Arnolds64 Samba Member
Posted: Wed Jul 11, 2012 8:48 pm Post subject: Daikin! |
Holds like glue with my 2017 at about 140hp? Second gear shift it hooks hard with no slip. _________________ 64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Wed Jul 11, 2012 11:21 pm Post subject: Re: What clutch disc to use with a Kennedy Stage 1.. |
vwracerdave wrote: |
You DO NOT have enough HP to need a $120 Centerforce or Copperhead disc. |
Centerforce disc is specified for 120 HP+. I've also used it with 100 HP...works well and you can keep using it later on, if you up the HP even more. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Stuntmanus Samba Member
Joined: December 24, 2006 Posts: 303 Location: Hungary
Posted: Thu Jul 12, 2012 6:23 am Post subject: |
Splitdog wrote: |
Daiken all the way. 180 hp turbo and I love it. With Kennedy stage II. |
With or without spring dampers? _________________ Stuntmanus
1974 VW 1303 RS 2110
1972 VW 1302
"Look man, I am not Mr. Lebowski, I am the Dude...!" |
flatfour Samba Member
Posted: Thu Jul 12, 2012 6:54 am Post subject: |
Where is the place to get the Daiken disc. You don't see it in many of the online stores unless it is named something else. I got one years ago at the local VW shop but they have since closed. _________________ '68 Bug
'74 Ghia |
Posted: Thu Jul 12, 2012 7:09 am Post subject: |
flatfour wrote: |
Where is the place to get the Daiken disc. You don't see it in many of the online stores unless it is named something else. I got one years ago at the local VW shop but they have since closed. |
http://csp-shop.com/cgi-bin/cshop2/front/shop_main...0&all=
This is one of the best and most expensive parts store of Europe.
Customspeed parts _________________ Stuntmanus
1972 VW 1302
Hotrodvw Samba Member
Posted: Thu Jul 12, 2012 8:57 pm Post subject: |
Itisa1835 wrote: |
Never, never use a Kush with a Kennedy, unless you are practicing for how fast can you pull a engine contest |
Explain.....
I"ve been running a Stage 1 with a Kushlock for 3 years now, works great on the street, holds the power even when racing, looks great when I pulled the motor. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Thu Jul 12, 2012 9:18 pm Post subject: |
Stuntmanus wrote: |
Splitdog wrote: |
With or without spring dampers? |
Without.
It's in a split so I don't do hard 1st gear launches or burnouts (unless I'm in the water, then 2nd gear is a good thing!). _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
jackro Samba Member
Joined: August 14, 2007 Posts: 192 Location: Rochester, NY
Posted: Thu Aug 30, 2012 8:01 am Post subject: |
OK -When would you use a clutch without dampers? |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Thu Aug 30, 2012 9:26 am Post subject: |
In 2004 I installed a new Daikin disc and stage I P/P in my street legal dunebuggy with a 125 HP 2007cc. I have 375 passes down the drag strip and 15,000 street miles on it. Last week at the drags the diaphram on my Kennedy finally gave up and broke. I measured the thickness of the old Daikin disc at .330". I measured a new Daikin disc and it was .360" thick. I reused the old Daikin disc with a used stage I P/P I had and put it back in. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
jackro Samba Member
Posted: Thu Aug 30, 2012 10:24 am Post subject: |
Once again- Thanks guys!
Jack |
Itisa1835 Samba Member
Joined: September 02, 2011 Posts: 123 Location: Norco
Posted: Thu Aug 30, 2012 12:39 pm Post subject: |
Daiken with Springs.... |
