motor swap
Goto page 1, 2  Next
livy
livy is offline
PostPosted: Thu Jun 07, 2012 7:28 pm    Post subject: motor swap Reply with quote
Has anyone put a type 4 engine into a thing? I wonder how hard that would be? Not thinking about doing it I was just wondering.
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Jun 07, 2012 8:28 pm    Post subject: Reply with quote
There are several people that have done the "481" conversion. I believe they all used the DTM upright conversion. Should be several threads.
Ian Epperson has a Type IV. Take a look through his threads. Threre's a couple of examples in Youtube
Soloman Grundy's
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 99 181s in the world
Ferretkona
Ferretkona is offline
PostPosted: Thu Jun 07, 2012 10:34 pm    Post subject: Re: motor swap Reply with quote
http://www.aircooledtechnology.com/
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
Wildthings
Wildthings is offline
PostPosted: Fri Jun 08, 2012 12:23 am    Post subject: Reply with quote
Build and install an oxyboxer.
Ian Epperson
Ian Epperson is offline
PostPosted: Fri Jun 08, 2012 9:33 am    Post subject: Reply with quote
Here's the vid of firing up the Type4 Torquer Jake Raby motor in my Thing:
I will never go back to having a T1 in my Thing again.
If you go with the pancake cooling shroud that comes stock on the bus and Porsche T4 engines, you'll have a lot of cutting to do to fit the sucker in. However, if you go with a conversion kit (like Grundy and I did) then it'll bolt up very like a high performance T1 engine - same mounts, almost the same clearance.
There are two kinds of conversion shroud: DTM (sold by Jake Raby) and a Porsche look-a-like (sold by discount shops everywhere). Raby had tested the Porsche-type shrouds and found them lacking, tested the DTM shroud and found it awesome, and eventually bought the rights to make and sell the DTM shrouds.
I spent a lot of money on my conversion. $8k (deep discount) for the hand-built-by-Raby engine, $2k (+2 more $k when I ripped it apart twice) for the transaxle, a couple more thousand for the awesome Tangerine exhaust, and several more dollars on bits and pieces (oil cooler, fuel pump/filter, electronic ignition, truss bar, etc). It took me 6 months or so worth of weekends to get everything installed and running. I believe it's running with about 180-190 HP.
Grundy's engine doesn't turn as much power as mine (still a bunch more torque than a T1), so he didn't need to upgrade his transaxle or reinforce his engine mounts, nor add an external oil cooler. He bought a T4 engine from a builder in California and we installed the DTM kit in his garage and patio. I think he went all in for under $4k and had it done in under a month. Stock, that engine has 90 HP.
How crazy do you want? Cool How's the budget?
VW-181 shirts and stickers.
http://ian.epperson.com/vw
sixty9fasty
sixty9fasty is offline
PostPosted: Fri Jun 08, 2012 11:54 am    Post subject: Reply with quote
Wow you guys are crazy putting a type4 in there Laughing
Ok, ok, here's an older pic of the 914 2.0L in my Thing, it's out for a rebuild right now, speaking of which, gotta call the guy...
My Oval Project
Wanna Touch MY THING?!
Jake Raby
Jake Raby is offline
PostPosted: Fri Jun 08, 2012 8:53 pm    Post subject: Reply with quote
Happiness is a 481.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
citroen
citroen is offline
PostPosted: Wed Jun 20, 2012 5:57 am    Post subject: Reply with quote
here is what it looks like if you leave in in stock form the rear of the thing has to be redesigned
cecil
cecil is offline
PostPosted: Wed Jun 20, 2012 3:39 pm    Post subject: Reply with quote
[img]Image may have been reduced in size. Click image to view fullscreen.
If you plan on changing engines a lot or adding a type 4/914 I might suggest a removable section. The engine just slides straight out and in with ease. GI Joe has this mod for a Type 1.[/img]
There are three kinds of people. Those that can add and those that can't.
Solomon Grundy
Solomon Grundy is offline
PostPosted: Thu Jun 21, 2012 9:12 pm    Post subject: Reply with quote
Here is my story.
Names have been changed to protect the innocent.
But the low end torque is very nice.
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Dr. Seuss
VW 181 Archive: https://sites.google.com/site/jeffgilleland/vw_archive
| _______
| |_______| '73 Thing "481"
| _\_\_|_/_/_
| |O||_4_||O|
and I am not talking about the VW K70, a watercooled front engine car designed by NSU from the early 1970s… Wink
http://en.wikipedia.org/wiki/Volkswagen_K70
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger Gallery Classifieds Feedback
ajbuchok
ajbuchok is offline
PostPosted: Thu Jun 21, 2012 11:46 pm    Post subject: Reply with quote
How are you guys handling secondary oil coolers?
Bashr52
Bashr52 is offline
PostPosted: Fri Jun 22, 2012 4:32 am    Post subject: Reply with quote
If you go with the DTM from jake as shown above, you will not need one.
DougD
DougD is offline
PostPosted: Fri Jun 22, 2012 7:02 am    Post subject: Reply with quote
I am amazed that the belt doesnt slip off.. it looks like it wants to slide off the sides. Is there a retainer of some kind that prevents it from doing that?
Solomon Grundy
PostPosted: Fri Jun 22, 2012 9:00 am    Post subject: Reply with quote
From driving these Things for years, and now on my 3 engine, I feel that even stock under normal conditions they all run on the hot side. Getting enough air to the back end is hard, just like a Bus.
I have no extra oil cooling system on my DTM type 4 with a stock rebuilt 2000 cc ’76 bus engine and it is great for daily driving, but I live in the Silicon Valley and the weather is nice, normally less than 85 degrees. When I drive across central CA. on the flat lands in 100 + degrees weather it is okay; oil temp runs around 225. Mind you the setup sheetmetal and all is not as tight as a stock engine. The heads temp may be running okay because of the DTM setup, but I do not have a head temp sensor yet.
I just made a run to the classic and pushed the car over a notorious hill into L.A. called the grapevine or Tejon Pass. http://en.wikipedia.org/wiki/Grapevine,_California
http://en.wikipedia.org/wiki/Tejon_Pass
Doing that extreme driving in 100+ degrees it takes a good 30 min. to get over the mountain. It was at 240 on the oil temp at the top of the hill and I forced myself to drive at 45 MPH up the long steep grade with a loaded car. I know some of the other bus folks did it at 35 MPH to avoid overheating. If you take your time and don’t push the engine it is fine. For something like this I will need to add an extra remote oil cooler in the future for pulling a trailer and other extreme driving situations in 100 + degree weather. Most of the type 4 folks I know have extra coolers. I think I am the only one that does not but I wanted to test it and see what I could get away with. In situations like that if you drive it like a normal air-cooled VW you will be fine.
But so far 2 years into this new DTM type 4 set up and I am relatively please. I hope when I run this engine out I can do it again. The other bonus with the type 4 is from what I understand is, if treated well, you will normally get more miles out of those engines then the normal type 1. Hopefully I can get a good 150,000 miles out of this rebuild. But we shall see.
- Dr. Seuss
| _______
| _\_\_|_/_/_
| |O||_4_||O|
nikita
nikita is offline
PostPosted: Fri Jun 22, 2012 4:25 pm    Post subject: Reply with quote
Ive never seen the 914 setup before. A similar belt routing and fan setup was used on the Corvair. 2 million of them were built and belt issues were rare.
mattt
mattt is offline
PostPosted: Fri Jun 22, 2012 4:59 pm    Post subject: Reply with quote
That's not a stock 914 setup with the horizontal fan. That appears to be some other aftermarket or homebuilt conversion. The 914 cooling system is just like a bus cooling system save a few minor differences in tin and random things.
T4 is nice....I have one in my Thing too. But keeping it cool is always the chanllenge. HP = HEAT. Bump up the HP and you have no choice but to add aux cooler. I've noticed with mine that oil temp is VERY dependent on speed/RPMs. Higher speed & RPMs = more heat. Keep it at granny speed and no heat problems....granted my Thing has a few other mod's working against it staying frigid. YMMV
sixty9fasty
PostPosted: Fri Jun 22, 2012 5:13 pm    Post subject: Reply with quote
Yes, this motor is far from stock... kinda, it was originally built by Lukes & Shoreman back in the mid 80's.
The alt/fan is a 911 that has been laid horizontally, the only issue I have with the belt is that it does rub on the case in one spot, and I threw it once or twice, ended up going to a slightly narrower and shorter belt to sit down in the 90deg pulleys(might be the cause of the rubbing as it did not show signs of this with the old belt size IIRC)
The other oddities of the motor are the 912 style lifters that were fitted with brass sleeves, and the 928 rods(much longer than stock, with an oiling hole drilled through to the wrist pin), to fit the rod they machined two blocks of aluminum about 3/4" thick for between the case and barrels.
The rod journals were also offest ground 2mm as the rods are slightly smaller than stock type4... About all I know about the differences...
My Oval Project
ajbuchok
ajbuchok is offline
PostPosted: Sat Jun 23, 2012 1:22 pm    Post subject: Reply with quote
Do you guys have any tips on keeping a type 4 cooler? I was thinking about running a second oil cooler above the transaxle and maybe open up some breather holes behing my rear license plate.
BL3Manx
BL3Manx is offline
PostPosted: Sat Jun 23, 2012 4:09 pm    Post subject: Reply with quote
Actually flipped belts were practically routine. However over the past 40 plus years they've developed fixes that make it less problematic. Clarks Corvairs has specially designed V belts, guides, tensioners, pulleys and the later magnesium fans all help.
These guys do the horizontal 911 cooling system
http://www.riechertmotorentechnik.de/en/coolingt4.htm
Tangerine Racing does a Corvair fan based system for the Type 4
http://www.tangerineracing.com/Engine.htm#Horizontal%20Cooling%20Fan%20Conversion
candymustang66
candymustang66 is offline
PostPosted: Sat Jun 30, 2012 5:46 pm    Post subject: Reply with quote
were is GI joe. this mod is so cool.
does he sell a kit?
thanks,,
68T1
close to for sale time. very close. by summers end.
just finished front end rebuild and Ghia discs (nice)
Goto page 1, 2  Next
