karu Samba Member
Joined: November 11, 2008 Posts: 229 Location: Cross Lanes, WV
Posted: Sat Jul 26, 2014 4:18 pm Post subject: |
wvbowtieman wrote: |
No.... that is not right.
Just flip the seal over and install like you did the first time. |
Thanks Dave!!!! |
wvbowtieman Samba Member
Posted: Sat Jul 26, 2014 4:23 pm Post subject: |
I always put a little Permatex sealer around the outside lip just for a little extra protection. |
karu Samba Member
Posted: Sat Jul 26, 2014 4:32 pm Post subject: |
Thanks!!!!
It sure helps to see a picture. |
karu Samba Member
Posted: Sat Jul 26, 2014 6:44 pm Post subject: |
Last summer I bought this mini lathe from harbor freight.
http://www.harborfreight.com/7-inch-x-10-inch-precision-mini-lathe-93212.html
It is extremely basic then again I only paid 375 (used a 25% off coupon). Today I used it to make a .25" thick disk to drive the seals. It took me an embarrassingly long time to get it but takes about 30 seconds to do the job; that is, if you put the seal right!!!
Here are some pics.
Posted: Sat Jul 26, 2014 8:30 pm Post subject: |
Nice work on the seal disk. My tool box is full of home made "SPECIALTY" tools...now I know who to call when I need one of those... |
bruces Samba Member
Joined: October 12, 2009 Posts: 221 Location: sudbury ontario
Posted: Sat Jul 26, 2014 9:21 pm Post subject: |
A hockey puck makes an excellent seal driver . |
karu Samba Member
Posted: Sun Jul 27, 2014 4:49 am Post subject: |
Any time! |
karu Samba Member
Posted: Sun Jul 27, 2014 5:02 am Post subject: |
bruces wrote: |
Do the dimensions work? Diameter has to be somewhere around 62 mm (if I remember correctly) because the seal is slightly recessed. |
karu Samba Member
Posted: Thu Aug 07, 2014 7:55 pm Post subject: |
Some more work is done. It is slow going as I just want to make damn sure that no nut or bolt comes off while I am driving .
I am also using permatex blue with fasteners.
Had little bit of trouble with the rear right caliper mount. It was rubbing against the disk. A little hand grinding took care of it.
Nice to see all the shiny parts going in.
For comparison, this is where I started.
karu Samba Member
Posted: Thu Aug 07, 2014 7:58 pm Post subject: |
One quick question. Can someone tell me what bolt size is used for rear trans mount to the cross member?
I see that I could possibly pick something which fits the holes with the right steel grade but since this is going to carry lot of weight, I just want to get what vw used for this. |
joescoolcustoms Samba Member
Looks like someone is motivated.
Nice work! Keep chopping at it, eventually that tree will fall. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
karu Samba Member
Posted: Thu Aug 07, 2014 7:59 pm Post subject: |
Thanks Joe!!
Your beautiful work on the puzzle buggy and of course your trip really motivated me. |
Posted: Thu Aug 07, 2014 8:02 pm Post subject: |
karu wrote: |
Are you referring to the two large bolts that hold the rear of the transaxle to the frame horns? _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
karu Samba Member
Posted: Thu Aug 07, 2014 8:14 pm Post subject: |
M8 X 1.5 Grade 8.8
About 20 to 22 mm total length _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
karu Samba Member
Posted: Thu Aug 07, 2014 8:16 pm Post subject: |
joescoolcustoms wrote: |
M8 X 1.5 Grade 8.8
About 20 to 22 mm total length |
Thanks Joe!! |
truckdude Samba Member
Joined: May 01, 2014 Posts: 148 Location: Beverly Hills baybee
Posted: Thu Aug 07, 2014 10:25 pm Post subject: |
Chassis looks great. Interesting to see the differences and similarities between your more modern IRS and my swingaxle. |
karu Samba Member
Posted: Fri Aug 08, 2014 4:48 am Post subject: |
truckdude wrote: |
Chassis looks great. |
Thanks truckdude. Looks like you are way ahead of me. I still need to prep the body which will be quite a job. |
karu Samba Member
Posted: Mon Aug 18, 2014 6:29 pm Post subject: |
I have yet another question. Here are pictures of the parts of the steering column I got with the chassis. An adapter with 9 holes came with it (pictured) and also a matching formuling brand steering wheel came with it.
I am not planning on using the stock turn signals. Can I skip the part marked with the red arrow (assuming I can still use some other parts!!!)
In the last picture, arrow shows a place where the steering rod is damaged. Does the damage make it dangerous to use? |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Tue Aug 19, 2014 4:45 am Post subject: |
Looks like someone 'fixed' this column by welding in a piece of tubing inside of the crash crumple area. Looks like a reasonably welded fix from what I can see, check it thoroughly. It certainly won't crumple in a crash anymore, I take a very small comfort knowing I have a crumple column. Not sure the carpet bushings inspire a lot of confidence. If you are not using the turn signal with the column you will need a bearing surface to replace it. You might be better off finding a replacement column that hits your mark better than this one. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
