Star Adjustment HELP!
Indianwagon
Indianwagon is offline
PostPosted: Sat May 26, 2012 3:38 pm    Post subject: Star Adjustment HELP! Reply with quote
Replacing rear shoes and drums and have gone as far as getting everything off except the star adjustment stuff. HOW the F can one get them loosened off??? bin tapping with mallet and screwdriver and soaking with penetrating but am NOT winning.... any suggestions would be greatly appreciated! Oh.... '73 bus....
Thanks!
busdaddy
busdaddy is offline
PostPosted: Sat May 26, 2012 3:41 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=341642&highlight=adjuster+stuck
Wanted, 68-73 westy OG plaid curtains, singles OK.
Indianwagon
PostPosted: Sat May 26, 2012 3:51 pm    Post subject: Reply with quote
Thanks Surrey Busdaddy... thats just sounds wrong, anyhow, I even searched star adjuster and didnt get that topic. So heat it is... haha
Wildthings
Wildthings is offline
PostPosted: Sat May 26, 2012 7:18 pm    Post subject: Reply with quote
Once you get them apart drill an 1/8th inch hole in the bottom of each side, this will allow any water to drain. I guess you could also use the hole in conjunction with a grease gun with a needle adapter to just force the adjuster out, never tried this though.
cefalu
cefalu is offline
PostPosted: Mon Jul 16, 2012 11:18 pm    Post subject: Reply with quote
I just finished this job. All of mine were frozen in their bores and it really looked hopeless.
No amount of pounding or PB blaster would loosen them up. A map gas torch did the job nicely though. The threads are M10 X 1.5 . I chased all the threads with a tap and die, when I was done and it worked perfectly. To protect it into the future I greased up the bore and threads.
Unscrew the bolt with the slotted head if you can. Then screw in a M10 x 1.5 bolt until it bottoms out and it will push out the star if the star is stuck in its bore.
I hate drum brakes!!!!!
1974 Volkswagen P27 Westfalia Camper
1995 BMW 840Ci
1974 Mercedes 280C
1986 Alfa Romeo Spider Veloce
1999 Porsche 996 Cabriolet (w/Raby IMS)
2005 Toyota 4Runner V8 Sport
Desertbusman
Desertbusman is offline
PostPosted: Tue Jul 17, 2012 1:25 am    Post subject: Reply with quote
I just did the ones on my bug after many years. No problem. Naturally I greased the hole and the male and female threads again like before. Wipe away any excess grease the can squeeze out. It's the detail attention that gets good results.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
