JeRmAn Samba Member
Joined: June 18, 2012 Posts: 133 Location: Huntsville, AL
Posted: Mon Jul 23, 2012 5:24 pm Post subject: |
| Eric&Barb wrote: | Good to see the engine is out.
Make sure your cooling fan is correct 33, 34 or best 35 mm width (inside measurement). Thinner earlier fan will not cool properly.
You are missing the foam rubber seal over the cooler to force the cooling air through the cooler.
#1 & 2 head tin is missing a big chuck of metal.
You are going to need all of this engine tin except for pieces #8, and # 29.
Thanks a ton for all the information, and the engine tin diagram. It's crazy, but as I was taking the engine out and apart, I was wondering to myself exactly how much engine tin I was missing. It's going to take some time to get this done, but I hope to have it all set back into the beetle to run by year's end. There's a possibility to have it done before then, either way I'm enjoying the journey. I should have taken before and after pics of the engine bay. It was disgustingly dirty, and now looks spotless. I will be painting it all black before the engine goes back in.
Any suggestions on where to get a good replacement pulley? Mine seems to be bent and past it's prime. _________________ -JeRmAn-
-Alabama-
1974 V lkswagen Beetle - Project Restoration
'74 Project Thread |
dubhead74 Samba Member
Joined: October 06, 2011 Posts: 204 Location: hartselle,al
Posted: Mon Jul 23, 2012 6:10 pm Post subject: |
lol that question has an endless amount of answers lol
What type of replacement pulley are you looking for.Factory...aftermarket...sand seal..with numbers or without numbers.....so on and so on not to mention whats your budget lol If you get a used on make sure its not warped btw whats wrong with your? _________________ 1974 Standard Type 1
"She may not look like much, but she's got it where it counts....."Han Solo |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 9510 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jul 23, 2012 8:34 pm Post subject: |
You are welcome!
The Classifieds on this website are a great resource for parts. DH crankshaft pulley was biggest stock diameter since 1961, and most came with a 3/8" tall "D" stamped into the rear face of the pulley. Used a smaller pulley and fan RPM will be lower and cause cooling problems.
Good time to strip the engine down to a long block. Then you can retorque all the engine case fasteners in same sequence as you would when building it and then same for heads. Simply amazing how loose they can get especially when running without all the tin, seals, and thermostat in place.
Cleaning out all the casting flash out of head and cylinder fins helps also. _________________ In Stereo, Where Available! |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4549 Location: Central Maryland
Posted: Tue Jul 24, 2012 2:47 am Post subject: |
| Eric&Barb wrote: | | DH crankshaft pulley was biggest stock diameter since 1961, and most came with a 3/8" tall "D" stamped into the rear face of the pulley. |
Does the DH stand for anything? _________________ Mike
A nice pair (of '74s)
Parts... |
Posted: Tue Jul 24, 2012 6:00 am Post subject: |
DH = Dog House _________________ In Stereo, Where Available! |
JeRmAn Samba Member
Posted: Sat Jul 28, 2012 10:21 pm Post subject: |
| dubhead74 wrote: | | If you get a used on make sure its not warped btw whats wrong with your? |
Thanks for the info bud, mine is warped and needs replacement. I'm not really sure whether to go with an aftermarket Pulley or one good used OEM. Either way I will decide soon.
Question: Do you know what size the nut on the front of the pulley is? I don't have the right size wrench and I need to go pick one up.
| Eric&Barb wrote: | The Classifieds on this website are a great resource for parts. DH crankshaft pulley was biggest stock diameter since 1961, and most came with a 3/8" tall "D" stamped into the rear face of the pulley. Used a smaller pulley and fan RPM will be lower and cause cooling problems.
Cleaning out all the casting flash out of head and cylinder fins helps also. |
Great information, thanks so much because I didn't know about the stock pulley's. Also thanks for the info about the cooling fan size in a previous post. Very helpful! I'd love to take the engine down to the block, however I'm not sure I'm confident enough in my abilities to do so. I usually don't give myself enough credit, and I'm sure with the aid of a good repair manual I could manage it. I'm currently cleaning and degreasing the engine. _________________ -JeRmAn-
-Alabama-
JeRmAn Samba Member
Posted: Sat Jul 28, 2012 10:28 pm Post subject: |
Ok guys, got yet enother question. I was rolling under the beetle today taking a look around at various things, and noticed a large build up of grease on the top of the transmission case, and the frame, directly underneath the starter. The starter had tons of grease build up as well. I sprayed some degreaser on it and took a closer look. I noticed this little rubber tube coming from the starter, and it seems to be an open tube. I took a picture of it below...
Could this somehow be the cause of the grease/gunk build up? Can anyone tell me what this little thing is? What it's purpose is? etc? _________________ -JeRmAn-
-Alabama-
docdanracy Samba Member
Joined: June 26, 2012 Posts: 702 Location: San Jose, CA
Posted: Sat Jul 28, 2012 10:40 pm Post subject: |
| DesertBob wrote: | Nice to see another 74 here even if it is a Standard. Here is a picture of my 74 Motor. I did switch the manifold with one that did not have the EGR valve but everything else is stock.
Correct fuel pump will be angled to clear the alternator. The one for Generators will not.
Did the non-California cars not have the vacuum retard circuit for the dizzy?
My motor...notice dizzy retard and advance vacuum lines..
This is with my rebuilt 34pict3 installed in place of the standard 34pict4
Posted: Sat Jul 28, 2012 10:46 pm Post subject: |
Wow thats something I have not seen before on a starter.I hope someone will explain what it is there for. _________________ 1974 Standard Type 1
Posted: Sun Jul 29, 2012 6:27 pm Post subject: |
Never seen that tube on the starter.
Grease gunk probably is from gear oil seeping out of the transaxle seals. If you do not know when the gear oil was last changed (or even if there is enough in it) , it is time to change it. Make sure the fill plug is removable, before taking out the one or two drain plugs, depending on which model of transaxle case you have in there. Do a tea leaf reading of the dregs of the gear oil for any metal chunks. _________________ In Stereo, Where Available! |
Wideopen Samba Member
Joined: May 17, 2012 Posts: 256 Location: N. California
Posted: Sun Jul 29, 2012 10:20 pm Post subject: |
| JeRmAn wrote: |
Could this somehow be the cause of the grease/gunk build up? Can anyone tell me what this little thing is? What it's purpose is? etc? |
I have seen this rubber "tube" on hundreds of starters. The purpose is to relieve any moisture from the starter that may get in there. No it is not likely the source of your grease build up. _________________ 1971 Super Beetle...owned
Squareback.....wife is begging for....not in the $ right now!lol |
JeRmAn Samba Member
Posted: Sat Sep 08, 2012 9:08 am Post subject: Update |
Thanks for all the help with the Starter questions.
Since my last post I've been working hard on multiple projects. I have taken out the fuel tank and have degreased, sanded, primed, and painted the fuel tank and exhaust. I am also working on doing the same to the heater exchange tubes currently. The finished product looks amazing, and I'm excited seeing the process. I will post pictures up in the next few days. I'm also trying to get the mess of electrical wiring in the trunk re-routed and organized. So I have taken out all the knobs, air flow equipment, tubes, and glove box. I'm going to get an electrical schematic to see what's wrong, needs to be fixed, and clean it up. I can already see that it seems like I am missing some relay's, and that there are a few broken or missing connections. So it's going to be interesting trying to figure this all out. I'm also degreasing the engine, and taking it down to the basics. I'm going to clean it up and paint it as well. I'm also sanding and prepping the engine bay of the car, I'm going to paint it black. It's going great, and working on this little guy is addicting. Like I said, I will post up some pictures of my progress soon. _________________ -JeRmAn-
-Alabama-
JeRmAn Samba Member
Posted: Tue Oct 09, 2012 6:03 pm Post subject: |
Hey everyone! Just wanted to get some photo proof on here of what I have been working on. We all know a good progress thread is worthless without pictures!
First the bumpers, they were tattered and rusted everywhere. I treated them with some commercial degreaser / Scotch Brite Pads (stainless steel safe), and then finished them off with coats of chrome polish and buffing. Turned out awesome!
Next the Stand, Intake Manifold, and Intake Tubes. These guys were almost caked over in grease and rust. It took days of degreasing and sanding to get them ready to paint. They took great to the paint, I did 3 coats of primer, and 4-5 top coats. This is also the same color I will be painting the engine block.
The Exhaust had a lot of surface rust, and just looked nasty and caked over with grease. Same method here, lots of cleaning and sanding. Painting method same, turned out nice.
I'm real proud of these heat exchangers. They looked just plain disgusting when they came off the engine. Tons of caked on grease, surface rust, spots. Same method here as before, they turned out smooth as glass.
The gas tank was quite a job. Lots of surface rust on it, glue, and did I mention grease???
Hope you guys liked seeing some of my progress, it's been a labor of love so far and I've really enjoyed it!  _________________ -JeRmAn-
-Alabama-
JeRmAn Samba Member
Posted: Thu Oct 11, 2012 4:35 pm Post subject: |
| mnussbau wrote: | | Great job! |
Thanks Mike! I was beginning to wonder if I was gonna get any feedback.
This bug was so dirty and greasy when I got it, inside, outside, every side. It's been amazing to uncover it all and see what a solid little bug I have here. Maybe someday mine will be somewhere near the condition of your 74's. Thanks again! _________________ -JeRmAn-
-Alabama-
JeRmAn Samba Member
Posted: Fri Nov 09, 2012 2:34 pm Post subject: Vacation Work |
So this week I have been on a "staycation" vacation from work. I've had the house to myself all week, so naturally I've been hard at work on the beetle. It's simply amazing how dirty this little car was underneath. From the front to back axle, cv joints and all was incredibly greasy, dirty, and nasty. So I've been under the car all week cleaning it all out. It also had some aftermarket undercoat spray all in the wheel wells/fenders, and it was done terribly. To top it off it was extremely dirty and filled with spider webs and wasp nest. I had to scrap it off with a puddy knife, and then cleaned it all down. This took a lot of elbow grease and a few hours of work! While under there I found the source to a lot of my grease issues around the transmission....a completely loose CV joint.
Does anyone know what size star bit works in the bolts that surround the CV Joint? My bolts were all loose and there was massive leakage as you would imagine.
Second question. Is this transmission fluid leaking from here? And whatever it is, how would I check or refill the level?
I also took off the poorly mispainted/primed glove box door, as well as the depth trim around the speedometer. Sanded, primed, and painted both black. Should be a massive improvement on the dash.
Recently ordered parts include an original '74 vac distributor in good clean working order. Also a pair of black rear interior panels off a 73 super beetle in great shape.
This beetle is coming along somewhat slower because I am rebuilding it, replacing a lot of pieces, while doing a light rebuild on the engine. My budget is exactly what the budget would be for any hard working married man that is starting a family.
Thanks for any answers! I'll get more photo's up when I get a new digital camera. _________________ -JeRmAn-
-Alabama-
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 435 Location: Pennsylvania
Posted: Fri Nov 09, 2012 4:10 pm Post subject: |
| Take your time and do it right. you won't be sorry. Rome wasn't built in a day. |
JeRmAn Samba Member
Posted: Sat Nov 10, 2012 6:46 pm Post subject: |
| mnussbau wrote: | | CVs are held on with a 12 point star (triple-square) tool, 8mm..... |
Mike, thanks for the amazing help. It's so nice having people like you who will share such useful and helpful information on here. Thanks for going to the trouble to include the links! Now that I saw the diagram I know exactly where everything is located and it should be pretty straight forward now. Lord knows I've spent enough time down there this week.
| Dwayne1m wrote: | | Rome wasn't built in a day. |
Funny you say that, I just said that same thing to myself today. I've made a lot of progress however. I've painted the speaker grills on the dash, the speedometer surround, and the glove box all with semi gloss black paint. An extremely nice upgraded look to the already black/white interior. _________________ -JeRmAn-
-Alabama-
