Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jul 02, 2015 7:22 pm Post subject: |
D/A/N wrote: |
Tram wrote: |
Donnie strickland wrote: |
D/A/N wrote: |
When the heads were off last week, all plugs looked a nice tan but for #3 which was a little lean looking but still in the tan range. It also had cracks in #3 radiating down from the Time Sert toward the valve seat in addition to the cracks between valves on #4 we reported back in December . I don't think these heads are in it for the long haul! |
I think you've found your answer. If those cracks are bad enough, they're letting air in, which leans out the mixture on that head, which makes the temp go way up, which as Tram points out, makes for tight valves. |
Yep- I just now saw the little tidbit about cracks from the spark plug hole down to the valve. this is likely why #3 is running a little leaner and the resultant heat on that side is why the valves are going snug so fast.
Cracks between the valves on the inside aren't a big concern but cracks from the plug hole to the valve are.
That's not to say your trip is doomed by any means, just be aware that this is the cause and nurse it. |
I get that about the cracks but here's the thing: we've had tight valves on that head going back more than a year but the cracks showed up sometime after we had the head off and put in the Time Sert in December. The only crack then was the one between the valves on #4. Then we had all those lean AFR #'s we posted back in December and January.
We plugged in the O2 sensor today before hitting the road and by the time we'd driven 1/4 mile we had an idle AFR of 15!!! Backed it down at the MPS to about 12.5 b/c at that point the idle smoothed out very dramatically. Then, we realized it had climbed to over 1000rpm. When we brought the idle back down to around 850, the AFR changed to 13.1 (but was less smooth) but we left it there and drove off bearing in mind that 13 is the target #.
220 miles later and the valves are still clacking away loudly. We'll check them again in the AM before continuing our drive but in advance, I can't help but wonder how much the leanness was working against us. We didn't have a single reading over 15 whereas over the winter we regularly had AFRs from 16-18 as we posted back then. |
Excellent... I think you are getting it! 13,1 isn't bad at idle. Maybe richen it a shade to where it idles smooth. remember- Idle spec is "+ or - 50 RPM" so if it does OK at 900 or even 950 I would leave it there.
If this car does well for you on your trip, I can pop another DP head in the mail before you get back, and you can replace the 3/4 side head since it's not the one with the FI sensor bung.
If you're happy with how it does at that point, if this was my car, honestly, I'd just drive it like this instead of sinking my bread into having another engine built. I'd put the dough into having the body repaired where the NYC galoots ran on it (and maybe hire an armed guard, too) so you can then put the remaining dough and the fancy engine into "Bigger" since that'll probably be your long distance vacation on wheels.
But hey, that's just me, and I am a cheap bastid. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
jadney Samba Member
Joined: January 13, 2005 Posts: 263 Location: Madison, WI, USA
Posted: Sat Jul 04, 2015 5:21 am Post subject: |
Tram wrote: |
If this car does well for you on your trip, I can pop another DP head in the mail before you get back, and you can replace the 3/4 side head since it's not the one with the FI sensor bung. |
Sounds like you've forgotten that on Type 3s the FI temp sensor IS on the 3/4 side.
Also, I'd like to step in on this "leak thru the crack" theory. Personally, I don't think any crack that is small enough to still hold the spark plug in place will be large enough to make ANY measurable difference in the leanness of the mixture. Keep in mind that the max pressure difference across that crack during the intake stroke will be less than 1 atm, and that's only at idle, where a slight bit of leanness won't matter since it's under min load. At full load, WOT, the pressure difference will be more like 1/4 atm, so there's even less effect when it might matter.
We're talking about the amount of air that can slip in during ~30 mSec (at idle) or ~10 mSec at speed.
During the compression and power strokes the inside/outside pressure difference is 10-50 times higher. (I'm guessing at the high end here, because I don't know what the peak pressure can be during the power stroke, but I know that it's BIG.) If the crack was a significant leak, we'd probably be getting flames on the outside, which would char the plug connectors and melt the air seals.
Personally, I think the primary concern about cracked heads is that they relax the press fit of the valve seats in the alum. Once relaxed, there's bound to be an increased chance of those seats coming loose and digging their way down into the head. In fact, that may be what's causing the valves on that side to tighten up so quickly.
I think that the Timeserts are a good product, but I've always been concerned about their use on VW aircooled heads. They put the alum around the insert under tension, which tends to promote cracking. I think HeliCoils are a better solution, but they have to be installed and used with extra care.
If the spacing in our heads were larger, none of this would be a problem, but we're stuck with the geometry VW gave us. I like the idea of longer and/or smaller diameter plug threads, but those only come with aftermarket heads that seem to have their own weaknesses, so we're kinda stuck. _________________ Jim Adney
50+ years of VW Type 3 experience
Specializing in VW Type 3 parts and service |
Posted: Sat Jul 04, 2015 3:07 pm Post subject: |
jadney wrote: |
Tram wrote: |
If the spacing in our heads were larger, none of this would be a problem, but we're stuck with the geometry VW gave us. I like the idea of longer and/or smaller diameter plug threads, but those only come with aftermarket heads that seem to have their own weaknesses, so we're kinda stuck. |
As the Samba Socialist, if I am right too often people will doubt my sincerity. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Mon Jul 13, 2015 10:51 am Post subject: |
A little update from vacationland: we checked the valves again at 500 miles and found that the clearances on the 1/2 side had shrunk from .008 to .006 and the exhaust on #2 was about .005 so we opened that one up and left the others. All of the valves on the 3/4 side (the always tighter side) were still at .008!! Go figure....
All told, the thing has been driving really well. We have a small oil leak somewhere thats been causing some stinky heater boxes but it doesnt seem to be from the valve covers which are tight and dry. Haven't jacked it up to explore further but I suspect a pushrod tube seal.
The only incident so far happened yesterday.....After stopping at a store, the starter wouldn't crank...just like a few weeks ago after putting the motor in. Turn the key and nothing doing. Jessica fiddled with the battery cables, but unlike last time that didn't do anything. Tried listening for a click at the solenoid but the parking lot was too loud. So she crawled under the car with a jumper wire. When she jumped terminals, the starter spun and sparked. Then, we were able to use the key to start it and we've been fine since. However, it seems like theres definitely a problem brewing.
Here's the question: the fact that the starter spun when jumped would suggest the switch is bad, but after jumping the terminals, the key worked. So which is the problem, the starter or the ignition switch? |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Jul 13, 2015 10:54 am Post subject: |
Without knowing anything else I'd say your starter is about to die.
OR
Wires to/from starter are loose (ground?) |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Jul 13, 2015 1:55 pm Post subject: |
Sounds like the notorious hot/sticky solenoid problem.
You may wish to install a relay for the solenoid if you don't have one already.
You may also want to make sure the ground strap between the transaxle and body is intact and making good electrical contact.
Your starter motor itself is probably fine but the solenoid may be gummed up with old dried grease and be sluggish.
It's commonly done (especially on Buses) to wire a relay in so that the current to trip the solenoid doesn't have to go all the way through the ignition switch and back. Instead the wire from the ignition switch is used to trip a relay with then shunts power directly to the solenoid from the battery which is, of course, right there.
That may buy you some time and make hot starts easier.
It fixes the symptom though and not really the problem. You'll have to check out your ignition switch (measure voltage drop through it) and all the wiring in the circuit and if no luck there you may have to pull the solenoid and clean it. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Jul 13, 2015 2:26 pm Post subject: |
sjbartnik wrote: |
It fixes the symptom though and not really the problem. You'll have to check out your ignition switch (measure voltage drop through it) and all the wiring in the circuit and if no luck there you may have to pull the solenoid and clean it. |
I was always a "fix it right!" snob, but with the quality of electrical replacement parts these days, I think the old "hot start relay" band- aid is a good way to hyper- extend the longevity of the ignition switch. It seems to overcome the annoying Bosch no- start- hot problem that Bobby Bosch has never been able to fix with his starters, too.
There's always second gear and an incline, too. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Mon Jul 13, 2015 2:37 pm Post subject: |
I've said it before and I'll say it again - it's funny that a lot of cheap ass VW people ( ) will tell you not to do the relay, but over in the big $$$$ Porsche world, it's ok and even encouraged and recommended to add one. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Jul 13, 2015 8:54 pm Post subject: |
My objection is that most of those problems are due to degraded wire terminals. Adding half a dozen more terminals seems like a step backwards, especially those installations done under the car with exposed wires and connectors. I expect that after a few short years, the failure rate is higher due to the added failure points.
An old VW axiom: "What isn't there can't break."
I prefer to fix the root cause by cleaning or replacing the degraded connections.
On the other hand, for those models with rare and obsolete ignition switches (like Euro cars with ignition locks or old Type 3 switches, or a one-year-only unit like the '71, or an old Porsche), it may make sense to prolong the life of this otherwise high-current device that has a history of degradation and eventual failure. As posted, using this circuit merely to trip a relay means its contacts will last longer. Overall reliability will be reduced, but the gain in saving a nearly irreplaceable component is sometimes worth the trade-off.
Just be sure you use good connectors and install the relay under the back seat, not under the floorpan where road splash and dirt will cause failure. |
Bobnotch Samba Member
Posted: Tue Jul 14, 2015 10:11 am Post subject: |
D/A/N wrote: |
I've got a similar issue with my Notch. On it, I ran a wire from the starter terminal (the normal small wire 1) into the battery area. From there I added a push button switch and another wire from the battery. This allows me to "jump" the starter without crawling under it. But, in my case, it's actually a dead spot in the starter itself. It's been doing it for over 15 years now, and when it gets a bug up it's butt, I use the push button to start the car. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
D/A/N Samba Member
Posted: Sat Jul 18, 2015 5:08 pm Post subject: |
So we're back from hiking and climbing the high peaks of the Adirondacks. Here's a gratuitous vacation photo taken at 4700', somewhere above our backwoods primitive camp. It was quite a hike.
All told, we put just short of 1,100 miles on the car without any incident other than the one bout of not starting. Clearly, that's an intermittent issue as we drove over 220 miles today in 85* temps and stopped at rest stops and re-started the car without issue. The starter might have sounded a little slow, but I was more than likely paying too much attention. I can't tell if it's worth doing anything about it. This also happened once during the summer on our Type 1 about 3 or 4 years ago and not at all again since . I should add that during the summer, it usually takes 2 tries to start the car no matter how many times I might prime the fuel pump on the first start of the day. During cool weather, it always starts on one turn of the key.
Geo....I hear you about maybe running this motor into the ground and saving $$ for other stuff, but it's too late to turn back now on the new motor. Plus, what happens if/when this one gives out? If we'd had more time, since the end play was good maybe I could have refreshed the rod bearings, cam, and lifters, but that wasn't to be. Here's a pic of the lifters right before we put in the p/c's. It's clear that they're worn and aren't in it for the long haul
D/A/N Samba Member
Posted: Tue Jul 21, 2015 1:26 pm Post subject: |
Ok, so we broke down the busted motor yesterday and have been doing some poking around and exploring and have some interesting pics and info. First of all, the center main is steel backed and is not .040, but STD. All the rest were non-magnetic and had no discernible #'s on them
Then, on both the #1 and #2 mains, the oil holes in the bearings don't match the holes in the case at all. Though you can see the imprint on the case, I also circled where the holes make contact. Here's one on #1.
And here's the other
Here's the one on the center main. Hard to believe there's less than 20k miles on that bearing!
Here's damage to the dowel pin hole on the #1 main
And here's a shot of the corresponding area in the case. Also note the huge ridge in the bearing saddle and all of those "scuff" marks
The outer surface of the bearing is all scratched up too
The center main also had a ridge but not as big as #1...unfortunately, no pic. The 3 and 4 saddles were smooth and nice though. Only a pic of 3:
Posted: Tue Jul 21, 2015 5:15 pm Post subject: |
1. The bearing you are showing is a Metaleve manufactured in 6.2009 with a standard INSIDE diameter for your standard crank.
This is a 40 over main set- why there is a steel backed in there is probably because we've been having issues with mismatched 40 over bearings in the same box.
Mike the outsides- that is where your oversize is.
2. As to the oil hole lineup- some years ago, the bearing manufacturers went from having the oil groove on the inside of the bearing to the outside- more universal fitment that way. The groove on the outside acts as an oil passageway to the hole in the bearing.
If the bearing wears or starts 'walking", you lose lubrication, though... and everything I see points to that being exactly the case.
That original case looks savable, though. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Jul 21, 2015 5:22 pm Post subject: |
D/A/N wrote: |
Looks like pretty typical wear to me- not of much concern. If the lifters are worn, the cam goes flat, and that cam is NOT flat, nor does it show any signs of wear beginning.
I mean this in the kindest possible way, but you worry way too much about every little issue. While I sort of understand that after all you've been through, i don't get why the drugs are so much more powerful today then they were when I was a kid your age. I guess we'll blame Monsanto. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
jadney Samba Member
Posted: Tue Jul 21, 2015 6:09 pm Post subject: |
Dan,
I don't see anything in your photos that's unexpected. The bearings are Metl Leve, a Brazilian brand that has always worked perfectly for me. Everything here is consistent with the bearing(s?) coming loose and wearing into the case. The oil holes in the bearings aren't expected to line up with the oil holes in the case. The holes in the case are drilled where they must be to access the pressure galleys in the case. The oil holes in the bearings are where they need to be to feed the bearing in a low pressure area. The groove around the OD of the bearing is there to connect these 2 different places.
The rotation of the crank pumps oil around in the space between the bearing and the journal. The action of the pistons and rods tends to push the crank sideways, L & R, creating tight areas that the oil gets pumped into, generating high oil pressure in exactly the places where it's needed. This pressure is MUCH higher than the pump output pressure and is what makes a plain journal bearing such an excellent bearing. This pressure keeps the journal from actually contacting the bearing, except when the engine first starts up and takes a few seconds before oil gets fed into the bearing.
It's "normal" to find a ridge under the #2 bearing, because the crank tends to flex and beat that bearing out against the case. This is especially a problem if the engine has been run at high rpm. It's not "normal" to see this in an engine with this few miles.
Another place you can look for signs of high rpm running are the pushrods. At high rpm they also tend to flex. You can see signs of this as brite wear rings where they rubbed as they flexed. If you see such a ring on just one pushrod, that probably means a pushrod tube/seal that was misaligned, but if they all show these wear rings then this would be high rpm running.
If the pushrods don't show these rings, it would be a good idea to check the crank to make sure it's not cracked. A crack would probably not be visible, but there are tests to find them. The simple way to do this is to remove EVERYTHING from the crank, suspend it from one finger under one of the crank throws, and tap an unimportant part with a hammer. It should ring like a bell. If it just goes CLUNK, then there's a crack somewhere, and that may have caused it to flex more than normal. They do spontaneously develop cracks, but I've only ever found one. I knew someone else who had the crack progress and completely break.
The hard part about this test is that you have to remove everything to do it. That means removing the cam and timing gear, and the Woodruff keys under them. That takes special tooling. I've got the tooling, but you might be able to find someone in Brooklyn who also still has it.
The elongated dowel hole in the bearing is normal once the bearing has gotten loose.
Regarding your starter experience, it's something that just seems to happen occasionally, especially with AT cars. If it happens more frequently, I'd take the brush end cover off the starter and clean out the brush "dirt" that accumulates. I've occasionally found that the brushes get stuck in their slides and can't slip forward to make good contact with the commutator. High resistance there means that the pull-in winding in the solenoid can't work, so the solenoid doesn't pull in and there's no click and no starter action.
Of course there are other possibilities. I'm not against the relay approach (especially for '71s) but I would put it under the back seat, not out in the weather under the car. For '71s, one of these days I'll finish the relay mod that's been in the back of my mind for a long time. _________________ Jim Adney
jadney Samba Member
Posted: Tue Jul 21, 2015 6:20 pm Post subject: |
Tram wrote: |
Looks like pretty typical wear to me- not of much concern. If the lifters are worn, the cam goes flat, and that cam is NOT flat, nor does it show any signs of wear beginning. |
I agree. New lifters are convex, but they seem to wear concave very quickly. Once broken in like this, they seem to last a very long time in this state. _________________ Jim Adney
Posted: Tue Jul 21, 2015 7:31 pm Post subject: |
One thing I'd like to know from D/A/N: Did the short block replacement solve the dancing shifter issue?
I'd also like to know if you find a cracked crank because then we'd have a definite answer to what did all this unless it's a mismatched set of 40 over bearings. The weird thing about the mismatched bearing theory, though, is how long this engine lasted- usually the "problem bearings" don't seem to survive much more than a few hundred miles from what we've been hearing.
The cracked crank theory actually makes the most sense to me at this point. It'll be interesting to see if the "ring test" proves this wrong. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Tue Jul 21, 2015 7:46 pm Post subject: |
I haven't had a chance to mic the bearings yet, but tomorrow should be a good opportunity and I'll post the results. I also have the tools necessary to remove the gears and woodruff keys from the crank and can do the crack test.
The new short block has definitely stopped the dancing shifter issue. It drives like "normal"....certain odd harmonics from the motor have vanished, there aren't any weird vibrations, and everything feels much smoother, from driving to shifting.
The weird thing is that we noticed all of the weird vibrations and shifter stuff after only 4-6 weeks of driving over a year ago and it still held up for more than 14k miles! |
Posted: Tue Jul 21, 2015 9:06 pm Post subject: |
D/A/N wrote: |
On the other half of that bearing there should be a number stamped. *IF* I am remembering correctly, it should be "465" for 40 over on the outside.
On the noise part- you always had the "sneakers in the dryer" noise from the beginning. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Wed Jul 22, 2015 2:24 pm Post subject: |
Tram wrote: |
D/A/N wrote: |
On the noise part- you always had the "sneakers in the dryer" noise from the beginning. |
There are a bunch of numbers and letters on the other half of the center main but none of them are 465. I have "BC 298" and "HL 19261". I hope that means something to you b/c it's gibberish to me.
As to the measurements, I have the center main shell measuring at .2095 and the #1 at 2.59.....According to info I found elsewhere on the site:
For #1 main, if the case has been bored + .040" The dia = 2.599"
For #2 main shell, if the case has been bored + .060" The Shell measures .2095"
So it looks like I'm coming up with two different bearing sizes, one correct for .040 and one correct for .060 though the case was bored to .040...These are my repeated findings but I can post a video that shows how I'm doing it if it makes any difference b/c I might be doing something wrong. It wouldn't be the first time.... |
