joe h. Samba Member
Joined: September 04, 2005 Posts: 782 Location: Seattle, Wa
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Thu Jun 21, 2012 5:51 pm Post subject: |
joe h. wrote: |
"widened Porsche 16" wheels"
Ouch!! |
Bold school! |
riveted Samba Member
Posted: Wed Jun 27, 2012 2:00 pm Post subject: |
Any more new info on this thing Jerry? Are you gonna end up taking it apart?
Ryan |
avus Samba Member
Posted: Wed Jun 27, 2012 2:31 pm Post subject: |
riveted wrote: |
Ryan |
No updates yet, Ryan. I've been tied up with real work lately (ugh!) A friend came by today, and identified the 356 on the Peppertree logo as a 1965-6 so we know that the sticker is at least that new. I haven't gotten a response yet from the "Big Deal" Gallery website about the artwork. |
avus Samba Member
Posted: Wed Jun 27, 2012 6:15 pm Post subject: |
I had a few minutes this afternoon, so did a quick check of valve timing. I just used the 8 deg mark on the pulley for reference, and a ghetto dial indicator setup, so the accuracy is questionable, but it looks like intake opening is around 30 deg btdc at .040" lift, and total lift is something over .320" I need to pull the exhaust to mount a degree wheel, and do a more accurate check, but i wouldn't be surprised to find the crankcase modified to fit a 356 super camshaft. I'll be pulling the tin and exhaust for freshening, and will post pics soon. |
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Wed Jun 27, 2012 7:38 pm Post subject: |
As Sargent Klink used to say Jerry, "very interesting!". we await your findings.......................
Burly |
Posted: Sun Sep 23, 2012 9:11 am Post subject: |
Hey Jerry, just checking in...
Have you had any free time to get this motor torn down? Found anything else interesting?
Ryan |
avus Samba Member
Posted: Sun Sep 23, 2012 9:15 am Post subject: |
No progress yet. My summer got hijacked by family and business obligations. Hopefully things will settle down soon, and I'll have a little shop time.
riveted wrote: |
Ryan |
Posted: Sun Sep 23, 2012 9:22 am Post subject: |
Missed you on the salt Jerry!
Burly |
avus Samba Member
Posted: Sun Sep 23, 2012 9:29 am Post subject: |
Meee too!! Can't wait to see some more pictures, Burly.
36hplandspeedracer wrote: |
Burly |
avus Samba Member
Posted: Wed Mar 19, 2014 4:30 pm Post subject: |
I finally got around to digging deeper into the "Rivets" engine. I'm hoping to freshen it up and run it on the Salt this year. It has seriously leaked oil, and needs to be cleaned up before I open it up. Planning to pull the heads and cylinders, and hopefully not split the case. Here are a couple of pictures.
Flywheel was 6v 36hp VW modified for 200mm clutch and 12v ring gear.
Heads show signs of mild porting.
Lovely aluminum cylinders. I'd like to know what exactly these are, and how I should treat them.
The crank does not have an index mark stamped in the gland nut hole, as the Porsche cranks I've seen do have. The flywheel was fitted with a single thick shim, Porsche style. But, perhaps my screwdrive down the spark plug hole method of checking the stroke was faulty. Should know for sure in a couple of days.
The main oil leak seems to be the typical generator gasket problem. Big mess, but easy fix. Yahoo! |
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Wed Mar 19, 2014 11:12 pm Post subject: |
Very cool! _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
avus Samba Member
Posted: Fri Mar 21, 2014 6:08 pm Post subject: |
The autopsy continues. After a couple of hours of grease sculpture, I pulled a head and cylinder to check dimensions. Bore is 82mm and stroke 74mm. If arithmetic is correct that makes 1563cc--woohoo! The cylinders are aluminum with iron liners. I don't know their original application, only that the holes for the studs were repositioned slightly, and the piston crowns appear to have been machined flat. Barrel shims are 1.45mm and deck clearance is 1mm. Heads have been opened up with a 1.5mm step. I haven't cc'd the chambers yet.
Other discoveries include Porsche "windage" pushrod tubes. Oil seal on crank pulley (leaking badly). Crank pulley ID'd as Porsche industrial ( http://www.thesamba.com/vw/forum/viewtopic.php?t=570758 ) and badass looking cam lobes. Visually the cam appears to have much more duration than stock or even "performance" grinds I have at hand. More research needed.
Current agenda includes fixing oil leaks, further inspection and servicing of valve system, checking and possibly adjusting compression ratio, and measuring cam profile.
To me this engine looks like a likely 36SSS contender. I'm torn between running it in original trim, or modifying exhaust and intake to run in SSS category. I would welcome any information and suggestions.
Machined piston tops, and cylinder stud holes moved inward.
.060" step cut heads with 33mm intakes
knurled piston skirts
Crank pulley seal modification
Posted: Fri Mar 21, 2014 11:38 pm Post subject: |
Dang Jerry that's a cool vintage engine! Run it. _________________ 71 Westy Roadcow
67 Panel
63 Bug
74 Ghia Vert
80 Cabby 2.1 16v
98 Passat |
avus Samba Member
Posted: Sat Mar 22, 2014 8:37 am Post subject: |
Roadcow wrote: |
Dang Jerry that's a cool vintage engine! Run it. |
that's the plan, Britt. Hope to have it spiffed up and in the car for a little test drive in about 3 weeks. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Sat Mar 22, 2014 7:55 pm Post subject: |
whats the purpose behind knurling the pistons _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
avus Samba Member
Posted: Sun Mar 23, 2014 8:59 am Post subject: |
sub-hatchtim wrote: |
whats the purpose behind knurling the pistons |
Knurling used to be standard procedure when reusing pistons, to restore skirt clearance lost due to slight collapse or wear of piston. It was also thought to improve cylinder lubrication by trapping oil in the grooves of the knurl. I assume these were Mr. Smith's motives when he built the engine. |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Mon Mar 24, 2014 10:48 am Post subject: |
Super cool engine Jerry. Definatley a contender engine. Sadly the guys that did this neat shit have passed on. wouldn't it be nice to hear 1st hand what was done and why, instead of performing autopsies. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
avus Samba Member
Posted: Mon Mar 24, 2014 11:58 am Post subject: |
AirCooledClassics wrote: |
Super cool engine Jerry. Definatley a contender engine. Sadly the guys that did this neat shit have passed on. wouldn't it be nice to hear 1st hand what was done and why, instead of performing autopsies. |
I love discovering things that surprise me how smart they were in the "old days" (when I was a kid ). |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Mon Mar 24, 2014 9:25 pm Post subject: Re: Craigslist find - hotrod 36 |
[quote="avus"]
I tried to contact Peppertree Automotive, but the number in no longer in service. Anyone know Peppertree Roger Smith?
I purchased a Pre-A Porsche 356 2pc. engine and it had the same decal in same spot!!
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
