CPO_05 Samba Member
Joined: October 13, 2011 Posts: 137 Location: Lakeside, CA (San Diego)
Posted: Mon May 21, 2012 5:34 pm Post subject: Carburetor/Distributor |
I am running a 1600 SP with a 30PICT 1 and a 009 Distributor in my 67 Splitty.
After doing research online about hesitation issues, I have come to learn that the 009 was not made for the Type 2's or the bigger 1600's, which could lead to hesitation problems.
I would like to upgrade mine and I was curious to what other people with 1600's were running as a carb/dist combo in their buses. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76904 Location: Sneaking up behind you
Posted: Mon May 21, 2012 5:36 pm Post subject: |
Bosch 019 mechanical works well on a 1600SP with a 30PICT-1. _________________ Glenn
Member #1009
#BlueSquare |
CPO_05 Samba Member
Posted: Mon May 21, 2012 5:51 pm Post subject: |
If you don't mind me asking, what does the 019 do better than the 009? From what I was reading you need the vacuum advance with the bigger carb for these engines.
Just curious. |
Glenn Mr. 010
Posted: Mon May 21, 2012 5:57 pm Post subject: |
The curve is better than the 009.
The 019 originally came in a Bus. It works well with stock to mild performance engines. _________________ Glenn
Member #1009
#BlueSquare |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon May 21, 2012 6:09 pm Post subject: |
Where does the 010 stand in the equation? |
Glenn Mr. 010
Posted: Mon May 21, 2012 6:11 pm Post subject: |
The 010 works better with larger displacement, big heads and cam. The curve works better with high performance engines. _________________ Glenn
Member #1009
#BlueSquare |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon May 21, 2012 6:32 pm Post subject: |
For many years, I used 009 distributors on my 1600 cc single port and dual port bus engines, and with no problems. The only time that my engines have had "hesitation" when taking off in first or second gears was with the dual port engines, due to their split manifolds. Right now, the single port 1600 cc engine in my 1963 bus uses a vacuum advance distributor and it runs really well. I love single port engines. _________________ Don't worry; be happy. (Baba) |
CPO_05 Samba Member
Posted: Mon May 21, 2012 6:35 pm Post subject: |
Campy: In your '63 with the vacuum advance, what size carb are you using? |
VolksFire Samba Member
Posted: Mon May 21, 2012 10:07 pm Post subject: |
There have been many threads discussing this sort of topic. I would encourage you to research the forums a little bit, I know that many people have posted their experiences with various carb/distributor combinations. Anyways, here's my 2 cents.
I have used a 009, 019, 010, 205m, 205t, 205L, 205k, 205p.... at some point on my 1600 SP's with an original 30pict1 (and governor).
Pretty much any of those above 205 vacuum distributors will work. I happen to favor the 205m (the 64-65 version, part number 111 905 205m, not the 113 version from 68, but that one also works).
I run it on my 63 sc and dc, although I plan to experiment soon with a fat cap 40 hp dizzy which would've been original for a 63 with the 1500 option (yes, now a 1600).
Anyways, the 009 sucked but I carry one on long trips as a spare just in case of whatever and its a pretty basic dizzy and cheap, that's why they are popular. The 010 worked well on my 1600dp with a 34pict3 and on my 1776 with kadrons (although I now run an 019 on there). The 019 was the best as a mechanical dizzy option for the 1600sp, but I still prefer vacuum dizzys.
As for what carb to run, you already have it. The 30pict1 is awesome. 28 Picts just don't cut it on a 1600 (someone feel free to prove me wrong, I'd like to know how it's jetted and/or modified). The H30/31 is the new carb that's available new in the box. It also comes with an adapter to be run on a dp engine. Most of these new carbs leak bad thru the throttle shafts. At the shop i work at, we often have to return the carb and get another because it is so bad. Keep the 30pict1 and try a vacuum distributor. _________________ Jahnai Pearson - VW Restoration Technician
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
85 Quantum Syncro Wagon
96 Golf GL |
Campy Samba Member
Posted: Mon May 21, 2012 10:35 pm Post subject: |
My single port engine has either a SOLEX 30 PICT-1 or 2 carburetor on it. Some thirty years ago, a mechanic told me to stay away from the 30 PICT-3 carburetor: it has a redisgned idling circuit. I uaed one and it did not work very well. _________________ Don't worry; be happy. (Baba) |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Tue May 22, 2012 10:46 am Post subject: |
What about a 34 pict 3 on a 1600cc. Whats the best distributor? _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Mr Mike Samba Member
Joined: March 23, 2004 Posts: 766 Location: washington state
Posted: Tue May 22, 2012 1:17 pm Post subject: |
Hey volksfire,
Read your comment on the test use of a "big cap" forty horse distributer
on your 1600 single port. Thought I'd share with you ( and anyone else that cares) I've been running a "big cap" with a 30 pict 1 on my '63
15 window with 1600SP about three years now.
My engine has around eight thousand miles since over haul. The bus is 12 volt. For what its worth I use Castrol HD 30 and on occasion when on the road 30-50.
Last March, the wife and I drove from our home north of Seattle out to the midwest ( a small town in Missouri south of St Louis) and back.
Normally I prefer back roads and two lane roads.
This trip we took I-5 to Portland, Or, then 84 through the Williamette valley, and then 80 across Wyoming then dropped down to Denver and took 70 all the way across to Missouri where we dropped down to hiway 44 for our last leg. We followed the same route home.
Weather and temperatures varied from 55 and raining like crazy when we left Washington (26 March ) to the late seventys in Missouri.
On flat stretchs particularly in Colorado and Kansas the bus cruised easily at 65 to 70. To be honest most of the time we rolled at 60. The bus seems happier at that speed. The winds in Kansas were easier to handle
also. I roll on stock 6.40-15 bias ply tires from Cocker.
I need to check my total milage for the trip,
but we had no troubles at all the entire run and while I didn't check gas milage every time, on the flats we got about 24.5 MPG.
On the hills ( theres a lot of them between Oregon and Kansas)
about 20 to 22) To be honest the 1600 is a dependable engine ( I think)
but maybe not the best for longer trips. It took a good two weeks to make the run out to Missouri. About 11 days to get back ( tail wind?)
I'm not any kind of expert on Carbs and distributers but I'm realy pleased
with the performance of my engine with the Big Cap.
It helped get us across the continental divide ( about nine grand?)
at a rompin' stompin forty miles an hour.
Funny thing on the entire trip we didn't see any aircooled VW's of any type. None at all, strange. |
zozo Samba Member
Posted: Tue May 22, 2012 3:36 pm Post subject: |
You only drove less than 150 miles a day? ~1800 miles, 2 weeks
That's the way to take a vacation. Can't call that a "hectic" pace, that's for damn sure. |
Posted: Tue May 22, 2012 4:05 pm Post subject: |
Hey ZOZO,
We stopped at a lot of places to take the "tour". The Williamette Valley
in Oregon kept us a while also. God's country! In Kansas
we checked out Fort Reily, and then later did the tour of General Custers
house where his wife lived while he was in the field chasing indians.
We spent a couple nights while hitting some museums also. Guess I should have said that.
We've driven the Pacific Coast hiway twice from Whidbey Island to the
Washington coast then down to San Diego to visit my old ship, USS Midway (I'm a retired 30 Year Navy guy) For us thats about a 10 day run.
Gotta love it! The wife and I are both in our mid seventies by the way.
zozo Samba Member
Posted: Tue May 22, 2012 4:09 pm Post subject: |
Mr Mike wrote: |
Hey ZOZO,
Gotta love it! The wife and I are both in our mid seventies by the way. |
I would really love it. I'm fixin' to head from San Antonio to Savannah, GA, and have barely a week to drive there, do some things, and drive back. Vacation time, but not a pleasure trip. They never are for some reason. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue May 22, 2012 4:39 pm Post subject: |
Mr Mike wrote: |
Hey volksfire,
My engine has around eight thousand miles since over haul. |
I'm running the same distributor in my '63 1500cc-equipped Bus with a rebuilt/rebushed 28 PICT carburetor. Same 6.40x15 Firestone tires.
It's been like that for I'm not sure how long, at least the same amount of mileage as Mr Mike's Bus.
No issues with this set up. I'm only getting about 21-22 MPG though. _________________ How to Post Photos
Glenn Mr. 010
Posted: Tue May 22, 2012 4:48 pm Post subject: |
EverettB wrote: |
I'm running the same distributor in my '63 1500cc-equipped Bus with a rebuilt/rebushed 28 PICT carburetor. Same 6.40x15 Firestone tires. |
Ev, you should try a BR8/019.
This past weekend a good friend drove his 64 Bus to CTS. On the way his distirbutor died. one of the guys he was caravaning with had a spare 019. He made it to CTS and all the way back. He love the 019 so much more than the stock distributor that he called me and wanted to pick one up on the way home.
Try it... you'll like it more. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 22, 2012 5:01 pm Post subject: |
I'm going to try that in my '61 1500cc Bus soon as I want the '63 to be as stock as possible.
The '61 has one of your 010s with a 30 PICT-1 right now as my used 019 was sticking.
I have used an 010 in the '63 too, the mileage was the same but the big cap accelerates a little nicer. _________________ How to Post Photos
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Tue May 22, 2012 5:41 pm Post subject: |
Glenn wrote: |
EverettB wrote: |
Try it... you'll like it more. |
Glenn,
Finally installing one of your rebuilt BR8's in a bus.
Actually on a 1600 SP on the test stand at the moment.
Got it purring with a standby 009, then swapped in the BR8.
For the 009, I set it to 28-30 deg. at speed, gives about 8 deg. at idle.
For the BR8, when I set it to 28 deg. at speed, I get about 13 deg. at idle.
Is this normal?
Should I go for 10 deg. at idle and then get a lower deg. at speed? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Glenn Mr. 010
