Front Floor rust repair question
AJack500
AJack500 is offline
PostPosted: Fri Jun 08, 2012 8:42 pm    Post subject: Front Floor rust repair question Reply with quote
How would i repair this portion of the front floor?
Im trying to avoid removing the heater tube as i heard its a real pain. Both sides of the floor are real bad too.
EDragnDean Premium Member
EDragnDean is offline
PostPosted: Fri Jun 08, 2012 9:17 pm    Post subject: Reply with quote
You can get a center section repair from WW. However if you also need the outside, you would be better off replacing in a single piece.
63 Double Cab http://www.franklinsvwwerks.com/phpbb/viewtopic.php?f=12&t=14842
66 Bus http://www.franklinsvwwerks.com/phpbb/viewtopic.php?t=8919
NAES
NAES is offline
PostPosted: Fri Jun 08, 2012 9:19 pm    Post subject: Reply with quote
If the center is that crusty i would imagine the outers are as well. Take a peek underneath to see if they are stout enough.
If it is you can either cut the bad sections out and replace with donor metal splitting it down the middle avoiding the heater tube or remove the heater tube itself. Its a pia but not impossible by any stretch of the imagination
BDM Hit Man.
BOW diehard.
SBS #00
Looking for
OG paint Mango drivers door
60 Standard build
