door panel- replace pressboard?
Goto page 1, 2  Next
Lil' Lulu
Lil' Lulu is offline
PostPosted: Sat Dec 13, 2008 2:19 pm    Post subject: door panel- replace pressboard? Reply with quote
Has anyone tried to remove the skin from the door panels and replace the pressboard? The skins and armrests on my doors are fine but the part of the board in the footwell is all but gone.
RB
"There's no nookie like Chinookie" Ray Troll
pwilson
pwilson is offline
PostPosted: Sat Dec 13, 2008 4:01 pm    Post subject: Reply with quote
Removing then is easy enough. You just take of the arm rest, window crank, door opener and air vent then pop the panel out. There are a bunch of little clip things that go around the edge of the panel holding it to the door, they just snap into and out of place. I haven't replaced my panels, I had them out for other reasons. I can't imagine them being too difficult to replace, just trace out the old ones and cut new ones, swap clips and skin (or add new skin) and presto!
Phil
Lil' Lulu
PostPosted: Sat Dec 13, 2008 4:48 pm    Post subject: Reply with quote
They're already off. It's just how the pressboard comes off.
pwilson- Have you done this removal and replacement? I'd like to know how you removed the vinyl from the pressboard.
Thanks
VDubTech
VDubTech is offline
PostPosted: Sat Dec 13, 2008 5:05 pm    Post subject: Reply with quote
He already answered your question if you read his post.
The vinyl is heat seamed to the pressboard, it should peel off. If your pressboard is in that bad a shape though, I have to think the vinyl down at the bottom is also. It will be brittle and difficult to work with. I made new panels for my '79 Westy...traced the old ones, cut them out with a jigsaw, made all of the necessary holes and covered them with a purple velvet fabric I bought at Jo-Ann Fabrics and made a nice big white VW symbol using the same pressboard and painted it white, and attached it to the panels. They look good and have served me well for the past 6 or so years since I made them. Reusing the old vinyl will be tough, especially getting it to fold over the edges of the panel and stay without looking like hell. Doable, but probably much easier to either use a new vinyl or fabric.
DurocShark
DurocShark is offline
PostPosted: Sun Dec 14, 2008 11:43 am    Post subject: Reply with quote
What VDT said.
I've rebuilt all the panels in my bus and used the opportunity to make them nicer (IMnsHO).
No boom today. Boom tomorrow. There's always a boom tomorrow.
The Guacamole Bus
Woodscrub's Blog
Buy My Crap
akscooter
akscooter is offline
PostPosted: Sun Dec 14, 2008 11:52 am    Post subject: Reply with quote
My kick panels where peeling back, I used a hairdrier and a heat gun, heat it to the point where you see the vinyl turn glossy and pull slowly. It will come off in one piece if you do it slowly.....mine came off very easily and only pulled in a few small areas..hope this helps.
1975 campmobile
1949 Ply Special Deluxe
1991 Custom 1200 HD Sportster XLH
Lil' Lulu
PostPosted: Sun Dec 14, 2008 2:04 pm    Post subject: Reply with quote
It helps- and thanks. So what I get from your post is the adhesive melt temp is lower than the critical temp of the vinyl.
I really think the vinyl overall is quite good or I wouldn't even try.
Thanks again AK
snotty
snotty is offline
PostPosted: Mon Dec 15, 2008 7:30 am    Post subject: Reply with quote
Thanks again AK
You should be able to peel them off quite easily and glue them to new boardswith contact adhesive.
The biggest problem I found is that the vinyl shrinks over the years and may not have enough stretch to cover new panels properly.
1978 Sage Green Bay
Lil' Lulu
PostPosted: Mon Dec 15, 2008 9:04 am    Post subject: Reply with quote
Thanks Snotty- Did you use heat to remove the vinyl? I wonder if any of the vinyl treatment stuff will restore the stretch.
RB
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Dec 15, 2008 9:46 am    Post subject: Reply with quote
I would suggest using something like Masonite or Baltic birch plywood and I would "seal" the inside with a couple of coats of polyurethane.
The factory set up contained 2 plastic sheets that allowed water to drip down past the window seals and drain out the drain holes in the bottom of the doors. You will have to do a search here but somewhere there is a picture of it.
New vinyl or fabric would not that tough to glue on there if you are so inclined.
busdaddy
busdaddy is offline
PostPosted: Mon Dec 15, 2008 10:13 am    Post subject: Reply with quote
If the vinyl is good and the board hasn't completely disintegrated at the bottom you can get it wet and sandwich it between some plywood with sandbags on it for a week, flattens it out nice. I've saved a few tough ones after that by fiberglassing the back of the panel to stiffen and seal it.
Wanted, 68-73 westy OG plaid curtains, singles OK.
snotty
snotty is offline
PostPosted: Mon Dec 15, 2008 12:05 pm    Post subject: Reply with quote
RB
Nope - they peeled off fairly cleanly, with the backing foam intact. I confess I gave up trying to fit them to new panels (from JK here in the UK) as the vinyl shrinkage had made them too short at the bottom. I was even considering shaving maybe 1/4" off the panels at the bottom, where it wouldn't show.
But...bit of a workout with a hairdryer mebbe before glueing might have done the trick. Should be possible, I'd think.
1978 Sage Green Bay
joe73camper
joe73camper is offline
PostPosted: Mon Dec 15, 2008 1:05 pm    Post subject: Reply with quote
I just replace the masonite on the original door boards with a 3mm plastic called sintra or foamed PVC, from a company called alussuise, peel off the vinyl using water, then clean with pinol or pine sol, then use the old boards as pattern, cut the sintra with jigsaw, drill the holes, glue the vinyl to the new board with super 77 spraymount, and thats it, looks original and it has the benefit that it is moisture free, the problem with original panels is that the fiberboard tends to grow with the moisture and the vinyl tends to shrink with heat, thats why many boards are bended. I just upload pictures at my gallery
http://www.thesamba.com/vw/forum/album_search.php?search_author=joe73camper
View user's profile Send private message Yahoo Messenger Facebook Gallery Classifieds Feedback
moxnix
moxnix is offline
PostPosted: Mon Dec 15, 2008 10:12 pm    Post subject: Reply with quote
In august I scrounged (free) some nice original tan door panels from a parts bus that were perfect except for the very bottom 4-6 inches due to water damage. (as usual) I cut up the repop incorrect black panels that I had in the bus to replace the rotted sections on the originals. I used some heat to peel the skin back and then cut the bad fiberboard out- then fit in fiberbaord patches from the other panels. Used some expanding wood glue and 3m adhesive to make the whole thing solid. Vinyl looks a little wavy , but hardly noticeable. Be sure to replace the batting under teh vinyl or it wont look right. And make sure you put the holes in the right places- measure 2x
Morgen morgen, nicht immer Heute sagen alle faule Leute..
Lil' Lulu
PostPosted: Tue Dec 16, 2008 12:13 am    Post subject: Reply with quote
Thanks again all- The board at the bottom is completely gone for about 4" so I'm going to try taking it off after it gets above 20 degrees (not usual here on the coast) I'll try some of the foamed pvc that Joe talks about.
Believe it or not, the plastic is OK on the pasenger side, so I can see the convoluted way they made the water flow inside the door. I use blue-tac to mount it now that I did the bug and it worked so good.
RB
snotty
snotty is offline
PostPosted: Tue Dec 16, 2008 3:10 am    Post subject: Reply with quote
Obvious point, but when replacing the door cards, refit the plastic membrane/sheet behind them. The window scrapers aren't the best in the world and even with new ones in my experience water still gushes in.
If you've got door speakers, best to arrange the membrane so it's draped over the back of thespeaker.
1978 Sage Green Bay
Lil' Lulu
PostPosted: Tue Dec 16, 2008 9:27 am    Post subject: Reply with quote
Looks like the membrane on mine has two parts, one that goes outboard to drain the water and one that goes inboard to cut off the airflow. They join together about halfway up the door.
busdaddy
busdaddy is offline
PostPosted: Tue Dec 16, 2008 10:12 am    Post subject: Reply with quote
Yep, you need that second flap to divert the water to the outside of the door, if not it all ends up on the mat beside the seat.
IIRC the 72+ vented door membranes had a flap that layed over the door side of the vent, kept water and drafts from coming into the bus.
suzygrnburg
suzygrnburg is offline
PostPosted: Tue Dec 16, 2008 11:15 am    Post subject: Reply with quote
i redid all of the panels in my bus with baltic birch plywood. I think it was 3mm. I still have a few extra sheets if anyone is looking for some. I think i also have the pattern for the front kicks that someone on here traced for me. I can send them out if anyone is interested
Without Love in the Dream It Will Never Come True!
snotty
snotty is offline
PostPosted: Wed Dec 17, 2008 5:51 am    Post subject: Reply with quote
I'm intrigued. the original membranes for my 78 were long gone. You're saying they were in two parts, with the lower part draped inside the door cavity?
Anyone got a pic?
1978 Sage Green Bay
Goto page 1, 2  Next
