Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun Aug 05, 2012 1:29 am Post subject: |
Nepenthe88 wrote: |
Speaking of transaxles....
uh-oh! (but look how relatively easy that was... Bet'cha Joel didn't even have to cut the axles like I did on the subaru )
Joel wrote: |
f**king gearboxes...... how do they work????
Half a million KMs worth of gear changes has got the brass bushings in the nose cone a bit worn out.
thing was pissing gearbox oil into the tunnel. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Nepenthe88 Samba Member
Joined: September 03, 2010 Posts: 1320 Location: Colorado
Ghia Nut Samba Member
Joined: December 23, 2003 Posts: 1565 Location: B'ham Alabama
Posted: Mon Aug 06, 2012 10:33 am Post subject: |
just tagging myself in this post so I can read it later, awesome work man, gotta get my wiring together. _________________ '59 typ1 rajay turbo
'72 Ghia rajay 1641 dual 36DRLAs, 1 3/8" SS merged header and fat boy
78" GL Vert with ej22t swap
This will likely change tomorrow to something else. |
Posted: Mon Aug 06, 2012 12:45 pm Post subject: |
@ghianut.. I hear ya. Once things calm down a bit im gonna draw up a nice wiring diagram, so stay tuned.
Also... Test drove a 2004 subee Forester xt today. Ooh baby! She was a sleeper. Once that turbo spools, youre off! She'd be awesome in a bug/bus. Regardless, I'm looking for a winter 'beater' that I can turn into a donor in a year or two. It's really gotta be the right car at the right price though. _________________ a Black & Blue Su-BUS-aroo
Follow my adventures in the GoWAND'RLoST bus on Instagram:
https://www.instagram.com/gowandrlost/ |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Mon Aug 06, 2012 2:40 pm Post subject: |
I saw they sell the pilot bearing as a stand alone piece and questioned whether or not I needed it when I put my order in, but the description of the adapter plate says
Quote: |
Kennedy Subaru adapter flywheels use a standard 8mm x 1.25 thread 20mm long clutch bolt. Adapter flywheels have a standard 12 volt Volkswagen style ring gear. This engine adapter includes the hardware to mount to the transmission, the hardware to mount the flywheel to the engine, the billet aluminum engine adapter plate, the adapter flywheel, the adapter pilot bearing, and an aluminum dust shield. |
I put a quick call in to the guys at PacificCustoms and they confirmed that the pilot bearing comes with the kit and is in fact already installed in the flywheel. Yay! You had me worried there for a second though!! Regardless, thanks for looking out for me! Gosh knows I'm still noob-ish enough to make silly mistakes _________________ a Black & Blue Su-BUS-aroo
Posted: Mon Aug 06, 2012 2:47 pm Post subject: |
... that phone call did cost me an extra $6 though I wound up getting some clutch installation hardware added to the order. Metric stuff can sometimes be difficult to find in the right pitch / length and it sure isn't worth my time driving around wasting gas searching for 6 grade 8.8 bolts and wobble washers. I'll edit my expenses now so I don't forget. Also, here's a link to the hardware:
http://www.pacificcustoms.com/AC000806.html _________________ a Black & Blue Su-BUS-aroo
Posted: Mon Aug 06, 2012 3:27 pm Post subject: |
While I was out and about looking at Subee's, I also stopped at the Subaru Dealer's Parts Department to get a line on how much a complete gasket kit would go for. Dealer want's $309 for their kit, which is obviously all guaranteed to be OEM Subaru stuff. Here's the printout of what it includes:
Now, after trolling various subee swap threads, it seems like pretty conventional wisdom that you MUST go with the BROWN OEM subaru seals, as the more generic black ones tend to leak pretty quickly. I don't know about you, but I'd rather do the job once than mess around with crappy parts and have to pull the engine 3 or 4 times replacing various failed seals... Despite the fact that you can get a complete EJ22 gasket kit for right around $38 (?!).
That said, the question I'd like to pose is... Does anyone know where to get a quality OEM seal kit, without paying the dealer's markup???
One would think that a quick google-ing would answer the question, but....buyer beware?! As I found this "Complete OEM Gasket Kit" for a mere $280, but (by the looks of things) all their seals are BLACK?! here's that link:
http://www.cimotorsports.net/motor-sport-products/subaru-oem-complete-gasket-kit-ej22.html
I realize I might have to go troll the subaru forums to get an answer, but thought I'd throw it out there anyway _________________ a Black & Blue Su-BUS-aroo
Posted: Mon Aug 06, 2012 7:07 pm Post subject: |
@GhiaNut-- Hey, that's a nice find. I hadn't run across that diagram yet. The only issue I have with it is that it's A) visually complicated, and B) isn't quite "complete".
As far as A) goes, I'd really like to break that master diagram into smaller "systems". One for Ignition, another for diagnostics, a third for the O2 sensor, etc. It may get a little repetitive, but I think it will be worth it in the long run. Not only will other people be able to check their work system by system, but People should be able to troubleshoot future electrical issues easier in the future.
As far as B) goes, I think it would be beneficial to really idiot-proof everything and show pictures / diagrams of all the quick clip connectors and relays wired up (I also want to have a little information on troubleshooting / testing relays in general)
Now, this isn't really my idea. I re-wired the entire bug with a Watson Streetworks harness and not only did that company supply me with a nice master wiring diagram and individual "systems" diagrams, but there's also a thread on here that's helping to flesh out some of the fuzzier parts of those documents. You can visit that thread here, and see one of the diagrams I did on pg.5 I'm hoping to do something similar (visually) with the subaru wiring. It's a different animal of course, so a slightly different visual technique is going to have to be used. Right now I'm thinking.... a black and white master @ 25% opacity (to show the general relation of the parts to the whole) with the system in question in full color to jump out.. if that makes sense
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=80 _________________ a Black & Blue Su-BUS-aroo
madness726 Samba Member
Joined: August 06, 2012 Posts: 9 Location: Battle Ground, Washington
Posted: Mon Aug 06, 2012 7:54 pm Post subject: |
Joel sent me a link to your build post, Nice job so far.. I just started mine.. I wish I would have labeled the wiring harness but I did not because I figured I would just send it out to be done... OOPS I will follow your post to see what happens..
Also here is a link to mine..
http://forums.aussieveedubbers.com/viewtopic.php?tid=97861 |
Posted: Mon Aug 06, 2012 9:25 pm Post subject: |
@Madness-- I see you've a '93 Subee as well. Very nice year.... for a donor! I wish I woulda went subee powered straight out the gate-- you must be smarter than me! Doing it from the get-go will give you a chance to have everything buttoned up and painted nice the first time around. Might I suggest a removable rear apron (Joel's way, not mine), some Ghia disks up front (at minimum), and you should probably take a look at the FOAM link in my sig. It's good reading for anyone that's got a fatchick with a bubbling C.
That is all for now grasshopper. You've been bookmarked. I'll be watching _________________ a Black & Blue Su-BUS-aroo
surfbeetle Samba Member
Posted: Mon Aug 06, 2012 10:56 pm Post subject: |
Have you tried http://www.outfrontmotorsports.com ? I ordered some exhaust gaskets and small stuff from them. They really know their stuff. _________________ 67 Beetle Build Thread
69 Beetle |
Joel Samba Member
Posted: Mon Aug 06, 2012 11:34 pm Post subject: |
Nepenthe88 wrote: |
^^^ gonna do a Rebuild or Subarugears ?? |
A Subi box may happen one day but for now stock works well and i have a few spares if I manage to break one. _________________ Quick little bug, you got a Porsche motor in that?
Posted: Tue Aug 07, 2012 5:28 am Post subject: |
wish I could do a subagears swap, but sooooo expensive. _________________ '59 typ1 rajay turbo
Posted: Tue Aug 07, 2012 6:22 am Post subject: |
Nepenthe88 wrote: |
That said, the question I'd like to pose is... Does anyone know where to get a quality OEM seal kit, without paying the dealer's markup??? |
I bought my weber carbs from NOPI in 93 and a few handfull of parts over the years. As for the Suby gasket set, I cant say these are black or brown, good or bad. but the price is right@$164.59
Nopi used to have a huge car show every year, but the economy got shitty and so they quit. This year they are gonna have it again.
http://www.nopi.com/dsp_part_detail.php?vnopinum=325+0893
The image they have posted for the kit is wrong |
Posted: Tue Aug 07, 2012 8:49 am Post subject: |
^^ Thanks again. I looked up the Topline Gaskets but couldn't really find much info on them (which always makes me leery). I did however stumble onto a good tidbit of info while I was searching....
Two companies (ISHINO and NIPPON REINZ) make gasket kits with OEM seals (according to a Subaru forum and one of the vendors... as always, buyer beware, I have no experience with these manufacturers/ vendors). I found a good deal on a NIPPON kit for $140. Only problem is it didn't have a parts list of what's included (I'm risk adverse and wish venders would spec out everything in their kit, as opposed to merely calling it a "Kit" ...seems silly to me). Here's a link. moving back one page you'll see "This is a OEM Product" (sic) in red writing (in case the link dies, it looks like we're looking for AutoPart# W0133-1609342 as that # is the same for both ISHINO and NIPPON 2.2L "kit"): http://www.autopartsnetwork.com/catalog/1995/Subar...year:1995_
Regardless, I also heard good stuff about an Ebay vender named Domestic Gaskets that uses all OEM seals. I didn't see an EJ22 kit. Maybe they're sold out? I did however find a halfway reasonable Serpentine belt kit with all the pulleys (and brown seals ). They come in different package configurations too. With water pump / without. With tensioner / without. It's nice to know you can customize their "kits" to include exactly what you need.http://stores.ebay.com/domesticgaskets/_i.html?_nkw=2.2L+subaru&submit=Search&_sid=493876738
Regardless, I'm not buying anything until I can pressure wash the engine. I want to get everything clean and bolt on the adapter (which is on the way already! got a tracking # last night-- For free shipping, I'm impressed, WOW!). After that I want to bolt it to the back of the Domus Flatback bug truck (also on the way) and get it to run for a little while to see if there's any noticeable leaks. I feel like this has a couple benefits:
#1, the Domus Flatback has a "baja" style open rear end, so it should be easy to bolt in / bolt out.
#2, I'll have all sorts of room to poke things while the engine's in the car because it's even more OPEN than a baja.
#3, A complete car makes a better test stand than any homebrew test stand I could fab up.
#4.... it's a FLATBACK bug, which in my mind is basically a large, flat, movable workbench _________________ a Black & Blue Su-BUS-aroo
Oakley Diesel Samba Member
Joined: July 09, 2006 Posts: 523 Location: Lubbock, TX
Posted: Tue Aug 07, 2012 7:48 pm Post subject: |
Are their any dowel pins on your case ? or do they stay with the transmission? Their are 2 holes for dowels on my case & holes in the adapter. But my engine did not come with any. _________________ Let my name be Feared at the gates of Hell as I exault the Savior!!
72 Super EJ20 turbo install in progress!
04 Excursion 6.0 w/ Spartan tunes |
ts39136 Samba Member
Joined: January 30, 2010 Posts: 735 Location: Pocatello, Idaho
Posted: Tue Aug 07, 2012 8:01 pm Post subject: |
Nice to see your making progress. One recommendation from experience, ditch the six puck and go for a full circle clutch disc. PC sold me on the six-puck, too, but it's much to grabby on the street IMO. I'm running 32" tires with an 002 and the full circle clutch and stage ii plate are working fine.
Keep up the good work. I like your detailed documentation. _________________ My Build Page |
