volkswagen4life Samba Member
Joined: July 31, 2010 Posts: 116 Location: Walla Walla, Wa
Posted: Thu Jun 14, 2012 1:40 am Post subject: Type 3 ignition troubles |
I have a 70 square that ran home fine than the next day didn't want to start we tracked it down to the thing on the side of the dizzy (with the green wire sorry can't remember what it's called) so took for ever finding that but finally got it put it together and still couldn't get it to start. we got it to push start and it ran terrible missing popping and not idling. Any thoughts? _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Slow 1200 Samba Member
Posted: Thu Jun 14, 2012 6:18 am Post subject: |
| have you checked point gap? |
Posted: Thu Jun 14, 2012 12:35 pm Post subject: |
yes we have checked the point gap the cap and roter the all seem to be fine we even check the plugs we are getting spark through them. when we had the dizzy out though we spread some lubricant because the vacuum advance was sticking due to rust _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 2142 Location: Southern AB
Posted: Thu Jun 14, 2012 2:48 pm Post subject: |
why would the timing be off we didn't adjust the ring around the base of the dizzy _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
EverettB  Administrator
Joined: April 11, 2000 Posts: 42221 Location: Phoenix, AZ
Posted: Thu Jun 14, 2012 3:24 pm Post subject: |
Green wire thingy = condensor.
If you removed the distributor by undoing the 13mm mounting bolt and removing the entire thing, bracket and all, the timing should be unchanged but I always check it anyway... _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
"Water is the only drink for a wise man" | "Communication prevents complaints" |
Posted: Thu Jun 14, 2012 3:25 pm Post subject: |
| volkswagen4life wrote: |
| yes we have checked the point gap the cap and roter the all seem to be fine we even check the plugs we are getting spark through them. when we had the dizzy out though we spread some lubricant because the vacuum advance was sticking due to rust |
Where and what did you lubricate? _________________ How to: Post Photos | Search
the base that is moved by the arm on the vacuum advance _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Posted: Fri Jun 15, 2012 2:03 pm Post subject: |
okay so finally got some time to mess around with it spread some starting fluid in her and got nothing but back fire so I took the dizzy back off and turned the roater 180 and spread some more fluid and got her to start and run for a very short while. then went back to check and it smelled hella of gass over the engine could it be flooding itself out or a leaking line or something _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Posted: Sat Jun 16, 2012 10:14 am Post subject: |
okay so I found and fix leak fuel line and now I can still only get it to start do I have to prime the fuel system some how? _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12526 Location: Eugene, OR
Posted: Sat Jun 16, 2012 10:49 am Post subject: |
If your spark plugs are wet now, then fuel probably isn't the problem but you can spray some gas in the throttle body with a turkey baster & try it. Can't hurt anything except get your spark plugs wet. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
Posted: Sat Jun 16, 2012 3:31 pm Post subject: |
What a freaking mess I fixed a cracked fuel line that had a slow drip and another burst (non fuel injection rated line) so fixed that and another line starts to leak I am just ganna have to chase it all the way around the car notes to anyone else always use fuel injected line when needed _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Posted: Sat Jun 16, 2012 7:10 pm Post subject: |
In these systems what triggers the fuel injectors to shoot and how do u check to see if its still good _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2186 Location: Colorado Springs
Posted: Sun Jun 17, 2012 7:47 am Post subject: |
Trigger points in the bottom of the distributor.
Sounds like you need to replace all of your fuel lines _________________
| iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
| Chickengeorge's wife wrote: |
| bing chow ching fong fang T.J. fang ching dow fong |
Posted: Sun Jun 17, 2012 10:16 am Post subject: |
Are those trigger points in cased in the distrubutor or under the cap? _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 10698 Location: Kimball, Mi
Posted: Sun Jun 17, 2012 3:16 pm Post subject: |
I checked that connection the three prongs going to my dizzy they seem nice and tight but there is a four prong that isn't connected to anything and I can't find where that might go. There is also one single white or maybe brown wire on the opposite side of the in take not hooked to anything. If I take the power off of the injectors and turn the engine would a volt meter catch a charger? If so how much of one should it pick up _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Posted: Sun Jun 17, 2012 3:18 pm Post subject: |
By the way I fixed the fuel leaks and in my other car 91 firebird the fuel pump builds pressure than stops but in my type 3 the pump is always going as long as the igniton is on is that okay? _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Posted: Sun Jun 17, 2012 4:00 pm Post subject: |
The Type 3 fuel pump should shut off after a couple seconds when it reaches 30lbs pressure if the car doesn't start. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
Posted: Sun Jun 17, 2012 4:09 pm Post subject: |
Only 30 lbs... I was told it was sapose to do 90 arnt there pressure regulators that keep it down there _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
