Mmuller994 Samba Member
Posted: Sun Jul 08, 2012 6:39 am Post subject: how do i tell what year my front end is |
i have a wide 5 lug drums |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Sun Jul 08, 2012 6:52 am Post subject: |
Find the VIN number and that is PROBABLY the correct year. PROBABLY because how many of us can afford two donor cars when building a buggy? Not a guarantee, but should work for you. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Sun Jul 08, 2012 7:12 am Post subject: |
this is a sandrail so there is no vine i can go buy and it has a aluminum beam |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jul 08, 2012 7:45 am Post subject: |
IT will either be a King & Link or Ball joint.... If its King and Link it will 66 and earlier I believe, Ball Joint first appeared in 67 if I am not mistaken...
Aluminum beam is aftermarket so that is really not a clue....
IF back side of spindles look like this, its a K&L
If back side of spindles look like this, its a ball joint...
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5389 Location: Holland, MI
Posted: Sun Jul 08, 2012 8:46 am Post subject: |
If you have a link pin front end, the passenger side bump stop horn as a code stamped in it. I couldn't tell ya how to crack it, but maybe someone else does. Anyways...this is what it looks like.
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
tdonaldson Samba Member
Joined: February 09, 2011 Posts: 580 Location: Columbus, OH
Posted: Sun Jul 08, 2012 11:06 am Post subject: |
Maybe your goal would be important for people trying to answer the question.
Are you ordering tie rods, ball joints, a whole beam, etc?
If the shock mounts are almost straight up and down, its a "king and linkpin" that ran up to 66 or something.
If they bow out a little like gremlin ears, its a balljoint front end.
If your tie rods fit a 17mm wrench on the adjuster they're a 68 type style tie rod.
If you're buying ball joints, you probably have a balljoint front end.
Wheel bearings relate to the spindle. I have 5 lug fronts on a ball joint beam wit the 68 style tie rods.
Bushings and bearings are probably specific to either balljoint or linkpin. _________________ "If you had a beer can in your hand the beer would have stopped it, alcohol is a natural force of good that keeps you from getting hurt, unless you're city people...." |
vingsthing Samba Member
Joined: February 28, 2012 Posts: 54 Location: Tucson, Az
Posted: Sun Jul 08, 2012 11:51 am Post subject: |
If it has an aluminum beam, it's an aftermarket part. I don't know that I have ever seen an aluminum ball joint beam, so my guess is that it would be a link pin beam. And seeing that it's an aftermarket part, it would be nearly impossible to tell the "year". |
mrbajadude Samba Member
Joined: July 12, 2002 Posts: 148 Location: Yerington, NV, home of the VORRA 300 mile off road race
Posted: Sun Jul 08, 2012 3:42 pm Post subject: |
If the shock towers are straight up, it's king/link pin. And if curved, ball joint. First ball joiint was '66(5 lug) as well as the '67. 4 lug was in '68. _________________ Panic, Chaos and Disorder, My work here is done! |
