prostock3 Samba Member
Posted: Wed Jun 06, 2012 9:43 am Post subject: Type 34 find - Black chop top |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Wed Jun 06, 2012 10:37 am Post subject: |
Wow...... Kind rare huh. VERT!!!!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Bobnotch Samba Member
Posted: Wed Jun 06, 2012 11:09 am Post subject: |
It looks like someone started to build a convertible, and then stopped. The windshield also looks a little cut down too. It would be a fun car once it's finished though.
P.S. Couldn't you find a bigger picture to use? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jun 06, 2012 11:30 am Post subject: |
pic of the front post |
vwfye Samba Member
Posted: Wed Jun 06, 2012 11:39 am Post subject: |
please deliver that up to my house in SW Oregon ASAP! thank you _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
MURZI Samba Member
Posted: Wed Jun 06, 2012 12:01 pm Post subject: |
LET THE BIDDING BEGIN!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Jun 06, 2012 12:05 pm Post subject: |
vwfye wrote: |
please deliver that up to my house in SW Oregon ASAP! thank you |
You already dropped out on one, Smedley. The flames and pink scallops wouldn't fit, remembah? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vdubjim Samba Member
Posted: Wed Jun 06, 2012 12:56 pm Post subject: |
yes, steering coumn shaft and door bottoms make me think been outside a long time with no cover |
Posted: Wed Jun 06, 2012 2:53 pm Post subject: |
vdubjim wrote: |
One word: Katrina. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
MURZI Samba Member
Posted: Wed Jun 06, 2012 3:03 pm Post subject: |
Funny.... I was thinking one word: ENVY
The dude has one of 17 made and 5-6 known to exist. That's pretty special in my book$$$$$ _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Wed Jun 06, 2012 3:10 pm Post subject: |
MURZI wrote: |
The dude has one of 17 made and 5-6 known to exist. That's pretty special in my book$$$$$ |
I have one here, too. Mine's not a real factory one. Neither is this. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
MURZI Samba Member
Posted: Wed Jun 06, 2012 4:04 pm Post subject: |
How could you tell?? The area above the rear quarters looks factory to me....not cut. What are the tell tales. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Wed Jun 06, 2012 4:44 pm Post subject: |
MURZI wrote: |
How could you tell?? The area above the rear quarters looks factory to me....not cut. What are the tell tales. |
Maybe you're seeing pictures I'm not on the other site?
According to all the info available, the chances of a real one having made it to the USA are probably less than nil.
But- a VIN number might help us determine if it's in the ballpark. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Lee Hedges Samba Member
Joined: November 09, 2000 Posts: 811 Location: San Diego
Posted: Thu Jun 07, 2012 9:34 am Post subject: |
I spoke with Patrick today about this T34.
No front VIN plate and mounted on a 1965 Fastback chassis. From the body parts it appears to be from 1963 (manual heater vents, push-button controls, one-piece fresh-air vent trim, heater tube design under rear seat, etc). Definitely NOT an original M341 with the lack of rear seat frame support plate, vertical inner heater vents, & lack of under-dash dome light.
But he's got some amazing plans for it ... |
MURZI Samba Member
Posted: Thu Jun 07, 2012 11:18 am Post subject: |
So Pat.....you gonna shove the Turbo motor in this baby???? Cruising the coast is right around the corner...GET BUSY!!! That would be flat out BAD AZZ!!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Jun 07, 2012 1:36 pm Post subject: |
I am planning a hybrid wrx motor,2.5l turbo with about 350-400 hp
tied to a bus gear box, so I will have to convert the swing to irs rear, It will be a roadster, no rear seat, I won t mind cutting it up since it is not a real vert, disappointed a little, but more excited that I will be able to build it my way. I will post a complete step by step build for anyone intersted |
Posted: Thu Jun 07, 2012 7:53 pm Post subject: |
prostock3 wrote: |
Please do. We always like seeing stuff actually get done. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Fri Jun 08, 2012 3:49 am Post subject: |
Far better off using a WRX or STI 5 speed, motor is a direct bolt on and is just a much better box than a bus box plus the bonus of a 5 speed.
Subaru gears in Aussie make ring / pinion flip kits for these also, they fit a VW chassis unbelievably well plus its built to handle the power you are aiming for.
Once my Ghia is done I'm putting a Version7 STI engine in my 79 Vert, 380hp factory with a STI gearbox, some even have a factory LSD in them if you know what to look for.
Don't want to cut up the Ghia, where as the Bug I don't mind _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
T2 Samba Member
Joined: February 15, 2003 Posts: 187 Location: Yachats, Oregon
Posted: Thu Jan 22, 2015 4:56 pm Post subject: |
I know the original poster sold this car a year or two ago to someone in San Antonio. Is the new owner on here or does anyone know him and can pm me his info? I would like to track down this car. Any help is appreciated. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Fri Jan 23, 2015 3:11 pm Post subject: |
Where would one find a shortened type 34 windshield??? _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
