no gen light
cburger08
cburger08 is offline
PostPosted: Thu May 24, 2012 6:31 pm    Post subject: no gen light Reply with quote
i just bought a 72' convertible, and it seems to be running fine except when i start it up the gen light doesn't come on when i turn the key on. there doesnt seem to be any problems with the battery charging, and every thing is working fine. i cant figure out what is going on. every thing im reading is telling me, no light means its not charging, but the battery isnt dying. any ideas? this is my first bug and im not sure where to start
cferry7
cferry7 is offline
PostPosted: Thu May 24, 2012 6:42 pm    Post subject: Reply with quote
Check the Generator Light light bulb and wiring to the light bulb.
1st : ' 71 Super , 1641 cc , ~ Stock - a keeper !
2nd: ' 70 Standard , Totaled 7-14-01 , R.I.P.
cburger08
PostPosted: Thu May 24, 2012 7:03 pm    Post subject: Reply with quote
everything i read says that it wont charge with out that light working and its not draining the battery out. thats why im a little lost here
DuaneL
DuaneL is offline
PostPosted: Thu May 24, 2012 8:13 pm    Post subject: Reply with quote
I think your confusion is with alternators needing that light a 72 came with a generator and does not need the light in order to work
____________
1971 std bug 1600 German solex 34-3 dvda stock exhuast
1966 1300 sedan
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Thu May 24, 2012 9:09 pm    Post subject: Reply with quote
measure accross the battery with a volt ohm -- you need min 13.5 above idle
Experience always triumphs over hearsay and You get to select which theory to believe
