apba12m Samba Member
Joined: November 08, 2011 Posts: 76 Location: michigan
Posted: Sun Jun 10, 2012 1:59 pm Post subject: rattling in fan housing |
I just got the engine back together fron rebuild started break in and now have a rattle in the fan housing. pulled the gen belt and as I spin the fan it is hitting something that is loose inside. Bottom line will the whole fan shroud come off with engin in the car or should I bite the bullet and pull it again? |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun Jun 10, 2012 2:54 pm Post subject: |
pull it again , you can get the fan out without liffting the fan housing easy with dual carbs a lot harder with stock carb. If you want to make it easy if you have to replace the fan or gen again while you have the engine out replace the 4 studs that hold the gen stand with bolts as i did and it makes it easy to remove the fan if you need to do it again |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Sun Jun 10, 2012 8:32 pm Post subject: |
Is the nut loose on the back of the generator that holds the fan on? If so, you might be able to tighten it up by holding it with a big socket and turning the front part of the generator with a wrench. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Sun Jun 10, 2012 9:51 pm Post subject: |
It's not possible to pull the doghouse off with the engine in the car, but you can pull the generator if you work at it. Pull carb, intake manifold, fuel pump (I think) loosen the strap, remove the generator backing plate bolts to the doghouse, remove the side doghouse bolts, remove the forward elbow tin (the one that takes the output of the oil cooler and ducts it forward). Whew, now unbolt the gen stand from the engine, lift the generator (which will pull the doghouse up about an inch) and the gen stand enough to get the gen stand clear of the studs, then slip the stand off to the side, then slip the gen out of the shroud. It helps if you have 3 hands. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Posted: Mon Jun 11, 2012 5:27 am Post subject: |
I am going to pull the motor. I can reach around and feel the fan as I turn the generator and nothing is loose. Must be a turning vane inside has come loose and hitting the fan? |
Banker Samba Member
Posted: Mon Jun 11, 2012 2:17 pm Post subject: |
Make sure the engine tin is not hitting the pully, not that this was my case _________________ Brian
07 Charger Sublime
03 Goldwing
74 Thing |
Posted: Tue Jun 12, 2012 2:30 pm Post subject: |
Found it! one of the two nuts that hold the fan cover to the generator had come off and was loose between the fan and the housing. used loctite this time! engine back in and running fine... |
