ACVWB Samba Member
Posted: Thu Jul 05, 2012 12:14 pm Post subject: Schnorr Washers |
Well I am almost finished rebuilding my cv joints and I am ready to reassemble. When I took my CV joint bolts out, there were not any schnorr washers or any type of washers on the bolts for that matter. From what I have heard, VW originally put schnorr washers between the bolt and the CV boot. I would like to but the get some schnorr washers to put back in place but my local fastener stores do not carry them in stock. This only poses a problem as I am trying to make a VW show this weekend and need to get the car reassembled. Is it imperative that I wait and get the schnorr washers or could I use lock washers temporarily or could I use some Loctite blue or even just put the bolts back in the way they were with nothing on them. Any advice would be appreciated. |
Randy in Maine Samba Member
Posted: Thu Jul 05, 2012 12:35 pm Post subject: |
Order up the washers from McMaster and put them on when you get back from your show. |
71superAS Samba Member
Joined: February 02, 2012 Posts: 223 Location: New York
Posted: Thu Jul 05, 2012 12:40 pm Post subject: |
The washers just help to seal in the grease and seal out the dirt.
You can run without them, just make sure to check your seal. If you have something you can seal them up with in the meantime, do it. You don't want to have to regrease your joints just because you drove to a show. _________________ Ahoy! |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Jul 05, 2012 12:42 pm Post subject: |
It's been a while since I worked on an IRS Bug, but there should definitely be washers there. In addition, under the washers there is a plate which spans every two bolts; i.e. there are three plates on each CV joint.
The Bentley manual just says "lock washer", but the picture is too small for me to make out what kind they are. I think I've just used regular spring-type split lock washers in the past, but maybe someone else can chime in. |
Posted: Thu Jul 05, 2012 12:45 pm Post subject: |
Schnoors give a better seal and the ribs give a very strong grip, but they are one-time usable. Once you undo the bolts, you need new washers. _________________ Ahoy! |
Posted: Thu Jul 05, 2012 12:50 pm Post subject: |
The washers actually provide better "bite" into the harder metal torque spreader bars and help maintain the correct torque on the bolts.
I would go to the show without them but would have my correct 8mm triplesquare socket and torque wrench with me. Check the torque after about 100 miles or when you get to the show. |
Posted: Thu Jul 05, 2012 12:58 pm Post subject: |
Randy in Maine wrote: |
Yeah, you should do this even with the washers. Sometimes torquing them wrong leads to them loosening up substantially. Always check your torque after your first mid-length drive!
I had an old, tired, 1987 Corolla for a few months and I had to replace a tire. I didn't check my lug torque after and I had to pull over hard in traffic when my wheel was falling off a couple hours later. _________________ Ahoy! |
ACVWB Samba Member
Posted: Thu Jul 05, 2012 1:01 pm Post subject: |
I will defiantly get the schnorr washers, but to get to the show this weekend what would you recommend? Regular washers, lock washers, loctite or nothing? |
Posted: Thu Jul 05, 2012 1:02 pm Post subject: |
Regular washers will work fine, no loctite or anything needed. Just listen to Randy and bring your torque wrench, check the bolts when you get to the show. _________________ Ahoy! |
ACVWB Samba Member
Posted: Thu Jul 05, 2012 1:05 pm Post subject: |
Thanks guys! |
