Engine re-build, seized during break-in
Goto page Previous  1, 2, 3, 4  Next
KTPhil
KTPhil is offline
PostPosted: Sun Jun 17, 2012 8:38 am    Post subject: Reply with quote
Stitch59 wrote:
I've drained off the oil. Got 2L out.
I presume you meant 2 quarts. 8 quarts won't fit inside a VW block!
Rebuilds don't always go right. I rebuilt a 40 hp motor of a friend, who bought all the parts and so I just did the assembly. I didn't bother to inspect the crank-- it was new, after all. A week after it was back on the road, the oil light came on at higher and higher rpms over the course of a drive home, and it also sometimes made a strange low rumble or clunk.
We tore it apart, finding nothing wrong, even after splitting the case. So we lifted the crank out... or rather, we lifted HALF the crank out! It had split in two, but the car still ran because the crack was at an angle such that the two halves were keyed together!
My friend, a machinist, looked over the crank,a nd found the radius of the machining at one of the main bearing cheeks was too small, concentrating stress, and it then cracked.
A new crank and bearings, and it then ran for many years after that.
Don't get down; be patient, learn all you can (this is how we all learned) and post lots of photos for us to learn from and help us help you.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jun 17, 2012 9:53 am    Post subject: Reply with quote
not hammering,no noises, top end looking ok, oil before seizing.. i guess rear main bearing and rear seal gone from improper end play. but it is all guesses untill it is apart. good luck might just cost you a set of bearings...and a few advil for the headache
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1958 deluxe Parts needed
1 rear hatch
2 rear pressed bumper trim
3 locking t handle
4 safaris
5 front hurst
Stitch59
Stitch59 is offline
PostPosted: Sun Jun 17, 2012 2:20 pm    Post subject: Reply with quote
A liter is nearly the exact same volume as a quart (1.000L/1.057qt). I drained off 2 liters. The 36HP holds 2.5 liters. Therefore, I lost 0.5L along the way.
I'll drop the engine today. I'm not sure I'll be able to get the flywheel off by myself, but I should be able to tell if it has/had oil sprayed all over it.
Stitch59
Stitch59 is offline
PostPosted: Sun Jun 17, 2012 2:33 pm    Post subject: Reply with quote
Here is a video of it running, the first time I started it. The next day, I adjusted a few more things and took it for its ill-fated break-in drive.
http://youtu.be/wCJvD8pyNJg
Stitch59
Stitch59 is offline
PostPosted: Sun Jun 17, 2012 6:42 pm    Post subject: Reply with quote
Engine is out. Here is what I've discovered:
Nothing...
I'll see if I can get the flywheel off later today and then split the case.
There were no signs of oil leaks anywhere and the pistons all had oil dripping off of them.
Stitch59
Stitch59 is offline
PostPosted: Sun Jun 17, 2012 6:55 pm    Post subject: Reply with quote
So what caused the oil to stop circulating, if that is indeed what the route of the problem was?
Here is my best guess. The pressure release valve piston jammed. What does everyone else think? It didn't drop out when I opened it up. Just the spring did.
Teeroy Premium Member
Teeroy is offline
PostPosted: Sun Jun 17, 2012 7:10 pm    Post subject: Engine re-build, seized during break-in Reply with quote
How hard is it to turn over? My guess is the endplay was too tight, and once it warmed up it seized at #1 main.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Stitch59
Stitch59 is offline
PostPosted: Sun Jun 17, 2012 7:13 pm    Post subject: Reply with quote
Its impossible to turn over now. When it was running, or prior to me putting it back in, it wasn't terribly difficult to turn over. Turn it over then, seemed to be mostly limited to compression.
Stitch59
Stitch59 is offline
PostPosted: Sun Jun 17, 2012 7:55 pm    Post subject: Reply with quote
I take that back. I thought it was impossible to turn over until I tried to take the flywheel off. I guess 200+ lbs of torque will turn it over.
Stitch59
Stitch59 is offline
PostPosted: Mon Jun 18, 2012 12:23 am    Post subject: Reply with quote
Split the case. There was some oil around the front seal. I'm guessing that is where it all came out. The split bearing as the one that seized. Don't know why though. Doesn't seem to have done any severe damage. I'll post pictures.
But what caused it?
The oil pressure valve piston dropped out when I was splitting the case. So it wasn't jammed.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Mon Jun 18, 2012 9:19 am    Post subject: Reply with quote
could be a bad line bore or bent crank.
1958 custom camper
1 rear hatch
3 locking t handle
4 safaris
5 front hurst
Max Welton
Max Welton is offline
PostPosted: Mon Jun 18, 2012 9:29 am    Post subject: Reply with quote
What was your measured clearance on that bearing?
Max
"Someone" told him it was true. That should be good enough for anybody.
Tdog71
Tdog71 is offline
PostPosted: Mon Jun 18, 2012 9:43 am    Post subject: Re: Engine re-build, seized during break-in Reply with quote
This is what I would guess too.
Stitch59
Stitch59 is offline
PostPosted: Mon Jun 18, 2012 2:39 pm    Post subject: Reply with quote
I didn't have it line bored. Same crank and bearings went back in. Machine shop said they checked out fine. I don't know the measurements.
Anyways, I don't think it was any of those things that caused it to seize. I believe it was an oil circulation problem.
#1 wasn't seized. Only the split bearing seized.
Tdog71
Tdog71 is offline
PostPosted: Mon Jun 18, 2012 2:48 pm    Post subject: Reply with quote
Use compressed air, remove the bearings and blow out the oil passages. Make sure the dowel pins are the same length as the old set. If they are new, they may be long and will pinch the bearing against the crank main journal if the case was line bored in the past. This burned me before. I had to shave the dowel pins.
Snort
Snort is offline
PostPosted: Mon Jun 18, 2012 5:27 pm    Post subject: Reply with quote
I would be tempted to pull all the plugs from the oil passages and do a complete case cleaning. Personally, I've never done this but if my 36hp went through what yours just went through then I would be reading up on this process and purchasing replacement threaded plugs for the job.
Max Welton
PostPosted: Mon Jun 18, 2012 5:28 pm    Post subject: Reply with quote
Absolutely. Gritty metal filled oil went through the entire engine.
Max
Stitch59
Stitch59 is offline
PostPosted: Tue Jun 19, 2012 1:47 am    Post subject: Reply with quote
Looks like gritty metal fillings may have caused the problem. Take a look at the split bearing. The others are fine.
The depressions coming out of the oil holes aren't suppose to look like that. The other bearings don't look like they were starved of oil.
Doesn't seem to have done much to the crank though...
Donnie strickland
Donnie strickland is offline
PostPosted: Tue Jun 19, 2012 11:38 am    Post subject: Reply with quote
That looks almost like the split bearing was too large on the crank side. Do you know what size it was?
Stitch59
Stitch59 is offline
PostPosted: Tue Jun 19, 2012 1:27 pm    Post subject: Reply with quote
Crank was original, had not been machined. Bearings were also original.
Why do you think it looks to large?
Page 2 of 4
