Wideopen Samba Member
Joined: May 17, 2012 Posts: 279 Location: N. California
Posted: Sun May 27, 2012 6:46 pm Post subject: Engine lid ? |
What is the reason I see so many engine/deck lids proped open at the top? Is it that they get more cooling or is it just for looks to break up the body lines of the Beetle?
Just curious, I don't love it or hate it but wanted to know the reason behind it. |
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Sun May 27, 2012 7:28 pm Post subject: |
Could be both, but I think it lets more air in for better cooling. _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun May 27, 2012 8:11 pm Post subject: |
Usually Cooling but occasionally clearance.
I had to lift mine to clear my turbo and super engines.
My oil temp dropped 15f with them, and that was with a 4 vent engine lid. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Scorpwanna Samba Member
Posted: Sun May 27, 2012 8:12 pm Post subject: |
I wish i could adjust mine more. It scrapes the back end every time I close or open it. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun May 27, 2012 8:13 pm Post subject: |
Usually for cooling because their engines are not tuned correctly. _________________ Glenn
Member #1009
#BlueSquare |
Joel Samba Member
Posted: Sun May 27, 2012 8:20 pm Post subject: |
or if there is inadequate decklid venting.
a 2 vent engine lid is marginal with a doghouse engine, thats why they went to 4.
You run a doghouse engine with a non vented engine lid you will toast it nicely. _________________ Quick little bug, you got a Porsche motor in that?
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sun May 27, 2012 9:17 pm Post subject: |
Scorpwanna wrote: |
thats easy , stick some washers under the hinge between the hinge and the deck lid , it raises it just a bit to clear tje rear add more till it dosnt hit anymore adjust as needed |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Sun May 27, 2012 11:14 pm Post subject: |
Joel wrote: |
You run a doghouse engine with a non vented engine lid you will toast it nicely. |
X2
_________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Tompkins Samba Member
Joined: January 17, 2011 Posts: 192 Location: Beeville Tx
Posted: Mon May 28, 2012 12:09 am Post subject: |
It's for cooling. I think it looks cool too. _________________ Just one, a 70' bug in progress. |
