Clutch Pedal to floor - cable not broke
VAVWFAN
VAVWFAN is offline
PostPosted: Mon Jun 11, 2012 7:53 am    Post subject: Clutch Pedal to floor - cable not broke Reply with quote
OK, 69 Westy was shifting normal 1st -thru- 3rd, then went to go into 4th, and pedal went to the floor, with little restriction. I was less than a mile from home so I turned around and parked it. "Cable I thought!"
I checked the cable run yesterday and it's in-tact, and moving the shift lever on the tranny. I tried adjusting but no help.
I'm assuming the problem is in the throw-out bearing area, but trying to determine most likely culprit (so I can preorder parts).
There was no noise, associated with failure, just ineffective pedal movement.
Can anyone suggest "possibilities" or other things I should look at before I pull engine????
Thanks
LeeE
LeeE is offline
PostPosted: Mon Jun 11, 2012 8:33 am    Post subject: Reply with quote
I had (maybe) the same thing happen with my '69 years ago. The throw-out bearing clips had come loose, weren't installed properly. Hopefully that's all that has happened to you.
It's an easy fix but unfortunately does require pulling the engine, maybe not all the way out but at least back far enough to be able to get at the clips.
1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp
VAVWFAN
VAVWFAN is offline
PostPosted: Mon Jun 11, 2012 9:06 am    Post subject: Reply with quote
Thanks - gotta get another engine anyways, though current is OK for around town. Time to kill two birds with one stone it seems!
If it weren't for "last minutes;" -- nothing would ever get done!
minispdrcr
minispdrcr is offline
PostPosted: Mon Jun 11, 2012 9:18 am    Post subject: Reply with quote
There was just a thread like that not long ago. The shifter arm on the transmission had cracked and was not moving the mechanism.
http://www.thesamba.com/vw/forum/viewtopic.php?t=514196&highlight=clutch+pedal
Marcin P.
1969 Westfalia Weekender Edition
1973 Morris Mini 1300 Super
1998 Audi A6
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
busdaddy
busdaddy is offline
PostPosted: Mon Jun 11, 2012 9:36 am    Post subject: Reply with quote
Try another cable, they can break internally and appear fine outwardly. If it doesn't make a difference keep the old one as a spare. Lay the 2 side by side as well for a length comparison.
Wanted, 68-73 westy OG plaid curtains, singles OK.
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Mon Jun 11, 2012 9:39 am    Post subject: Reply with quote
most commonly the clevis pin breaks.
did you look @ the cable end under the pedal?
'71 - 1600DP, C/W - 32NDIX - o19
VW Logo Air Cooleds Only VW Logo
BAY PRIDE
VAVWFAN
VAVWFAN is offline
PostPosted: Mon Jun 11, 2012 9:56 am    Post subject: Reply with quote
Well, my grandson was pushing the pedal, and the arm was moving what appeared to be full trave. I looked at that clevis fitting being cracked and it isn't, but as I was moving the arm by had, I heard a matelic "tinkle" inside the bell housing, so my guess is the T/O bearing clips - "duogh!"
That said; I want to get something other than a floor jack to pull the engine this time. Does anyone have recomendations?? I've heard motorcycle stands work, but dunno?!? I've don't VW engines about 9 times in my life, and while relitively easy, I'm not the most experienced in this forum, but as I advance in age, I sure wouldn't mind making the job as easy as possible...
Suggestions kindly requested!!
drober23
drober23 is offline
PostPosted: Mon Jun 11, 2012 10:23 am    Post subject: Reply with quote
The Motorcycle jacks work fine. For a '69, a good floor jack is plenty though.
If you use a motorcycle jack, some people put a piece of wood across the two "arms" for better stability.
DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey
aeromech
aeromech is offline
PostPosted: Mon Jun 11, 2012 1:51 pm    Post subject: Reply with quote
Your shift fork may be broken inside the bell housing. So, you say you're getting full travel on the arm but the pedal went to the floor? Only way to know is to pull the engine.
Jacks:
I use floor jacks and motorcycle jacks to pull bus engines. The problem with the motorcycle jack is that it doesn't go up as high as the floor jack. So, raise the rear of the bus up enough to get the rear wheels off. Then remove the rear bumper. When you get the engine onto the motorcycle jack (and plywood platform) you should be able to slide it right out the back.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Type 2 1971 (2 ea.) 1978
VW Jetta
VW Passat
ccpalmer Premium Member
ccpalmer is offline
PostPosted: Tue Jun 12, 2012 4:53 am    Post subject: Reply with quote
Jacks:
I use a motorcycle/atv jack on my '71, and it goes up plenty high.
Why are you saying to remove the rear wheels?
'71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com
ccpalmer is offline
PostPosted: Wed Jun 13, 2012 5:18 am    Post subject: Reply with quote
ccpalmer wrote:
Jacks:
Hmm; was cruising old posts and found this one - now I can see how it might be easier to jack the Bus up even when removing T1 engines... love thesamba!
http://www.thesamba.com/vw/forum/viewtopic.php?t=103843
'71 Westy
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com
aeromech
aeromech is offline
PostPosted: Wed Jun 13, 2012 6:59 am    Post subject: Reply with quote
I use an impact gun and removing the rear wheels is really easy for me. Once off, it allows easier access for me to reach things like the fuel line, clutch cable, and heater box cables during an engine swap. I've pulled engines while leaving the bumper in place too but found that being able to slide the engine out the back is easier than raising the bus high enough for the fan shround to clear the bumper. The bumper comes off easiely using an impact gun especially if there are no splash guards to disconnect (which is usually the case).
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VAVWFAN
VAVWFAN is offline
PostPosted: Wed Jun 13, 2012 10:34 am    Post subject: Reply with quote
Gary; Haven't pulled engine, nor looked into the shift fork replacement,,,,,will be evaluated soon.
However, if the fork is broken, is it a tough job to replace, or pretty straight-forward??
Thanks again!
aeromech
aeromech is offline
PostPosted: Wed Jun 13, 2012 11:20 am    Post subject: Reply with quote
Thanks again!
Pretty straight forward. I think in all my years of working on VW's I've only had one break on me.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sellitsoon
sellitsoon is offline
PostPosted: Thu Jun 14, 2012 3:01 am    Post subject: Reply with quote
I put a wooden cross brace on a small furniture dolly and used a regular floor jack. Best part is that the engine will be on wheels so it's easy to wheel around the garage nice it's out.
Tom Powell
Tom Powell is offline
PostPosted: Thu Jun 14, 2012 7:41 am    Post subject: Reply with quote
Here's a homemade dolly to wheel the engine around the garage. I've used it with wood blocks and wedges to pull and replace the engine, but a motorcycle jack would be far better and easier. There are big cracks in my working surface and the two large wheels did not get stuck in the cracks like a floor jack did.
Aloha
tp
pieterotto
pieterotto is offline
PostPosted: Sat Jun 16, 2012 9:21 am    Post subject: T/O Frok Reply with quote
hi there, i am busy building up a beach buggy.
i am nearly done and just finished off the last wiring on the lights.
i took the buggy for a test drive and the same thing hapenned to me - no clutch pressure and a funny noise came from the bell housing area.
OK, I pulled the engine and found it to be the throwout fork that broke and the throwout bearing was rotating freely around the shaft - hence the funny noise.
OK, i got a new fork, but struggled the whole day today to get the old fork out, and still struggling.......
I eventually discovered the circlips and removed them. Then I had to grind off the lever where the clutch cable fits to. Now the fork is moving freely from left to right and the lever where the clutch cable fit to is removed.
Now, how do I get the fork out of the bell housing?
VAVWFAN
VAVWFAN is offline
PostPosted: Sat Jun 16, 2012 3:36 pm    Post subject: Reply with quote
Well, I finally pulled engine and found the T/O bearing on the shaft, and the two little clips sitting in the bottom of the bellhousing.
The shaft and forks are OK, and I don't see what caused this, except perhaps the little clips vibrating loose.
Curious if a looser than normal clutch adjustment could've caused this? T/O bearing had about 1,100 miles since installed. Clutch and transmission was fine prior
