15" or 16" bead lock rims for Syncro
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
insyncro Premium Member
insyncro is offline
PostPosted: Fri Jun 08, 2012 7:12 am    Post subject: 15" or 16" bead lock rims for Syncro Reply with quote
I am in the process of building a 16" Syncro for offroading.
Does anyone have links to companies that will produce alloy or steel, 15 or 16" rims, with my choice of ET, 5x112 and offer bolt on bead lockers???
Weld didnt have anything that would fit.
Would sandrail Guys use 5x112 mounting?
Not interested in adapters or spacers for this application.
TIA.
Christopher Schimke Premium Member
PostPosted: Fri Jun 08, 2012 7:38 am    Post subject: Reply with quote
Diamond racing will pretty much build whatever you want:
http://www.diamondracingwheels.com/drwcustom.html
Christopher
*Custom wheel hardware for Audi/VW and Mercedes wheels - Urethane Suspension Bushings*
View user's profile Send private message Facebook Classifieds Feedback
GoWestyYoungMan
GoWestyYoungMan is offline
PostPosted: Fri Jun 08, 2012 7:42 am    Post subject: Reply with quote
Tomorrow, I am going to a 4x4 products sales event in Ontario,Ca with all of the top manufacturer's in attendance so I will ask the wheel mfg reps.
insyncro is offline
PostPosted: Fri Jun 08, 2012 7:58 am    Post subject: Reply with quote
Thanks Chris.
I will call you to discuss all of fitment parameters soon.
insyncro is offline
PostPosted: Fri Jun 08, 2012 8:00 am    Post subject: Reply with quote
Thanks Craig.
Any info would be appreciated.
Contact names and numbers from companies who can offer this service would be ideal.
I will gladly post my experiences with them and try to drive some business there way.
Lets talk over the weekend and get your parts order finished up.
D
GoWestyYoungMan
PostPosted: Fri Jun 08, 2012 8:13 am    Post subject: Reply with quote
Okay.
I will collect their basic flyers and mail you the ones saying they can make them.
I will call you afer the event.
Craig
danfromsyr
danfromsyr is offline
PostPosted: Fri Jun 08, 2012 8:20 am    Post subject: Reply with quote
Give the fine folk at Stockton Wheel a call.
they do custom wheel work for decades.
http://www.stocktonwheel.com/
VW Club of Central New York SPRING VW GTG
Upstate NY 2013 VWCCNY events
NY State VW Camping 2013 season events
vw7266
vw7266 is offline
PostPosted: Fri Jun 08, 2012 8:21 am    Post subject: Reply with quote
Ive been wanting to buy a set of beadlocks to have tig'd to my clk wheels to convert them
http://www.omfperformance.com/beadlocked_conversions.php
aka: Brad
hans j
hans j is offline
PostPosted: Fri Jun 08, 2012 8:53 am    Post subject: Reply with quote
I looked into it when I was thinking about wheels and found some interesting stuff. I would have probably gone with a weld on ring to go on some stockish steel wheels. [ur]http://www.ballisticfabrication.com/-Ballistic-Steel-Beadlock_p_1589.html[/url] http://www.atozfabrication.com/store/Weld-On-Bead-Lock-Kits.html
I would be concerned about the Diamond Racing wheels on a vanagon. My experience with them is they like to taco VERY easy, at least the race car versions.
I just went with a eurovan 15" steel wheel. They are as thick or thicker than the vanagon wheels so I am not worried about load rating or tacoing them.
Balancing the wheels was also a concern of mine. I still drive mine to the 'off-road' and that can mean 3-4 hours on the highway. Some use water or bb pellets inside the tire to balance it.
In the end, after discussing it at length with my 4x4 coworker, I decided it wasn't for me. I feel there isn't enough articulation to do anything that warrants bead locks and with the BFG AT KO tires, I can air down as far as I need to get out of anything.
It would be cool to see done though, definitely post pics if you do it!
1986 Canadian Syncro Westy TDI - 1981 VW Caddy ABA - 1980 VW Caddy EV - 2001 Audi S4 - 1978 VW Rabbit - 1973 VW T-181
GoWestyYoungMan
PostPosted: Sat Jun 09, 2012 6:17 pm    Post subject: Reply with quote
There is just one lead after talking to 4x4 wheel manufacturers at the Ontario Convention Ctr today, but it is very promising.
http://www.methodracewheels.com/products-race/
The Buggy 101 Bead-lock and no bead-lock versions don't have the 5x112 hole pattern, but everything else is very close to what we are seeking...for the 1st time.
The rep was too busy to discuss in depth so we started an email exchange at his request.
Will post the outcome.
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Jun 09, 2012 11:21 pm    Post subject: Reply with quote
Another for Stockton Wheel in California.
DougM
Two fully locked 80 Series LandCruisers. 2013 Subaru Impreza boxer. 1990 Audi 90 Quattro 20V
SyncroGhia
SyncroGhia is offline
PostPosted: Sun Jun 10, 2012 3:39 am    Post subject: Reply with quote
This is something that I've been looking into since I started designing the Lightweight.
My issue is slightly different in that I'm limited to the Audi S4 Fuchs forged wheels as they're about the only wheels which will fit over the larger Porsche brakes that I'm running.
As such, my options are looking for an Aluminium beadlock kit for the wheels I have...
... or use the internal beadlock inner tubes which are around now.
Staun Beadlocks
http://www.innerairlock.com/ is another
There is one other thought and that's to use two piece wheels and have an internal frame that sits inside the tyre and is compressed between the wheel halves, beads and inside of the wheel rims holding everything in place.
There are positives and negatives to all of these.
Beadlocks
1) Weld on beadlocks.
Negatives
Unless you weld on beadlocks to the inner and outer of each wheel (lots and lots of work), you'll still be able to pull the tyre off the side that you haven't fitted one to.
Weight, add big chunks of metal to your wheels really adds weight and mass to your wheels. This not only slows your vehicle down but puts a lot more stress on the drivetrain.
Expensive in comparrison to buying wheels already fitted with beadlocks.
Positives
Much stronger wheels so you're unlikely to bend one.
Look cool! (ok they look cool to me!)
You get to chose your wheel style and have individual wheels.
Staun and Inner Air beadlocks.
Negatives
Expensive. For this price, you can buy wheels or kits to convert your wheels.
Changing the tyres is a lot more work.
Doesn't strengthen your wheels and with such low pressures, you're more likely to bend your rims.
Positives
You can't see them so they look like stock wheels
Weight, you're adding a piece of canvas and a valve...
Two Piece wheels
Negatives
Expensive
Hard to find
Positives
Doesn't add lots of weight to the wheels
You can't see them so they look stock
MG
1989 Syncro 16 S6 Westy Limey
1991 Syncro Lightweight SWB
1989 S8 Bluestar
1990 Tristar
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
GoWestyYoungMan
PostPosted: Sun Jun 10, 2012 9:03 am    Post subject: Reply with quote
SyncroGhia,
What is the load rating of the Audi wheel above?
It looks too weak for off-roading, I need the rear wheels 3000lbs max load minimum for my near future project which will involve towing besides the normal usage.
Thanks,
Craig
Now I understand your project is lightweight.
Last edited by GoWestyYoungMan on Sun Jun 10, 2012 12:18 pm; edited 2 times in total
insyncro is offline
PostPosted: Sun Jun 10, 2012 9:08 am    Post subject: Reply with quote
Thanks for all the great leads.
insyncro is offline
PostPosted: Sun Jun 10, 2012 9:10 am    Post subject: Reply with quote
My concern will the internal beadlockers is weight.
Derek Drew uses them with his CV wheels and 30.5" BFGs.....each wheel weighs 70+lbs Shocked
insyncro is offline
PostPosted: Sun Jun 10, 2012 4:25 pm    Post subject: Reply with quote
So Im told the internal units weigh 5lbs.
The BFGs in combination with the CV alloys, the rest.
So still focussing on weight....how do we all feel about modifying CLKs with an external lock or using the internals with them?
Very light wheel, for sure
I have tons of them, but figured they were a better crossover or stictly pavement alloy.
My concerns are with the lug nut mating area of the alloy...very thin for heavy duty Syncro offroad abuse.
I have planned on using a steel rim, but maybe someone can point me in a direction of strength...but not adding excess pounds.
SyncroGhia
PostPosted: Mon Jun 11, 2012 11:48 am    Post subject: Reply with quote
If you find some aluminium weld-on 16 inch beadlock kits at a good price, please let me know as I may buy some with you.
Thanks
MG
1989 S8 Bluestar
1990 Tristar
insyncro is offline
PostPosted: Mon Jun 11, 2012 3:35 pm    Post subject: Reply with quote
Thanks
MG
MG,
I and a few others are working on this and will update this thread once we find a suitable part.
dylan
SyncroGhia
PostPosted: Mon Jun 11, 2012 11:15 pm    Post subject: Reply with quote
SyncroGhia,
Thanks,
Craig
I haven't managed to find that out yet, but as they're forged and made by Fuchs, I'm expecting that they will probably be more than strong enough.
MG
1989 S8 Bluestar
1990 Tristar
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
