Axle nut removal?
Maddog209
Maddog209 is offline
PostPosted: Fri Jun 29, 2012 2:53 pm    Post subject: Axle nut removal? Reply with quote
Does anyone have a trick or suggestion on how to easily remove the rear axle nut on a Bug? Would PB Blaster or similar product help? I'm using a breaker bar and still no luck other than damn near lifting the rear of the car off the stand.
Current VW's= 2013 Tiguan, 1968 Bug
mondshine
mondshine is offline
PostPosted: Fri Jun 29, 2012 3:22 pm    Post subject: Reply with quote
This subject comes up pretty regularly.
Personally, I'm a big fan of the "torque tool".
Whacking on it (and your wheel bearings) with a hammer might remove the nut, but you probably will want to put it back on; at the correct torque setting.
Buy or borrow the "torque tool".
This thing will make the job 9 times easier.
Since you live in California, there are probably a bunch of these tools within a 20 mile radius of your house; maybe somebody close will chime in.
Good luck, Mondshine
GA_Boy
GA_Boy is offline
PostPosted: Fri Jun 29, 2012 3:26 pm    Post subject: Reply with quote
There are numerous ways-------Did you use the Search engine?
You can take it to a truck tire repair facility and have them loosen with a huge impact wrench and tighten back enough to get you home.
Regular (conventional)threads on both sides------counterclockwise to loosen.
Just remember to tighten to the proper torque when you go back with it.
Marvin
Vinnems
Vinnems is offline
PostPosted: Fri Jun 29, 2012 4:23 pm    Post subject: Reply with quote
You can borrow my Torque Tool if you find yourself around my neighborhood, but I figure you're a bit too north.
RDbugger
RDbugger is offline
PostPosted: Fri Jun 29, 2012 5:26 pm    Post subject: Reply with quote
Removing my one as well. Using blow torch, wax and w40. Soaking it now with W40, wash the w40 off because if you heat it up again.You will get a ball of fire. Laughing
Dismas
Dismas is offline
PostPosted: Fri Jun 29, 2012 5:32 pm    Post subject: Reply with quote
I welded a socket onto the end of a 5' chunk of pipe . . did the job admirably
69/70 chop refurbed from a 70 baja
Maddog209
PostPosted: Fri Jun 29, 2012 6:14 pm    Post subject: Reply with quote
Marvin
DON"T ask me if I used the search engine? I was looking for help in the moment. This isn't my first post or first time on a forum.
I managed to remove the seized nuts with PB Blaster and an impact gun.
Thanks to all for the advice. BTW, the "torque tool" is awesome looking. I will be adding one to my tool collection.
Maddog209
PostPosted: Fri Jun 29, 2012 6:15 pm    Post subject: Reply with quote
Thank you for the offer!!
Cadaver
Cadaver is offline
PostPosted: Sat Jun 30, 2012 10:55 am    Post subject: Reply with quote
John Muir says
a large pipe wrench (or cold chisel ) and a BFH.
that sets one end. for the cheap skate spectrum.
there are 10 ways
which way depends on
your cash flow.
your time line, or down time..
none of which we know.
the right torque wrench is $600 from Proto.
the torque Meister is $60 and beats them all hands down. YES 9 TIMES>
only John wins in the hippy domain./ zero bucks, and fatherinlaws tools.
or better, he gets his "freeloaders to do it" my all time fav, in his book....
getting off is easy ((no pun ,)
back on , a whole other issue.
if done wrong the drums will crack.
and if you look close, do it., imagine if said crack hit a wheel bolt hole.
dont ask. (but lots of photos here to bare witness)
the $5 way < hand drill in hand,
the long angle irons. x2
comes off.
then back on:
a bathroom scale and a Archimedes rule set.
then you weigh your self, (no guessing or fibbing) the placing hands
on the pre marked 300 lbs points.
you drop your body on the bar , exactly THERE. fun yet?
the second locking bar can be skipped (left side example)
with 3 fat chicks in back seat of your FAT CHICK, brakes set, 4 wheels chocked,
nose up hill going off
nose down going on.
it's is urban rumor, the chick way, YFCMV, your fat chicks may vary.
some weekly.
for sale now.
in Samba classifieds....1968 T1.
Cusser
Cusser is offline
PostPosted: Sat Jun 30, 2012 6:09 pm    Post subject: Re: Axle nut removal? Reply with quote
You loosen these with the wheel and tire on the ground. Same for tightening.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
jhvw1976
jhvw1976 is offline
PostPosted: Sat Jun 30, 2012 6:18 pm    Post subject: Reply with quote
*hijacking for a moment..sorry* if anyone near Joplin, MO has one of the torque meister and a torque wrench to let me borrow, barter (I have a 73 seat I'd trade), or rent let me know it would help me out a ton. I lost that stuff a year ago and haven't had $ to replace it.
1976 standard stock FI beetle daily driver
buggy2430
buggy2430 is offline
PostPosted: Sat Jun 30, 2012 6:29 pm    Post subject: Air Impact Reply with quote
Use a impact wrench. It will NOT hurt your car. I've used it for years with NO problems. I even put my flywheel gland nut on with one. I know there are many who will say this is the WRONG thing to do. But it works for me.
Maddog209
PostPosted: Sat Jun 30, 2012 9:24 pm    Post subject: Re: Axle nut removal? Reply with quote
NOT an option with custom wheels.
And, as mentioned above, I was able to get both sides removed with PB Blaster and an impact gun. Upon inspection of the left rear brake I found a 2' piece of the shoe lining broken off and rattling around inside the drum. New shoes purchased and will be installed tomorrow.
Cadaver
Cadaver is offline
PostPosted: Sun Jul 01, 2012 6:08 am    Post subject: Reply with quote
see, the easy part
now to put it back on. Rolling Eyes
for sale now.
Cusser
Cusser is offline
PostPosted: Sun Jul 01, 2012 9:05 am    Post subject: Re: Axle nut removal? Reply with quote
Oh. I can remove the axle nut on my aftermarket wheels with the wheel on.
But first I have to remove the wheel, take off the cotter pin, and remount the wheel. So usually nowadays I just use my electric impact wrench. Note that I'm in Arizona, no rust, and I've owned mine for 38 years, so very few surprises.
Great.
DrummerDaveB
DrummerDaveB is offline
PostPosted: Thu Jul 05, 2012 1:11 pm    Post subject: Reply with quote
Or you can do what I did - Put a ratchet on the nut w/ a 2 foot cheater bar.
Then put in one lug nut to the right side of that.
Then put a big lug wrench on that lug nut,
Then jump up and down on both at the same time, whilst holding your nuts hoping you dont get a cheater bar through them.
Very Happy
79 SB Vert, in pieces.
Kadrons, SVDA.
71superAS
71superAS is offline
PostPosted: Thu Jul 05, 2012 1:15 pm    Post subject: Reply with quote
Very Happy
Buy a cup! [Or athletic protector, or whatever they are called now]
Ahoy! Purple Bug
Vinnems
Vinnems is offline
PostPosted: Fri Jul 06, 2012 6:06 pm    Post subject: Reply with quote
I remember on my 74 trying to get the castle nut off. Had a 36mm socket, two foot breaker bar, and a five foot steel pipe over it. Me and my buddy just ended up bending the pipe Shocked That's when I bought the torque tool posted here, and even with that, I still have to use the cheater bar and a lot of force. The nut wasn't even rusted when I pulled it, just the PO hired a gorilla to put it on, apparently. I used a torque wrench to put them back on. One lined up perfectly, other I had to still do another 1/4 of a turn to get teh cotter pin in. YMMV.
Don't even get me started on the engine gland nut. I had two guys standing on the case and three guys on the five foot pipe to no avail Laughing Laughing Laughing
AggieDave
AggieDave is offline
PostPosted: Fri Jul 06, 2012 6:15 pm    Post subject: Reply with quote
I punch through it with my impact wrench.
If you're rebuilding a car or doing any amount of custom car work you should invest in a decent air compressor and some basic air tools. It will make your life much better. Sure you can do a complete resto on a VW with nothing but a 13mm wrench and some foul German language, but why not make it easier by having tools that help. Shocked Very Happy
flyboat
flyboat is offline
PostPosted: Fri Jul 06, 2012 7:07 pm    Post subject: Reply with quote
With the wheel off and the car on stands, place a crow bar thru 2 of the lug bolts and locked against the ground, then place a 1 7/16 or 36 mm socket and a breaker bar on the nut. Now stand on it. It will come off. If you happen to weigh about 250 lbs, re-install the nut with all your weight placed on the breaker bar at 12" from the socket to get 250 ft lb torque.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
