Engine is out - what should I change in there?
Goto page 1, 2  Next
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 3:13 pm    Post subject: Engine is out - what should I change in there? Reply with quote
Following my earlier threads about engine problems, Harvee's currently at the garage where they've got the engine out - he's getting new cylinder heads, pistons, cylinders, hydraulic cam followers and some other bits and pieces.
I've spoken to them and they're happy for me to come down and do anything I need to that area of the bus while the engine is out, so what should I be looking at?
I'm thinking:
Fuel lines
Gas tank sender (he only reads to half-full, even when the pump cuts out)
What else would you do with that sort of access?
Order list so far:
German Supply
Fuel Hose Kit Fuel Injected Bus 75-79, Vanagon 80-83.5 - ordered
Fuel Vapour Canister Hose Kit Bus '78-'79 - ordered
Oil Cooler Seal Bus '72-'79 Vanagon Aircooled '80-'83 Pair - ordered
Oil Filler Tube Gasket Bus '72-'79 - ordered
Shift Rod Coupler Bus 68-79 - ordered
Shift Rod Bushing Kit Bus '77- '79 - ordered
Clutch Cable Renew Kit Bus '72-'79 - ordered
Accelerator Cable Bus '75-'79 MT 3458mm - ordered
Fuel Tank Filler Neck Bus '74-'79 - ordered
Bus Depot
Fuel Tank Sending Unit - ordered
Airhead Parts
Power brake/decel valve rubber 'Y' piece
Ben
1979 7-passenger bus
Rallybugs
Harvee the Wonder Bus' pics
Harvee's blog
atmellovw
atmellovw is offline
PostPosted: Thu Jun 21, 2012 3:18 pm    Post subject: Reply with quote
Oil cooler seals...oil filter mount gasket and oil filler gasket
1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 3:26 pm    Post subject: Reply with quote
Added oil cooler seals (they may be in the set that they've already got, but at CAD2 for the pair from German Supply, it can't harm Laughing
Oil filter mount gasket? Did you mean oil filler, not filter? Like this?
Ben
Rallybugs
Harvee's blog
chrisradioman
chrisradioman is offline
PostPosted: Thu Jun 21, 2012 3:31 pm    Post subject: Reply with quote
Breather pipes above the fuel tank, all the fuel lines & fuel filter. Don't forget the breather hidden behind the spare wheel well. Very Happy
http://www.vintagevwweddings.co.uk/contact.html
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 3:34 pm    Post subject: Reply with quote
Fuel lines are in my order from German Supply
Fuel filter is already in the bus ready to be fitted
Breather pipes - hmm, OK, lets look for them, I wonder if they're included in the German Supply kit?
From Ratwell:
This is going to cost a fortune, but hey, at least they'll be done!
Ben
Rallybugs
Harvee's blog
curtis4085
curtis4085 is offline
PostPosted: Thu Jun 21, 2012 3:42 pm    Post subject: Reply with quote
german supply sells fuel and breather kits, you should also replace fuel filler grommet depending on you year. Pull and clean gas tank, if rusted it needs to be treated and repainted. Clean and degrease engine bay. Maybe even repaint engine bay depending how far you want to take this. oh check seals on side marker lights, if bad replace seals and pop out the plastic achors and use nuts bolt and washer to put markers back on. Paint fire wall. Reseal fire wall. sound proof back gas tank side of firewall.
edit: make sure it a VW or German fuel filler grommet. bus-boys.com has decent ones.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
71 Pastel White Panel Van current restoration
73 Westfalia (sold)
73 Westfalia (accident)
73 Kombi (Sold)
75 Panel Van
79 Sage Green Westfalia fully restored
http://www.thesamba.com/vw/forum/viewtopic.php?t=479199&postdays=0&postorder=asc&start=0
curtis4085
PostPosted: Thu Jun 21, 2012 3:44 pm    Post subject: Reply with quote
no.
you will need this.
http://www.germansupply.com/home/customer/product.php?productid=17327
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 3:46 pm    Post subject: Reply with quote
no.
you will need this.
I have them already somewhere, I think
Ben
Rallybugs
Harvee's blog
jtauxe
jtauxe is offline
PostPosted: Thu Jun 21, 2012 3:48 pm    Post subject: Reply with quote
While you are going after fuel lines, inspect the fuel filler neck rubber.
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
Long gone: 1969 and '78 CE Transporters, Westies: 71, 76, 77, 76, 77, 71, 73, 77
For sale: 1974 Westy Automatic
Current projects: 1975 Single Cab, 1978 RHD Double Cab 2.0-L FI
http://vw.tauxe.net
chrisradioman
Breather lines - hmm, OK, lets look for them
There are 4 short lengths above the fuel tank, one in front of the driver rear light up by the spare wheel well, 1 above the engine lid, 3 on a t-piece above the engine lid & one on the charcoal filter:-
http://www.volkszone.com/VZi/showthread.php?t=491922&page=28
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 3:53 pm    Post subject: Reply with quote
curtis4085 wrote:
...you should also replace fuel filler grommet depending on you year.....
I'm confused on which bit you mean now Confused
Part C?
Ben
Rallybugs
Harvee's blog
curtis4085
PostPosted: Thu Jun 21, 2012 3:56 pm    Post subject: Reply with quote
replace #'s 1, 6, 9, 24, and 15A in diagram
you may also need to replace this if you have not already
http://www.germansupply.com/home/customer/product.php?productid=18157
Edit #6 can be bought at your local Flaps. it will need to be cut to size. I think ratwell gives the part # for this and also has handy cutting instructions as well.
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
curtis4085
PostPosted: Thu Jun 21, 2012 4:02 pm    Post subject: Reply with quote
Part C?
thats the wrong year diagram your looking at if your bus is a 79.
it looks like this and has same part # but dont buy busdepot as it is cheap looking rubber. http://www.busdepot.com/211201119
call bus-boys and give them the part # 211201119 you want German or VW one.
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
curtis4085
PostPosted: Thu Jun 21, 2012 4:12 pm    Post subject: Reply with quote
for your reading enjoyment.
http://www.ratwell.com/technical/FuelTankRestoration.html#equip
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 4:13 pm    Post subject: Reply with quote
No answer from the Bus Boys order or information line.
I shall try again tomorrow.
Ben
Rallybugs
Harvee's blog
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 4:23 pm    Post subject: Reply with quote
First post updated
Ben
Rallybugs
Harvee's blog
curtis4085
PostPosted: Thu Jun 21, 2012 4:42 pm    Post subject: Reply with quote
i would look for a OG NOS VDO fuel sender.
and if your charcoal canister is as old as the bus repack it or call your VW dealer. busdepot sold me mine but i do not see them listed on there website. you may want to call and give them part number to check.
http://www.germansupply.com/home/customer/product.php?productid=17726&cat=&page=1
Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
Desertbusman
Desertbusman is offline
PostPosted: Thu Jun 21, 2012 8:17 pm    Post subject: Reply with quote
Sit down on the ground in the engine compartment hole. Look at the slime and dirt and start cleaning everything immaculately. Inspect every single thing that you can see in there. Not just in the engine hole but the area in front of the engine. Trans, suspension, brake lines, wiring, etc. Pull the trans and replace the rear shift rod rear bushing and closely inspect the coupler. Pull out the clutch and throttle cables and put new ones in.
Repair all the other problems you will find after you carefully inspect everything within sight. A new engine won't gain you anything when any of the related items fail.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
samwise
samwise is offline
PostPosted: Thu Jun 21, 2012 8:44 pm    Post subject: Reply with quote
All added to first post - Scott at German Supply is going to love me! Laughing
Ben
Rallybugs
Harvee's blog
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Thu Jun 21, 2012 11:20 pm    Post subject: Reply with quote
can you roll it outside and de grease the engine compartment itself? clean areas to work on things make me more willing to work....Wink
MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.”
Goto page 1, 2  Next
