Anyone have instructions to install gowesty poptop seal?
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
dubbified
dubbified is offline
PostPosted: Sat Jun 30, 2012 10:37 am    Post subject: Anyone have instructions to install gowesty poptop seal? Reply with quote
I have finally mounted my fiberglass top, and was trying to get out of town, thought I had these instructions!
I already have the basket mounted to the van, have the poptop mounted to the brackets, and mated to the van.
The pop top also has the primary seal along the lower edge,
I need to know how to cut/glue the FLAT seal along the front leading edge.
Also, unsure where to trim to make this all work..
Pictures are most welcome!
Thanks!!
Al
specialev
specialev is offline
PostPosted: Sat Jun 30, 2012 12:13 pm    Post subject: Reply with quote
Install it first with the excess material and leave some hanging off each edge. Edge with the rounded groove is the side that goes on the fiberglass.
Mark out on the roof where it ends. I use blue painters tape to prevent soiling the roof with contact adhesive in the next step.
Remove the seal and apply contact cement to seal groove and the roof, both sides. Allow to dry. Apply a small amount of cement to groove and install seal. Allow to cure.
Trim seal excess to be flush with edge of roof.
I trimmed the long seal on the roof to overhang the front seal by about 0.1-0.2" and bonded them with contact adhesive.
dubbified
PostPosted: Sat Jun 30, 2012 1:13 pm    Post subject: Reply with quote
Hi,
I understand what you said.
The cargo basket has a seal, which runs all the way back to the trailing edge, my boggle is that, where do I trim the seal?
If I trim the pop top seal flush, then that bulk rests atop of the cargo box seal material, and it causes the fiberglass to bulge, definitely a stressor point.
I wish I had my instructions that came with the top, and Gowesty does not have their writeup in the "Library", will take your advice and wing it..
Thanks!
Al
specialev
PostPosted: Sat Jun 30, 2012 3:06 pm    Post subject: Reply with quote
I trimmed the cargo basket seal at about the point where the contour changes to a slight inboard recess. You can just leave some excess on it then fit the main seal and once you get it all put together you will see where to trim.
PDXWesty
PDXWesty is offline
PostPosted: Sat Jun 30, 2012 7:24 pm    Post subject: Reply with quote
Search...you'll find a couple good posts on this very topic.
http://www.thesamba.com/vw/forum/viewtopic.php?t=495301
This thread has good pictures:
http://www.thesamba.com/vw/forum/viewtopic.php?t=451036
89 Westy 2.1 Auto
dubbified
PostPosted: Mon Jul 02, 2012 5:07 pm    Post subject: Reply with quote
pics definitely showed my lack of understanding..
I ran the basket seal all the way back, so all that extra rubber was my problem!
Thank you!
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
