1969 Karman Ghia Build (UK)
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 9, 10, 11  Next
carl4x4
carl4x4 is offline
PostPosted: Mon Mar 31, 2014 2:03 pm    Post subject: Reply with quote
Lot's of small jobs getting done over the last few weeks, The biggest was the gearshift bush which took a good afternoon to complete. Been concentrating on the engine wiring, starter, gauge senders, fuel system, ignition timing etc.
New bush & Vintagespeed 356 shifter:
New re-routed wiring to the starter from battery relocated to under rear seat:
New Spax adjustable shocks fitted to match the rates of the Red9 front ones:
Aluminium Sill plates fitted, to hide the main front/rear loom
And perhaps the biggest pain in the ar$e job which was haiving to re-do the front flexi brake pipe mountings. Rolling Eyes I went to bleed the air from the brakes and noticed the flexi lines were under strain. So out came the fuel tank (again!) empty the brake system, move the brackets, get some new hard lines made up to 25mm longer, fit those, (if only I'd tested at full lock the first time Rolling Eyes )
1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight=
carl4x4
carl4x4 is offline
PostPosted: Thu Apr 03, 2014 2:16 pm    Post subject: Reply with quote
When I was looking for something else in the garage last night I stumbled across these Carello fog/driving lamps I bought at an autojumble a while ago and forgot about. Only paid a couple of £ for them and stored them away without much thought.
Anyway I Googled them this morning and found that not only are they the right age for the car, they were used on old Lancias, Maserati's, but more importantly are the same type as fitted to Herbie, in Herbie goes to Monte Carlo (ok so perhaps this model has a slightly different lens)
Anyway I mocked one up tonight on the car with a temporary bracket, the lens needs cleaning inside & out but I think it suits the car and it's nice they are period correct and didn't cost me an arm & a leg! Smile
mountainkowboy
mountainkowboy is offline
PostPosted: Thu Apr 03, 2014 3:07 pm    Post subject: Reply with quote
NICE! Would love to find a set for mine.
Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater"
sputnick60
sputnick60 is offline
PostPosted: Fri Apr 04, 2014 5:09 am    Post subject: Reply with quote
Very illuminating. I like them
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
c21darrel
c21darrel is offline
PostPosted: Fri Apr 04, 2014 11:03 am    Post subject: Reply with quote
I like the shifter AND the lights. Might like the lights even more if you painted the lenses yellow Smile
GhiaBuild
1967 DC build
carl4x4
carl4x4 is offline
PostPosted: Fri Apr 04, 2014 2:33 pm    Post subject: Reply with quote
Funny you should say that, I had considered re-coating the lens yellow
FRNKNSTNGHIA
FRNKNSTNGHIA is offline
PostPosted: Fri Apr 25, 2014 3:58 pm    Post subject: Reply with quote
did you trial fit them on the inner bumper. Between the over riders?
carl4x4
carl4x4 is offline
PostPosted: Fri Apr 25, 2014 4:14 pm    Post subject: Reply with quote
Yes I did, not sure I liked it though...
carl4x4
carl4x4 is offline
PostPosted: Sat Apr 26, 2014 12:37 pm    Post subject: Reply with quote
I'm now at the stage where I definitely am getting pi$$ed off doing wiring. Spent another 6 hours on it today and a similar amount during the week. I know I am getting somewhere but there's not much to show for it when you do wiring! Crying or Very sad
This will teach me to completely re-wire the car plus change all the instruments to 914 ones, change the horns & switch, convert washers to electric, plus change from Generator to Alternator, and move the battery under the rear seat all at the same time.
I must have been mad, all that on a UK car that no proper wiring diagram exists (not that it would have been much use looking at the list above!)
Laughing Laughing
carl4x4
carl4x4 is offline
PostPosted: Sat May 10, 2014 2:18 pm    Post subject: Reply with quote
Been spending a lot of evenings on the Ghia recently with quite a lot of progress.
Engine & rear of car wiring, fuel & plumbing is all complete now, just a vacuum advance pipe left to fit.
Interior is now finished, treated myself to my favourite period steering wheel, a Momo Prototipo with quick release for added security. (this photo angle makes the seat base look bigger than it is!)
And the wiring is now almost complete, just the main battery feed left to splice into the main loom under the rear seat, waiting on me buying some 7mm 50 amp wire to complete the job. The combination of being a RHD car with no published wiring diagram, plus changing to alternator, moving the battery location & fitting Porsche 914 dials has meant the wiring has taken what seems like ages to do. Brakes will hopefully get bled next weekend then the fuel tank can go back in (keeping it out for now just incase any of the new brake lines/junctions need tweaking)
And for safety I also fitted a third brake light today inside the engine grill
very unobtrusive when it's not on Smile
motorhead364
motorhead364 is offline
PostPosted: Sat May 10, 2014 3:18 pm    Post subject: Reply with quote
Very nice
63 ghia coupe
FRNKNSTNGHIA
PostPosted: Sat May 10, 2014 6:01 pm    Post subject: Reply with quote
Nice ghia... Ours will be somewhat similar interior wise.. I will also be running the Momo Prototipo but in brushed aluminum, as well I will be running Porsche 356 Speedster gauges. I like your shifter, I have the 13" Empi for now but will upgrade to a Vintagespeed eventually... I like the 356 version you have...
What quick release did you use?
ScottDoonan
ScottDoonan is offline
PostPosted: Sat May 10, 2014 11:29 pm    Post subject: Reply with quote
Very clean, nice work. Me likey a lot.....
If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2
carl4x4
carl4x4 is offline
PostPosted: Mon May 12, 2014 6:18 am    Post subject: Reply with quote
It's a snap-off quick release with a lock;
carl4x4
carl4x4 is offline
PostPosted: Sun May 18, 2014 1:55 am    Post subject: Reply with quote
It lives !
Spent a great day Saturday and managed to get the brakes all finished, bled, fuel tank back in, wiring finished, put some fuel in her, then managed to get the engine started Cool Cool
Took lots of attempts, my wise old Uncle was there to help me and he took 14 videos of failed attempts at starting before she sprung into life, timing was a challenge without points but we did it the crude way of timing to 0 degrees from the coil wire sparking on the alternator when at tdc to get it started. (then set it when running with a strobe light) Then we had a problem with not enough fuel until I raised the pressure on the fuel regulator.
Also managed to drive it up & down the drive so I know 1st & reverse work now Laughing
Running;
One of the outakes...
carl4x4
carl4x4 is offline
PostPosted: Thu May 22, 2014 11:49 am    Post subject: Reply with quote
Had a problem with the turn signal warning lights flashing only once then not at all. Found the answer here: http://www.thesamba.com/vw/forum/viewtopic.php?t=375700 the front bulbs were the wrong wattage.
Proves what a great resource TheSamba is Smile
carl4x4
carl4x4 is offline
PostPosted: Sat May 31, 2014 1:46 pm    Post subject: Reply with quote
Decided to polish up the old licence plates to see if they would come up to scratch, bit of metal polish on the letters and three coats of wax to bring up the background and the result was quite surprising !
Also cleaned up the driving lights and made some mounts that use the existing bumper bolts so I don't have to drill through the bumper
carl4x4
carl4x4 is offline
PostPosted: Thu Jun 05, 2014 9:43 am    Post subject: Reply with quote
Well the Ghia saw the light of day today with a visit to Novatech in Slough, nice guys who checked over the fuel system, sorted out the carbs & timing for me & have set it up & jetted it at the moment for running in. I'll go back after it's run in for another tune up & a more aggressive setup. But for now it's making 90bhp with a nice healthy 125lb ft torque that comes in quite low down the rev range which is useful. probably be closer to the magic 100 when it's loosened up Very Happy
c21darrel
PostPosted: Thu Jun 05, 2014 10:04 am    Post subject: Reply with quote
Congratulations!
Must be nice for you to be on the road. Low end is where its at for a street car. Much more useful powerband. I remember you are 76 stroke and 90.5's. What cam?
GhiaBuild
1967 DC build
carl4x4
carl4x4 is offline
PostPosted: Fri Jun 06, 2014 7:52 am    Post subject: Reply with quote
It's been a while since the engine was built, I'd have to look up what the cam is.
Took the car for its MOT today, and passed Very Happy Very Happy (this is a big thing in the UK Wink just need the paperwork through from the Insurance and I can tax then drive it
Page 6 of 11
