calvin and hobbs Samba Member
Joined: April 04, 2009 Posts: 12 Location: n las vegas
Posted: Sun May 27, 2012 10:32 am Post subject: Is there a RACK and PINION kit out there for type 1s? |
this maybe beating the skeleton of a long since dead horse but....does anyone know of a RACK and PINON steering kit for type 1's? don't get ahead of me now, i know there is the Mendeloa ($3200), Eyeball Engineering ($3,000) and Creative-Engineering's(site down at time of post) bulkhead-double a-arm, high proformance, bells and whistles out the ying-yang but like most people i can't and don't wanna spend 3 months mortgage(never mind the unforeseen costs and time it would take to install) on my bug for safer steering. i'm talking about what most of the threads on here are asking for(listen up manufacturers and engineers), a bolt-on RnP set up that delivers SAFER, TIGHTER and just all around BETTER steering that won't break the bank or the bug.
there is a thread on here that leads you here:
http://www.classic-centrum.de/Kaefer_Lenkung_1.htm
site is no good anymore. several other threads with talks of designing kits for with intentions to make copies with no such luck.
who, who out there can deliver a quality RnP setup that will meet the small need of better steering?
anyone? Bueller? ....Bueller? _________________ If it's not leaking, it's out of oil
'66 Bahama Blue
'72 Guards Red |
Hugo Stiglitz Samba Member
Joined: August 07, 2009 Posts: 753 Location: Southern California
Posted: Sun May 27, 2012 3:30 pm Post subject: |
replaced the ENTIRE front end when i put my discs in, steering box, ball joints, damper, bushing, tie rods, shocks...everything with all new parts and the steering is still sloppy. went form a 1300SP to a 2010DP now that i can go faster the 55(without a tail wind on a downgrade), i've noticed the steering is much worse then i thought. severe play in the wheel before it actually starts to turn the car being the major issue. tried adjusting the new steering box, still sloppy. i want a cleaner feeling. over correction due to soft steering components is not something i want should the need to swerve from a kid in the street or a wreck on the highway. _________________ If it's not leaking, it's out of oil
'66 Bahama Blue
'72 Guards Red |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 8120 Location: Black Forest, CO
Posted: Sun May 27, 2012 3:55 pm Post subject: |
How did you adjust the steering box?
Max _________________ The only thing more expensive than cheap parts is mixing cheap parts with stupidity. |
Posted: Sun May 27, 2012 5:12 pm Post subject: |
Gents, i feel we're headed in the wrong direction here. this wasn't meant to be a "how to" or a "did you try..." thread. a Rack and Pinion steering set is the focus here, that's what i'm trying to find, figure out, get. _________________ If it's not leaking, it's out of oil
'66 Bahama Blue
'72 Guards Red |
Posted: Sun May 27, 2012 6:03 pm Post subject: |
:: shrug ::
I'm sure there is something aimed at the off-road guys. Good luck.
first_one_a_65 Samba Member
Joined: January 22, 2010 Posts: 204 Location: bay area, california
Posted: Sun May 27, 2012 8:20 pm Post subject: |
there's plenty of bugs out there with even bigger engines that steer and handle just fine. im not questioning your mechanical ability or anything, but that obviously sounds like something isnt adding up.
before giving up and introducing a foreign setup into your car, why not check the basics? _________________ real cars dont power the front wheels.. they lift them |
VeeDubDoug  The veedub thug!
Joined: August 27, 2008 Posts: 1412 Location: The Gutter, SoCal
Posted: Sun May 27, 2012 8:36 pm Post subject: |
The reason you are having a hard time finding a rack and pinion setup is that they are not really needed.
You said you bought a new steering box... what brand?
Most "new" steering box's are notoriously crappy... _________________ Westküste
'66 Bug "Charlotte"
What's it to you...friendo? |
Posted: Mon May 28, 2012 8:24 am Post subject: |
i don't recall the brand of my steering box, i'm currently deployed so have no way of looking at the car. i want to use the time out here to research products and find toys for the bug so when i get home it's christmas. _________________ If it's not leaking, it's out of oil
'66 Bahama Blue
'72 Guards Red |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3726 Location: Canada 306
Posted: Mon May 28, 2012 9:31 am Post subject: |
There are a number of racks offered, but non are DOT approved meaning you'll have to retro fit something out of another car if you want to keep it DOT legal. And none of them are a bolt in and go, they will all require reworking of fuel tank and possibly your body to fit.
I've raced for 18 years with a stock suspension and never had any problems with sloppy boxes or steering, and I run 6-8" wide slicks on the front of my buggy. I've done everyhting with that car from going through tight twisty corners to big sweepers at 50mph and in a straight line flat out at over 100 with a cross wind.
Personally I would try my best to adjust the stock box propperly and if you still can't make it work go from there.
brad _________________ BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues |
BDSBSS23 Samba Member
Joined: January 03, 2008 Posts: 1598 Location: Home of the potatoes.
Posted: Mon May 28, 2012 8:00 pm Post subject: |
There always 75 up pan that will work with rack and pinion. Just that your bug even with rack and pinion it will take more work and i dont see why its really necessary..... _________________ 74 Super Beetle SOLD
69 Standard Beetle SOLD
61 Beetle SOLD
58 beetle AKA Black Beauty http://www.thesamba.com/vw/forum/viewtopic.php?t=496780&highlight=black+beauty
65 beetle sold
71 super DD sold
65 micro bus (project) |
Posted: Mon May 28, 2012 10:26 pm Post subject: |
| calvin and hobbs wrote: | | Does anyone know of a RACK and PINON steering kit for type 1's? |
To answer your question from above, no. Well at least not anymore. There was a German kit that used a VW Polo rack (good luck finding one state-side), but the link to their site doesn't work anymore. So outside of the ones you've named and noted that you weren't willing to drop that kind of coin on, nope.
The consensus here, and the reason I originally asked, is with a little trouble-shooting you can get the front end of a bug pretty tight. Keep in mind though, you can do whatever you'd like - It really depends on how deep your pockets are...
Introducing a rack and pinion setup isn't going to be a magic bullet that cures all of your woes. In fact, it will undoubtedly induce more woes. But it CAN be done. Like stated earlier, you can look at a 75 and up pan, modify your current pan/body to accept it. Also consider your steering column linkage (will a stock column work??). Admittedly this is all speculation on my part as I've never tried. I guess to me the juice isn't worth the squeeze.
The stock box, tie rods and steering damper setup is very capable of handling anything you can throw at it if you have everything setup properly.
Are you running stock height? If you've lowered the car, are you running a narrowed beam? Did you drop the rear? _________________ '63 slow n low build thread...
System 51 - Advanced Waxes & Polishes
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] |
Joined: May 16, 2010 Posts: 30 Location: saint louis mo
Posted: Mon May 28, 2012 11:20 pm Post subject: |
I have followed this thread for awhile as this topic intrests me too. It appears there are no less expensive street legal options than the ones mentioned. So I assume the next logical step is fixing the factory set up. I am not VW expert, but it seems most of the posters here think the front end can be worked out.
I have no technical advice on this issue, but what I can say is that in the past I have "believed" I "should" know how to fix or do something, but it turns out that it is just not as easy for me as it sounds. I used to spend a lot of time, energy, frustration, and ruined parts (aka money) on trying to do things I 'should know' how to do or fix. Over the years I have gotten better at knowing my limitations and have learned to hire a professional for certain things.
If I found myself in this situation I would take the car to my local VW guru, Archway imports, and say "Call me when it is done". Who knows, it could save me money too. Last year I was trying to fix a shifter cable on my Chevy II and took it out the highway for a test drive. At 65 mph it shifted into reverse instead of fourth. The wheels locked up and the cars around me were able to move in time to avoid an accident and I shifted to nuetral and coasted to the shoulder. It all turned out okay, but I could have easily wound up on my roof.
This steering deal sounds as though it could be expensive if done wrong too. _________________ 1966 Beetle
1966 Chevy II
1967 Chevelle
1967 Chevelle ss |
Joel Samba Member
Joined: September 04, 2006 Posts: 7974 Location: NSW Australia
Posted: Tue May 29, 2012 4:11 am Post subject: |
| Br58 wrote: | | There always 75 up pan that will work with rack and pinion. |
The 75 and later rack setup is only in the Super Beetles with strut front end, standard bugs stayed with steering box.
I've seen a few conversions into standard beetles though using racks from various donor cars like Golfs and Polos. |
jhoefer Samba Member
Posted: Tue May 29, 2012 11:56 am Post subject: |
| Joel wrote: | | Br58 wrote: | | There always 75 up pan that will work with rack and pinion. |
Yeah, the Super rack is for front steer spindles on Supers. Won't work with a standard beetle's rear steer spindles.
You might also look at the rack from an 87 Cavalier. Center mount like the super rack but for rear steer spindles. |
Posted: Tue May 29, 2012 8:49 pm Post subject: |
I've seen a few conversions into standard beetles though using racks from various donor cars like Golfs and Polos. | my bad. Thanks for correcting me. _________________ 74 Super Beetle SOLD
61 Beetle SOLD
65 beetle sold
71 super DD sold
trae Samba Member
Joined: June 13, 2011 Posts: 113 Location: high desert, california
Posted: Wed May 30, 2012 9:00 am Post subject: |
I'm thinking you should readjust the steering you have in the car and run it...there is a damn good reason why VW chose that set up for your car and it should work just fine  _________________ 69 squareback auto |
Posted: Wed May 30, 2012 9:29 am Post subject: |
way to think outside the box,thanks Trae. as per usual, you provide priceless advice with a total lack of smartassery _________________ If it's not leaking, it's out of oil
'66 Bahama Blue
'72 Guards Red |
Culito 11010101
Joined: December 07, 2006 Posts: 4963 Location: Columbia Missourah
Posted: Wed May 30, 2012 10:28 am Post subject: |
| calvin and hobbs wrote: | | way to think outside the box,thanks Trae. as per usual, you provide priceless advice with a total lack of smartassery |
Easy now.
There was a guy on here that built an awesome removable a-arm rack and pinion front suspension that used the stock mounting locations. Looked like lots of work, though. _________________ Copyright 2012-apocalypse, CJ Industries, Inc.
'62 Turkis fleet
| johnnypan wrote: | | ...dont pay no attention to Culito,he's a cornhole.. |
Posted: Wed May 30, 2012 10:40 am Post subject: |
i work with Trae, he's busting my balls. it's all in "fun" _________________ If it's not leaking, it's out of oil
'66 Bahama Blue
'72 Guards Red |
