Christopholi Samba Member
Joined: May 16, 2011 Posts: 234 Location: Vancouver, BC, CANADA
Posted: Thu Jun 14, 2012 3:31 pm Post subject: Fog lights on fibreglass bumpers |
Hi all,
I would liket to mount fog lights on my van, but I have fibreglass bumpers. I am curious what others have done to mount their's (other than getting steel bumpers ). Do you find them shaky? Has there been any damage to the fibreglass?
Thanks in advance,
Chris. _________________ 1988 Tintop Wolfsburg Special Edition - "Meatloaf"
RMW 2.5 Subaru, SubaruGears 5MT 4.44 w/LSD, Coast Mountain Hightop |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6246 Location: Portland OR
Posted: Thu Jun 14, 2012 3:43 pm Post subject: |
I mounted them right on the bumper and never had any problem. The bumper is about 1/4" thick and plenty strong for fog lights.
_________________ 89 Westy 2.1 Auto |
kamzcab86 Samba Moderator
Posted: Thu Jun 14, 2012 3:45 pm Post subject: Re: Fog lights on fibreglass bumpers |
Christopholi wrote: |
I am curious what others have done to mount their's (other than getting steel bumpers ). Do you find them shaky? Has there been any damage to the fibreglass? |
Second owner drilled a couple of holes according to installation instructions (included, if you can believe, in the folder of paperwork from the 3rd owner). The only thing I didn't care for was the way the wires had been run (under the front spoiler), which I promptly changed by re-routing them through the lower grille.
Do you find them shaky? |
No.
No.
Been installed since about 2001:
_________________ ~Kamz
2016 Golf GTI S
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Thu Jun 14, 2012 4:22 pm Post subject: |
There is also a bracket available in the UK that copies an
oem bracket. It's a metal tab that bolts under the bumper cover
on the metal frame. A member on here documented it and
had some of their own made locally. There is a couple factory
holes under your bumper they mount to. I couldnt find the
post on my iPhone with a quick search but it's here somewhere. _________________ Bill M
87 Westy |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Thu Jun 14, 2012 4:35 pm Post subject: |
Bill is correct,
It's a triangle of 3 holes visible once the fibreglass bumper cover is removed.
There is a drawing of the bracket on Vagcat under electrical accessories/halogen fog lamp. It is referred to as "retainer". your bumper covers are referred to as "carat trim"
You could Probably bend a pair up in a vise with some 1/8 steel strap. There is an example somewhere here in the posts, keep searching and you will find....
Good luck. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Posted: Thu Jun 14, 2012 4:46 pm Post subject: |
Here's the post on the brackets, but you can also do it without. They work with steel bumpers but I don't know how they'd work with the fiberglass bumpers.
http://www.thesamba.com/vw/forum/viewtopic.php?t=377713 _________________ 89 Westy 2.1 Auto
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Thu Jun 14, 2012 4:47 pm Post subject: |
The one on the bottom right is for fiberglass bumpers. Image borrowed from ragnarhairybreeks.
Posted: Thu Jun 14, 2012 10:49 pm Post subject: |
Thanks guys for all the great info. I feel a lot more confident about mounting something now than before. That diagram of the bracket looks quite do-able.
Kamz, would you happen to have a scan of those install instructions, as well?
Thanks again, all.
BillM Samba Member
Posted: Fri Jun 15, 2012 6:13 am Post subject: |
Chris
Don't forget that there is a factory switch that fits up on your
cluster and I would also use a relay. I had a Vanagon a few
years back that came from Europe. I bought it crashed for
parts. It had fogs that were either dealer installed using factory
parts or were factory installed. I kick myself in the ass for
not documenting the wire harness but it used a relay. Just
something to consider. _________________ Bill M
87 Westy |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Fri Jun 15, 2012 8:07 am Post subject: |
factory wiring for fog light did include relay, but (assuming I have read diagram correctly) the relay did not protect foglight switch.
My rambling blog post explaining more:
http://shufti.wordpress.com/2010/01/21/fogaux-lights-installed/
The stock wiring set up
my wiring set up (note the diagram for the fog light switch is not correct in that the 3 position switch does not have the internals wired as shown, but the diagram works for the purpose now.)
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
zippyslug31 Samba Member
Joined: July 20, 2007 Posts: 799 Location: Central Oregon
Posted: Fri Jun 15, 2012 8:54 am Post subject: |
I used to have them bolted straight on the bumper. Worked fair but they were a little wiggly on rough roads, the light cast was a little too low, and if a light took a direct hit the force would be transmitted directly to the fiberglass.
While I was doing a bunch of upgrades to the van I installed a light bar directly to the crush bumper, then mounted the lights to the bar. Much happier with this solution.
_________________ previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor. |
alembical Samba Member
Joined: October 12, 2011 Posts: 16 Location: Portland, OR
Posted: Fri Jun 15, 2012 2:20 pm Post subject: |
_________________ 1997 EVC |
Posted: Fri Jun 15, 2012 2:23 pm Post subject: |
Posted: Fri Jun 15, 2012 2:42 pm Post subject: |
Bill - That's a great suggestion. I will definitely go that way.
Zippy - Nice looking bar. Is that notched right into the fibreglass? Is it a custom piece, or regularly available?
Alembical - Your silence speaks volumes _________________ 1988 Tintop Wolfsburg Special Edition - "Meatloaf"
Posted: Fri Jun 15, 2012 2:46 pm Post subject: |
yeah, not sure what is going on. When I go to the messages and hit Edit, all of the text, links and pictures show up. When I go to view the thread, they are blank.
My messages had said I use a license plate mounted fog light bar
Like this http://www.buy.com/pr/product.aspx?sku=221566884&sellerid=33746554
works well on our van... but, ours is a Eurovan. _________________ 1997 EVC |
Also thanks to Alistair for the diagrams. My German is getting better bit by bitte! _________________ 1988 Tintop Wolfsburg Special Edition - "Meatloaf"
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Fri Jun 15, 2012 5:18 pm Post subject: |
Mine are mounted to the fiberglass bumper and are very stable. I used some heavy rubber washers on the topside of the bumper to help prevent them from twisting left or right.
I wired them to a Porsche 944 fog light switch, and then to a ignition powered relay so they automatically turn off. I usually leave them on to be used as daytime running lights.
_________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
maco70 Samba Member
Joined: March 16, 2011 Posts: 456 Location: Montréal, Québec
Posted: Sat Jun 16, 2012 3:36 pm Post subject: |
Here is how i installed it :
Those products, the fog lights and the driving lights are from Van Cafe. _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Sat Jun 16, 2012 4:32 pm Post subject: |
very nice...
do you need to remove the bumper to mount then?
thanks |
