bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 465 Location: Los Angeles, CA 90016
Posted: Sun Jun 10, 2012 10:50 am Post subject: Cast 82mm Crank |
I've owned an 82mm Cast Porsche journal crank that I've been planning to use for a 2110. It was turned to .020 and wrapped up a few years ago. I located a set of Porsche rods and had them rebuilt so the set is ready to go.
I chose an Engle 120 because its' powerband peak is the same or close to the max rpm limits of the crank. I also am using a Bosch SVDA with a 5400 RPM rotor so over-revving will not be an issue.
Question is has anyone ever heard of or had a cast crank problem before? _________________ No matter how many "fads" that cal-lookers go through; scallops, bright colors, metallics, white fender seals on colored cars, one off custom wheels, color matched wheels, fully chromed engine compartments, slammed rear ends, super narrowed suspension, etc, nothing beats a traditional, functional, performance first looker. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7557 Location: Whittier,CA
Posted: Sun Jun 10, 2012 11:33 am Post subject: |
My opinion......... Take your 82 cast crank, sell it, get what you can for it and buy a quality DPR crank. But don't mind my opinion (I'm a cast crank Haterrrr ) you'll get plenty of guys here to tell you cast cranks are great, go right ahead and use it.  _________________
| Mitey62 wrote: | | Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: | JB weld the case halves....that'll keep the fretting to a minimum.  |
ALB Samba Member
Joined: August 05, 2008 Posts: 2635 Location: beautiful suburban .....
Posted: Sun Jun 10, 2012 11:41 am Post subject: |
If you're going to put a 5400 rpm rotor in it, why not use a W110 to more closely match that rpm ceiling? Why have something that will rev to 6000 rpm if you're not going to use it? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Slalombuggy- Now I understand my trust issues... |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 8041 Location: OKLAHOMA
Posted: Sun Jun 10, 2012 2:28 pm Post subject: |
I've had a 78 cast crank engine and broke it at the drags. I've had two 69 cast crank engines both with less then 100 HP and neither have had any problems after hundreds of drag strip passes. RPM is not what is going to kill your cast crank. HP and torque will. You can turn it to 8000 RPM, you just can't use in an an engine that makes over 100 HP. I totally agree with darth, sell the cast crank and rods and get a new forged crank and H beam rods. The China junk today is still good to 200 HP without any problems.
Have you see the price of Porsche rod bearings? There is a reason nobody uses them any more. _________________ 2010 Sportsman ET Champion - Mid-America Dragway - Arkansas City, KS
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
