911 cam nut
72veedub
72veedub is offline
PostPosted: Sun Jun 17, 2012 8:07 pm    Post subject: 911 cam nut Reply with quote
I have a 72 911t motor size 2.4 I need to get the cam nuts off does anybody
know what size they are ? I know they are big cause a 1 11/16" socket did not fit. thanks ahead of time.
CUBA
CUBA is offline
PostPosted: Sun Jun 17, 2012 9:37 pm    Post subject: Reply with quote
I would yank that one out, and just throw a VW motor in Cool
LISTEN TO CONVERGE
jt912
jt912 is offline
PostPosted: Mon Jun 18, 2012 7:13 am    Post subject: Reply with quote
46mm
72veedub
72veedub is offline
PostPosted: Mon Jun 18, 2012 10:36 am    Post subject: Reply with quote
well actually it is going in a beetle.
Low Bräu
Low Bräu is offline
PostPosted: Tue Jul 03, 2012 2:04 pm    Post subject: Reply with quote
You need to set the motor to Z1 and use the proper tools to hold the cam while you loosen the cam nut (46mm). You risk bending valves if the cam or pistons move while you brake that nut loose. Those nuts are tight so be careful. I recommend you use the correct tools or take it to a shop with the proper sockets and have them loosen them for you. Just my two cents.
Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1974 Vespa VBC Super 177cc
1964 Honda CB77 Superhawk
tripicana
tripicana is offline
PostPosted: Wed Jul 11, 2012 8:44 am    Post subject: Reply with quote
so you're going to swap a porsche motor into a bug, but dont even know how to measure a nut?....
foam cowboy hats aren't good helmets.
