GoldWing Motor swap
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
Aloha Bob
Aloha Bob is offline
PostPosted: Mon Jun 04, 2012 9:08 am    Post subject: GoldWing Motor swap Reply with quote
I was cleaning my GoldWing last night and was thinking.
It has a compact 1800 cc boxer motor that is fuel injected and has 180 hp.
Anyone ever try putting one of those in a Bug?
FYI....because the motor is a component of the frame and when they get laid down or (heaven forbid) run into something..the insurance companies don't fix them, they total them out and I have seen them go for $500 .
With all the crap that I have on mine , it has to weigh 1100 pounds...and I can smoke a corvette from a standing start up to about 90 when the motor stops pulling hard.
Any thoughts (other than agreeing with my wife that I am too old to be riding a motorcycle) ?
DarthWeber
DarthWeber is offline
PostPosted: Mon Jun 04, 2012 9:16 am    Post subject: Reply with quote
That's an interesting idea! What is the bore and stroke on those engines? What about clutch issues with a heavier VW?
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Aloha Bob
PostPosted: Mon Jun 04, 2012 10:07 am    Post subject: Reply with quote
I have not a clue on boar and stroke....I will need to google it.
As far as clutch goes....I actually tow a little trailer that weighs about 500# when it is fully loaded down (we do wine rides and the Boss loads it down at each stop we make).
I had a clutch put in it at 87,000 miles and the guy at Wingworks said it would have gone another 20k or so.
What could be sweet would be some place like McCloud to take a VW blank fly wheel and put a GoldWing crank bolt pattern on it and have plate to go between the motor and trans.
I have a Atlantic in boxes that has a Hewland transaxle that is based on a VW style case....with a adapter plate that bolts the Holbay engine on.
I will have to find the box with that and see.
Aloha Bob
PostPosted: Mon Jun 04, 2012 10:11 am    Post subject: Reply with quote
About 20 years ago, I put a 903 Kawasaki in a bug eyed sprite by making a longer drive shaft an hooking it up to the output shaft on the Kawi trans (long detailed story on how it was done).
That car would scream. No clutch problems ....and no reverse.
windsoreight
windsoreight is offline
PostPosted: Mon Jun 04, 2012 10:33 am    Post subject: Reply with quote
At the last VW show I went ,there a vendor there with a kit to install a Harley v-twin using the stovk VW trans.
Alstrup
Alstrup is offline
PostPosted: Mon Jun 04, 2012 10:35 am    Post subject: Reply with quote
That engine is actually an Alfa Romeo engine.
- I think the 180 hp is........ slightly positive. Most of them produce about 155-160 IRL.
Anyway. It is not a problem Adapters are produced several places. I even think KEP have them in their program.
T
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jun 04, 2012 10:54 am    Post subject: Reply with quote
Torque is what will push a VW down the road.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
Aloha Bob
PostPosted: Mon Jun 04, 2012 11:28 am    Post subject: Reply with quote
Great info.
Thank you.
The 180 hp is what the people at WingWorks told me after they charged me $250 for some part and installation.
The Wing does scare me sometimes when I am riding down the road and wondering why everyone else is going so slow.
The Boss whacks my helmet and says unkindly things on the intercom.
supersuk
supersuk is offline
PostPosted: Mon Jun 04, 2012 11:40 am    Post subject: Reply with quote
6 cyl boxer engine
74mm x 74mm
118hp 5500rpm
123 lb/ft 4000rpm
68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323
View user's profile Send private message Send e-mail AIM Address MSN Messenger Gallery Classifieds Feedback
OLD VW NUT
OLD VW NUT is offline
PostPosted: Mon Jun 04, 2012 12:14 pm    Post subject: Reply with quote
supersuk wrote:
6 cyl boxer engine
74mm x 74mm
118hp 5500rpm
123 lb/ft 4000rpm
Thats enough power and torque to make it worthwhile to give er a go - but I think the Subaru transplant would be a better investment since all the parts needed are available over the counter. Even a small Subaru motor will provide more power. Want more? Go with one of the turbo versions. Can you buy an 1800 GW motor for $500?
71 Ghia Coupe - stock body - no rust! Powered by a mild 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2012 Nissan Leaf SL EV
POLITICIANS AND DIAPERS NEED TO BE CHANGED OFTEN -- AND FOR THE SAME REASON
gt1953
gt1953 is offline
PostPosted: Mon Jun 04, 2012 1:25 pm    Post subject: Reply with quote
This is interesting and never heard of it but man what an idea.
mcmscott
mcmscott is offline
PostPosted: Mon Jun 04, 2012 9:00 pm    Post subject: Reply with quote
Torque is what pushes my long bed, 4 door, 4wd, powerstroke pulling 26000 lb trailer with a vw inside of it down the road
lostinbaja
lostinbaja is offline
PostPosted: Tue Jun 05, 2012 4:21 am    Post subject: Reply with quote
OLD VW NUT wrote:
supersuk wrote:
6 cyl boxer engine
74mm x 74mm
118hp 5500rpm
123 lb/ft 4000rpm
I'm sure the Honda engine will not have the head gasket and timing belt issues that the Subi's have.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
MURZI
MURZI is offline
PostPosted: Tue Jun 05, 2012 7:49 am    Post subject: Reply with quote
looks like a lotta stuff hanging below the crankshaft.........
62 vert
mark tucker
mark tucker is offline
PostPosted: Tue Jun 05, 2012 7:58 am    Post subject: Reply with quote
not realy, justlook at where the cam on a vw would be, and then the sump and then the added sump, looks great to me, and with some work probably a lot more power.and of corse the honda brand with it's superrior casting&machining, manufacture,desine, reliabilty,etc. bore it to 94 stick some 450f pistons in it,have jose stroke it a bit ,bore out the throttle bores and go have fun.
Aloha Bob
PostPosted: Tue Jun 05, 2012 12:32 pm    Post subject: Reply with quote
I asked a friend who is a buyer for a company called "CoPart" to look and see what the 6cyl Wings were going for .
He said that a couple that had been in front end wrecks went for $350.
There is soooo much ABS plastic on these things that is soooo expensive...that no body wants them.
I asked him to keep an eye out for me.
People in the GoldWing club think that I am nuts.
They say that my problem will be the electronics.
Along with putting a 903 in a sprite, I have done things like putting a 350 chevy in a TR-6 and a 260 Z...a 302 in a Plymouth Arrow mini pick up, a 215 olds aluminum V-8 from a 64 into a Datsun 510....and some other "different" combinations.
Maybe it is because I drink too much beer and end up staring at stuff in my little shop too long.
Aloha Bob
PostPosted: Tue Jun 05, 2012 2:18 pm    Post subject: Reply with quote
I am going to a pre auction on Friday to see a wrecked Wing.
bugger101
bugger101 is offline
PostPosted: Tue Jun 05, 2012 4:19 pm    Post subject: Reply with quote
Oh man the wheels are in action Surprised Cool
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
JustBuggy
JustBuggy is offline
PostPosted: Tue Jun 05, 2012 9:58 pm    Post subject: Reply with quote
That 215 into a 510 was a popular swap back in the good ol' days!
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Wed Jun 06, 2012 7:48 am    Post subject: Reply with quote
Buick aluminum V8's have been swapped into mid engine Crovairs, makes a nice light powerpack. I'd be interested to see if the Honda engine fit width-wise into an unmolested VW engine bay, would be an interesting swap.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
