avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Mon Mar 31, 2014 1:35 pm Post subject: degreeing cam |
Here's my setup for degreeing the camshaft.
I checked timing at .001, .006 and each .010 up to .050". This seems like a rather radical grind for a supposed "mpg engine". I don't do this often, so I repeated the process a few times and verified numbers within a degree or so. Here's what I got:
avus Samba Member
Posted: Mon Mar 31, 2014 3:42 pm Post subject: |
The combustion chamber volume measures 48cc. With a deck of .040" compression ratio is 8.3 : 1. The valves show considerable wear, though they are not leaking. And one valve guide was found loose in the head, so I'll touch up the valve job and guides. Other than that, and a little clean up it will go back together as found. More compression is tempting, but I think this will be a nice street engine as is. |
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Tue Apr 01, 2014 3:14 am Post subject: |
Go ahead, give in to temptation. _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
avus Samba Member
Posted: Fri May 09, 2014 2:25 pm Post subject: |
Closer inspection revealed that the ring grooves in the pistons were badly worn, and so were some valve guides. I replace the sloppy guides, sent the heads to Marty at WSK machine with some new 33 mm intake valves, and sent the pistons to Kevin at Total Seal for some machine work and ring groove inserts.
In cleaning the lifters, I found that some of the pushrods were completely plugged, and couldn't be cleared with air pressure or baling wire. These are early-style lifters, but in very good condition, so I decided to remove the "chopsticks" and reuse them.
My method is to pry the end of the pushrod off using an old flaring tool vise and two pry bars.
Most of them came apart like this. Some so stuck I had to drill through the oil hole to get the wood out of the pushrod tip.
The sticks are quite intentionally designed and machined, with the lower (lifter) ends having a distinct groove, probably designed to allow oil passage. However, the upper ends seem incongruously made to plug the oil exit to the rocker arms. The pointed tip could be a result of wear, so it's hard to know what a new one would look like.
It would be interesting to know the actual design rationale behind The pushrod chopsticks, but in any case I feel better knowing that the rockers and valve guides will get steady lubrication.
Heads will go together this afternoon, and pistons will be here Monday. Progress! Wahoo! |
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Fri May 09, 2014 7:28 pm Post subject: |
I have heard two versions of why the chopsticks are in there. The first is to take up volume so the oil pressure comes up sooner, and the second is that the wood moving back and forth helped to pump oil to the valve train. I suspect the first is more likely. By the way the cam is probably a 2-pc case 356 super cam which had timing of 19, 54, 54, 19 at 1mm clearance. Very close to the 18, 54, 56, 18 at .040 inches you measured.
The cylinders are probably sleeved 2-pc case 356 cylinders. Ray Litz at Competition Engineering in Pasadena, used to do this back in the early 70's. He would machine out the cylinders to just the finned section and shrink fit them to an iron sleeve he had made by L.A. Sleeve. He would do them in bore sizes of 80 or 82.5 mm for use with 356 pistons and I'm sure he could have done them in 82 for use with a VW piston.
All in all this was probably a pretty hot engine back in the day!!
Alan |
avus Samba Member
Posted: Sat May 10, 2014 4:10 pm Post subject: |
alanhall wrote: |
Alan |
Thanks for the info Alan. I had come to a similar conclusion concerning the camshaft, but the lift numbers didn't seem to agree. In looking at the camshaft comparison picture in your photos, the lobe width on the Porsche cams look like what I can see in my engine. The idea of resleeved cylinders makes good sense, but I'm puzzled by the 82mm bore size. The pistons appear to have had the tops machined flat, and don't match any VW size that I recognize. I believe this engine was assembled in the late 1980's or early '90s, probably from spare parts Roger Smith has on hand. Hope to have it making noise and smoke again very soon. |
Posted: Sat May 10, 2014 8:54 pm Post subject: |
The other possibility for the cam is that it is an Isky 2J re-grind. The timing was very similar to the Porsche super grind (I think, but Isky didn't say what clearance their numbers were based on) and their lift was .335 inch.
The pistons don't look like they started life as anything from a Porsche and if they are not VW then it's a good question what they are from. I assume the engine has a 356 crank and rods, so the piston would be 82mm diameter with a 22 mm pin, maybe from some Japanese or European motor. If you ever get a look inside the piston there might be some markings as to who manufactured it.
I'm looking forward to hearing how it runs!
Alan |
avus Samba Member
Posted: Tue May 20, 2014 5:02 pm Post subject: |
Longblock back together, no valve or cylinderhead leaks. Still need to work on the rockers, though. The rocker/ valve stem contact is all over the place. I'll do some parts and shim swaps tomorrow. I couldn't resist a picture, though. I love VW engines at this stage, and almost regret having to clutter things up with cooling tin. The ally cylinders are, to me, especially photogenic.
The tin is all cleaned up, so things should go fairly quickly from here. However, the pci30 carb, I think, is not legal in 36 sss category, so I will find a 28 pci to use just in case this engine makes it to Bonneville. Maybe this will help:
I hope Roger doesn't mind. If so, I'll probably disappoint him a bit more before this is done. |
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Tue May 20, 2014 5:21 pm Post subject: |
Someones having fun, huh Jerry! See you on the salt, or maybe in June ? ? ? ?
Burly |
Posted: Tue May 20, 2014 5:32 pm Post subject: |
Engine porn Jerry! _________________ 71 Westy Roadcow
67 Panel
63 Bug
74 Ghia Vert
80 Cabby 2.1 16v
98 Passat |
avus Samba Member
Posted: Tue May 20, 2014 5:54 pm Post subject: |
36hplandspeedracer wrote: |
Burly |
June, Burly? What's happening in June? I plan to be snorkeling with the Manta Rays in June. There will be salt there, but it's dissolved in crystal blue water. Aloha. |
avus Samba Member
Posted: Wed Jun 04, 2014 4:54 pm Post subject: |
I lives!
Carburetor jetting was a hipshot, but with the timing set and ear tuning, it idles. O2 sensor hooked up, and carb tuning tomorrow. No leaks or noises so far, and it sounds strong. Wahoo!
Stinger thru decklid=no sss36 recognition But beaucoup aural enhancement, and perhaps additional thrust. |
Posted: Wed Jun 04, 2014 10:32 pm Post subject: |
That's Bitchen Jerry! Tell us how it runs tomorrow. I may have to sneak up and see you tomorrow also!!! _________________ 71 Westy Roadcow
67 Panel
63 Bug
74 Ghia Vert
80 Cabby 2.1 16v
98 Passat |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Fri Jun 20, 2014 5:49 pm Post subject: |
alanhall wrote: |
Alan |
a little late, but the figures I have for a isky 2J are: .335" lift. in. 19 , 55. ex. 53 , 20. at .020" check clearance. (from "making the Volkswagen go") |
avus Samba Member
Posted: Tue Jul 22, 2014 5:55 pm Post subject: |
I decided to make the Rivets engine 36hp Challenge SSS compliant, so installed an exhaust header which allows a deck lid without holes. Nobody seems to make a merged header for 36hp but a 1600 header with slip jointed primaries should be easy to modify, right? So I ordered a header from a well-known supplier (who might get a good plug here had it not taken 3 weeks to receive my parts) and started fitting pipes to motor. I knew that 36hp engines were shorter and narrower than 1600 engines, but what I didn't know was that the exhaust flange bolt patterns are clocked differently by about 2 degrees. Meaning that all 4 exhaust flanges had to be cut off the headers and rotated 2 degrees to align the headers with the heads. Piece of cake for a good weldor--2 days of education for me. In any case, the deed is done. The apron also needed relief to clear. Looks like it will work. One more carb tuning session, and Rivets should be ready to rock.
Posted: Tue Jul 22, 2014 6:07 pm Post subject: |
Looks great Jerry! Can't wait. It would be nice if I had a day to run up and see how everything fits. _________________ 71 Westy Roadcow
67 Panel
63 Bug
74 Ghia Vert
80 Cabby 2.1 16v
98 Passat |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Tue Jul 22, 2014 6:55 pm Post subject: |
Klasssy idea Jerrry.................................Burly |
avus Samba Member
Posted: Wed Jul 23, 2014 7:00 am Post subject: |
Actually, mine is trick photography, too. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
