thingguy Samba Member
Posted: Tue Jun 26, 2012 12:29 pm Post subject: Anyone ever install an In-Line fuel shut off valve? |
I'm thinking of putting one in the line under my gas tank to make it easier to do maintenance that requires tank removal. I will be driving it to and from a friends house soon to have some welding done. He wisely wants the tank removed first. It would sure make things easier if I could limit the amount of gas that leaks out when I removed it.
Thanks!
Scott |
thinghunter Samba Member
Joined: May 18, 2004 Posts: 398 Location: North Texas
Posted: Tue Jun 26, 2012 1:53 pm Post subject: |
| I have an electric fuel cutoff that shuts off the fuel when the key is turned off. I installed it thinking it might help if ever I had an engine fire based on a fire I had on my 66 bug in high school where the tank was not bolted in and I just pulled it out and the fire went out by itself. Never been tested out but it's a good theory. I don't know where I got it. All I know is it was from some Model T parts supplier that sends me a very nice expensive looking parts catalog every year now, even though I have contacted them and told them I don't have a Model T. |
mikemcbride Samba Member
Joined: February 22, 2012 Posts: 83 Location: Hillsboro, Oregon
Posted: Tue Jun 26, 2012 2:01 pm Post subject: |
I have one on my Sandrail. And since I run it once or so a month I'll turn it off before the engine is off and let it use the remaining fuel in the line then it doesn't get gummed up in the carb or whatever _________________ 1968 VW Baja D.D.
1971 VW Baja (in progress) roof chopped!
1967 VW Sandrail
1961 VW Sandrail
1964 VW WFG Mountaineer |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1273 Location: Columbia, CA
Posted: Tue Jun 26, 2012 2:43 pm Post subject: |
The outlet merely screws on the bottom of the tank, just get a valve that screws in.
Years ago on my type 2 I had a quick disconnect coupling that shut off fuel flow on both couplings when disconnected. Looked much like air compressor fittings. _________________ 74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6 |
guppysoup Samba Member
Joined: June 07, 2003 Posts: 273 Location: Jalisco, Mexico
Posted: Tue Jun 26, 2012 3:20 pm Post subject: |
I have a inline (close to the tank) small ball valve on both my VWs. Just put hose barbs on both ends. Cheap and easy and it hasn´t failed me yet. _________________ 1973 Thing/Safari
1984 GMC Suburban 1500 4x4 6.2 diesel
1985 Bug/Bocho class 11
1995 Chevy Suburban 2500 4x4 6.5 diesel
2003 Jetta TDI |
Posted: Tue Jun 26, 2012 4:11 pm Post subject: |
| You think a 1/4" clamped valve would work, or would it be too big? |
Posted: Tue Jun 26, 2012 4:25 pm Post subject: |
I´ve never used a clamp valve so I can´t say. _________________ 1973 Thing/Safari
2003 Jetta TDI |
Posted: Tue Jun 26, 2012 4:27 pm Post subject: |
OK, OK....1/4" valve (clamped)?  |
74 Thing Samba Member
Posted: Wed Jun 27, 2012 7:40 am Post subject: |
| 74 Thing wrote: | | http://cbperformance.com/catalog.asp?ProductID=585 |
Do you have an inline shut off valve or one installed on the bottom of the tank? Or either?
Thanks for the link!
Scott |
Posted: Wed Jun 27, 2012 8:22 am Post subject: |
The one I used is just like the 6545. I think the 6542 might be a better fit as it looks smaller and more compact. _________________ 1973 Thing/Safari
2003 Jetta TDI |
Posted: Wed Jun 27, 2012 8:38 am Post subject: |
| guppysoup wrote: | | The one I used is just like the 6545. I think the 6542 might be a better fit as it looks smaller and more compact. |
Does the 6542 go in the bottom of the tank or inline? It looks like it is made more for a direct fit to the tank. |
rsorak Samba Member
Posted: Wed Jun 27, 2012 9:33 am Post subject: |
Its hard to tell from the picture but I would think it could be adapted to the tank bottom. _________________ 1973 Thing/Safari
2003 Jetta TDI |
citroen Samba Member
Joined: February 28, 2010 Posts: 812 Location: louisville ky
Posted: Wed Jun 27, 2012 6:25 pm Post subject: |
just use the stock one off a 356 porsche or a early pre 60 bug that way you have a reserve and a shut off it fits the stock thing tank
Yarkle Samba Member
Joined: August 03, 2009 Posts: 482 Location: the Hills of Western Maine
Posted: Thu Jun 28, 2012 11:18 am Post subject: |
Dennis,
how does that reserve valve work? do you have to have a special tank or does it work with a regular tank? Or does it just pick up gas that the regular pickup wouldnt get? |
Semper_Dad Samba Member
Joined: May 14, 2005 Posts: 2610 Location: HELL Paso, TX
Posted: Thu Jun 28, 2012 11:33 am Post subject: |
| Yarkle wrote: | Dennis,
This should explain everything
http://www.356registry.org/tech/fuel_cock_faq.html _________________ 74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
Washington State 181 (Thing) Registry - current tally: 58
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 98 181s in the world |
Yarkle Samba Member
Posted: Thu Jun 28, 2012 11:57 am Post subject: |
Hmm..well it explains how it works, but does it actually tap into fuel that would otherwise be unavailable?
it is a pretty cool setup. |
Posted: Thu Jun 28, 2012 12:10 pm Post subject: |
| it has 2 pickup tubes 1 lower 1 upper when the fuel level reaches the top 1 you run out of fuel ,switch to the lower pickup. i think it is about 1.8 gals differance. That way you always have 1.8 gals unless you forget to switch the valve back when you fill the tank up. |
BNMike Samba Member
Joined: November 12, 2009 Posts: 270 Location: Hot Springs, SD
Posted: Fri Jun 29, 2012 4:17 pm Post subject: |
Well, boys......
I'm picking up a 356 fuel cock for my '73. Where do you suppose I'd look for the "escutchion" with the lettering?
Thanks,
BNMike |
