Ignition Switch Problems
peacejones
peacejones is offline
PostPosted: Fri Jul 31, 2009 7:18 pm    Post subject: Ignition Switch Problems Reply with quote
Hi when I turn my key nothing happens. Not even the 'cluck' of a frozen starter throwout. However, when I 'pinch or jiggle' the wires going up into my newly replaced ignition switch, the starter throws in and it starts. Why would jiggling the wires make it fire? Anyone can help please do? thanks...
Cusser
Cusser is offline
PostPosted: Fri Jul 31, 2009 7:33 pm    Post subject: Reply with quote
Did this work fine just after the new ignition switch was installed? Or did the same symptoms just continue after you replaced the ignition switch? If the symptoms are the same, I'd say you have an "open" in the hot wire leading to the ignition switch, or possibly the "run" wire. Do you get the oil and generator light to come on when you turn the key?
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2004 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
peacejones
PostPosted: Sat Jul 07, 2012 6:58 am    Post subject: Reply with quote
solved -- weak post oN Battery weak as well -- would this fry a switch?
candymustang66
candymustang66 is offline
PostPosted: Sat Jul 07, 2012 8:08 am    Post subject: Reply with quote
no
