vdub13 Samba Member
Joined: January 14, 2005 Posts: 16 Location: Howard, coloRADo
Posted: Thu Jun 28, 2012 4:01 pm Post subject: Clutch Release Ring Doesn't fit over the Guide Sleeve? |
So I have a Issue with the Trans & Motor fitting together due to the fact the Sleeve wont slide into the Clutch Release Ring, What can I do to Fix this Issue? Can I bore out the Release ring so it fits over the sleeve? Or will that cause balance issues??? Any Help Would Be Mucho Appreciated....
Thanks
Vdub13 _________________ VW'z 4 Life |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 1268 Location: sanger ca
Posted: Thu Jun 28, 2012 4:06 pm Post subject: |
| Remove the ring alltogether, the ring is for early trans only |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 1606 Location: Baltimore, Maryland
Posted: Thu Jun 28, 2012 5:27 pm Post subject: |
x2
if you have a sleeve you do not need the ring on the pressure plate. It is removable on the Kennedy clutches. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
Cox Racing Engines
Class 5-1600's; Stock 1600 to 2498cc Type 1's. Custom Built for you in Maryland |
vdub13 Samba Member
Posted: Thu Jun 28, 2012 5:37 pm Post subject: |
| yamaducci wrote: | x2
if you have a sleeve you do not need the ring on the pressure plate. It is removable on the Kennedy clutches. |
What about the springs that hold the ring onto the clutch? _________________ VW'z 4 Life |
Posted: Thu Jun 28, 2012 5:54 pm Post subject: |
| What type of pressure plate do you have? |
vdub13 Samba Member
Posted: Thu Jun 28, 2012 6:42 pm Post subject: |
| mcmscott wrote: | | What type of pressure plate do you have? |
It is a coil spring type clutch... _________________ VW'z 4 Life |
modok Samba Member
Joined: October 30, 2009 Posts: 8632 Location: Colorado Springs
Posted: Thu Jun 28, 2012 7:13 pm Post subject: |
| In that case the thingy is held on by the little springs, you can just pull them back and remove the plate.....easy, now it is converted to fit late models! |
vdub13 Samba Member
Posted: Thu Jun 28, 2012 7:27 pm Post subject: |
| modok wrote: | | In that case the thingy is held on by the little springs, you can just pull them back and remove the plate.....easy, now it is converted to fit late models! |
Sweeeet Thanks My VW Brotha, Hope you are Doing OK down there, Hope your not to close to the fire....  _________________ VW'z 4 Life |
vdub13 Samba Member
Posted: Thu Jun 28, 2012 8:41 pm Post subject: |
Thanks Guys, Motor is Back in and running & shifting fine....
Love The Samba.... _________________ VW'z 4 Life |
