britegreenVWSB Samba Member
Joined: June 13, 2004 Posts: 315 Location: Western Washington State
Posted: Sun Jul 01, 2012 10:00 am Post subject: Piston Notching for Valve Clearance: When Is It Needed? |
I'm assembling a 2276. The deck height is at about .058", combustion chamber cc's about 60. I'm using a SLR XR 302 cam which has a lift at the valve of .529". Should I worry about piston to valve interference with this? Is it really necessary to clay the pistons and check? Thanks.
TG |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8514 Location: SHALIMAR ,FLORIDA
Posted: Sun Jul 01, 2012 10:03 am Post subject: |
probably not but it's always a good idea.I would bring that deck down to about .035-.040" unless you using a forced induction.
usualy unless your heads have been milled a good bit your good to go. |
nsracing  Samba Member
Joined: November 16, 2003 Posts: 5451 Location: VIRGINIA
Posted: Sun Jul 01, 2012 12:12 pm Post subject: |
It is ALWAYS part of the build to check valve-to-piston clearance if you are installing larger than stock cam.
You want to find out if the valves are going to hit the pistons during the build and not during the running. _________________ "A free people can only afford to make this mistake ONCE."
"..from my cold dead hands."
"An unjust law is no law at all." |
modok Samba Member
Joined: October 30, 2009 Posts: 8629 Location: Colorado Springs
Posted: Sun Jul 01, 2012 12:29 pm Post subject: |
| you could also assemble the thing with light checking springs and turn it over 10 degrees at a time and see how much extra travel the valves have. Just push on them and see if how far they go before they hit the piston. |
neil68 Samba Member
Posted: Mon Jul 02, 2012 4:26 pm Post subject: valve-to-piston clearance |
It really depends on which heads you're using and whether they've been flycut. I've used 044 and JPM heads, both out-of-the-box and later with flycutting. So far I haven't required any piston notching, even with high lift cams such as Engle FK8, Web 251, 226, 86C and JPM cam.
I would recommend that you clay a piston and make certain that you have 2.5-3.0 mm clearance, as the cam timing could also be a factor (ie. advanced or retarded). _________________ Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro |
Posted: Mon Jul 02, 2012 5:06 pm Post subject: |
| cam timing is more a factor than lift!!! |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1612 Location: Grass Pants, Orygun
Posted: Mon Jul 02, 2012 6:03 pm Post subject: |
| mark tucker wrote: | | cam timing is more a factor than lift!!! | X2. Lobe center and advanced or retarded cam timing is a bigger factor than lift. _________________ John Bates
SOVW.org |
Bill271 Samba Member
Posted: Mon Jul 02, 2012 6:09 pm Post subject: |
| X3 if that thing stays open or opens at differant times it will hurt itself |
Joined: August 03, 2002 Posts: 7047 Location: Salt Lake City, Utah
Posted: Mon Jul 02, 2012 7:08 pm Post subject: |
you don't even have to think about this until you have a cam over 270 degrees @ .050" (86C, FK87, etc), OR have compression over 11:1. _________________ Please do NOT send me Private Messages through the Samba PM System (I will not see them). Send me an e-mail to john at aircooled dot net
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net |
