scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Wed Mar 16, 2016 1:56 pm Post subject: Re: 1969 Karman Ghia Build (UK) |
scotty timmerman wrote: |
i had the same problem when i installed the traction bar. i was able to trim the plastic fan shroud on the oil cooler enough to squeeze it in. also my oil thermostatic bi-pass valve goes on the oil filter mount.
I like the idea of the bi-pass going on the oil cooler mount thanks _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Thu Mar 17, 2016 9:07 am Post subject: Re: 1969 Karman Ghia Build (UK) |
Just like to state that two of the most annoying things about refitting an ACVW engine is re-threading the accelerator cable (by feel rather than by sight) and a replacement starter motor that doesn't have the little notch on top, to stop the 'D" shaped bolt from endlessly spinning! _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
mcvick Samba Member
Posted: Sat Apr 09, 2016 4:32 pm Post subject: Re: 1969 Karman Ghia Build (UK) |
A very valuable, well done documentary of a sharp ride |
Posted: Tue Apr 26, 2016 1:52 pm Post subject: Re: 1969 Karman Ghia Build (UK) |
Cr@p Spring washer broke on 3,4 luckily it stayed in the rocker cover. Should replace with solid shaft in the long term but the standard ones will go back on for now _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
c21darrel Samba Member
Posted: Wed Apr 27, 2016 2:30 pm Post subject: Re: 1969 Karman Ghia Build (UK) |
Rebuilt the rocker assembly with a new spring washer, then stumbled onto the next problem. When I took the rocker cover off, all but one of rockers were closed completely. I tried to open the gaps but the adjusters wouldn't move enough. On closer examination there were some pedestal shims in place but not it seems the right amount. I added another 0.015" and the adjusters now gap up to 0.006" nicely.
It seems there's still plenty for me to learn new things about ACVW every time I tinker with mine
Who knows, if the rockers didn't have any clearances then the valves may not have been sealing fully when closed at higher revs. It'll be interesting to see if this makes a difference now. _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Thu May 19, 2016 3:30 am Post subject: Re: 1969 Karman Ghia Build (UK) |
carl4x4 wrote: |
Who knows, if the rockers didn't have any clearances then the valves may not have been sealing fully when closed at higher revs. It'll be interesting to see if this makes a difference now. |
In a true case of "a little knowledge his a dangerous thing" it turns out that I have chromoly pushrods (steel) which need to be adjusted to 0" free when cold (no gap but pushrods can still spin). Add this to a dodgy starter motor causing an interesting noise that needed hunting down, plus some impromptu open-tunnel surgery to re-weld the front and mid clutch tube welds and it's been an interesting few weeks.
Finally all tucked up and back on the road
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu May 19, 2016 5:15 am Post subject: Re: 1969 Karman Ghia Build (UK) |
Did you butt weld those windows in the tunnel closed again? If not you have taken a fair bit of strength out of the chassis in the event of a serious crash. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Thu May 19, 2016 10:41 am Post subject: Re: 1969 Karman Ghia Build (UK) |
Mellow Yellow 74 wrote: |
Did you butt weld those windows in the tunnel closed again? If not you have taken a fair bit of strength out of the chassis in the event of a serious crash. |
Yes they've both been welded up again ! _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Thu Sep 01, 2016 5:00 am Post subject: Re: 1969 Karman Ghia Build (UK) |
Just a quick update, in a short while the Ghia will be going up for sale. Just need to do a couple of odd-jobs like replace a tempremental relay and adjust the steering stops on the rack before advertising it.
It's been a blast and I've enjoyed Ghia ownership greatly but it's time for a new challenge - not straying too far as I've started the hunt for Porsche 914 which I can use to compete in Autocross so I will still be hanging around TheSamba The hardest part will be coming up with a price for my Ghia ! _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Mon Sep 05, 2016 1:29 am Post subject: Re: 1969 Karman Ghia Build (UK) |
Thanks guys, happy to assist in shipping to Australia / NZ / South Africa etc. if needed, interestingly a lot of the old UK sports cars have been making thier way over to Japan (also a Right hand drive market) in the last few years. _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Thu Sep 15, 2016 1:44 am Post subject: Re: 1969 Karman Ghia Build (UK) |
Well it looks like I'm going to be around this forum for a while longer the family have pursuaded me to keep the Ghia and put her into storage for a time _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Thu Sep 15, 2016 6:32 am Post subject: Re: 1969 Karman Ghia Build (UK) |
carl4x4 wrote: |
Thanks guys, happy to assist in shipping to Australia / NZ / South Africa etc. if needed, interestingly a lot of the old UK sports cars have been making thier way over to Japan (also a Right hand drive market) in the last few years. |
never been to Japan but I know a LOT of VW's have left the U.S. and gone over their, I think my beloved bus is their now....
excellent car you built there.... I hope someone in the U.S. snatched it _________________ BUS WANTED: 13 window BUS any year considered.. |
LCDR O Samba Member
Joined: July 03, 2016 Posts: 46 Location: Isabela, Puerto Rico
Posted: Fri Jun 29, 2018 7:25 pm Post subject: Re: 1969 Karman Ghia Build (UK) |
What's the colour paint code? |
