Removing exhaust manifold
JSalzillo
JSalzillo is offline
PostPosted: Thu Jun 07, 2012 9:57 am    Post subject: Removing exhaust manifold Reply with quote
Can you remove the exhaust manifold from a 72' 1600 without removing the engine?
65'1300Deluxe
65'1300Deluxe is offline
PostPosted: Thu Jun 07, 2012 10:05 am    Post subject: Reply with quote
Do you mean the muffler portion or the heat riser section under the carburetor?
1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
JSalzillo
PostPosted: Thu Jun 07, 2012 10:11 am    Post subject: Reply with quote
I meant the heat riser below the carb. It is a dual port.
CaffeineJunky
CaffeineJunky is offline
PostPosted: Thu Jun 07, 2012 10:17 am    Post subject: Reply with quote
I've removed the entire intake manifold from my single port engine including the heat riser without pulling the engine. It was a pain, but it was doable. You'll have to remove your generator/alternator, the gen/alt pulley stand, and possibly some of the other components. Can't remember if I "had" to remove the fuel pump and distributor, but I did because I was replacing a bunch of stuff.
I assume it would actually be slightly easier on a DP engine because of the rubber boots on the intake.
1969 VW Bug - 1600 on a 5" narrowed beam
JSalzillo
PostPosted: Thu Jun 07, 2012 11:21 am    Post subject: Reply with quote
I think it would be easier with the boots also. I have a small leak which I've heard is a common problem with older cars. Not a big deal but something that needs to be addressed. Thanks
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
