web cam, dfl coated?no cam card?
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
mark tucker
mark tucker is offline
PostPosted: Thu May 31, 2012 12:07 pm    Post subject: web cam, dfl coated?no cam card? Reply with quote
just got a new web 163 in the mail today, no cam cardWTF??, So I reckon it go's slot to bolt to dot.
the cam looks great,stroker clearanced,wish it was debured before the lube was applied.(looks to be dfl coated instead of parkerized). And a new crank gear, that has nice burrs on the teeth( I just love a quality product). but the cam gear from roy, looks pretty good.
yamaducci
yamaducci is offline
PostPosted: Thu May 31, 2012 12:19 pm    Post subject: Reply with quote
I had to debur my 86c but I don't think that is DFL coating. Also take a look at the cam thrust surface. Mine looked buggared from a lathe in 3 or 4 evenly spaced locations. I managed to work it out with some wet paper before I set cam endplay. I didn't like that. Otherwise, very impressed with overall WEB cam look and "Notch" clearancing job.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
Cox Racing Engines
Class 5-1600's; Stock 1600 to 2498cc Type 1's. Custom Built for you in Maryland
mark tucker
PostPosted: Thu May 31, 2012 2:01 pm    Post subject: Reply with quote
thrust looks great.it sure looks to be dfl coated& not parkerized.it shines up real nice witch parkerizing dont do when scratched with a fingernail or rubbed good like dfl does.
modok
modok is offline
PostPosted: Thu May 31, 2012 5:45 pm    Post subject: Reply with quote
it's a heat treatment of some kind
Welcome to the future mark, if you need a card print it out. It's on their website
Steve Arndt
Steve Arndt is offline
PostPosted: Thu May 31, 2012 6:53 pm    Post subject: Reply with quote
Buy your Web cams from aircooled.net. You can get any custom grind you would imagine, and the cam card comes included....
mark tucker
PostPosted: Thu May 31, 2012 9:22 pm    Post subject: Reply with quote
I didnt buy or order it, but found out the customer has it and will send it to me., no modoc not heat treetment.
modok
modok is offline
PostPosted: Thu May 31, 2012 10:00 pm    Post subject: Reply with quote
oh, ok
Do you know what carburizing look like?
I do not know if that is what they do, but it is what it looks like, unless you don't know what it looks like, in which case....... um...... well you know what I mean
fastone
fastone is offline
PostPosted: Thu May 31, 2012 10:40 pm    Post subject: Re: web cam, dfl coated?no cam card? Reply with quote
Mark, split the overlap and go from there, I'am I missing something ?
66brm
66brm is online now
PostPosted: Thu May 31, 2012 10:46 pm    Post subject: Reply with quote
Wunda ifn its wun offem haaard weeeelded ones or ar nu grynd?
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
[email protected] wrote:
Kadrons are horrible excuses for carburetors.
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
