1973 VW Super Beetle - Pictures
Molly1973
Molly1973 is offline
PostPosted: Thu Jul 12, 2012 8:24 am    Post subject: 1973 VW Super Beetle - Pictures Reply with quote
Here she is ($4000 - 500 miles on engine and transmission...new tires...new interior):
1973 Volkswagen Super Beetle
Restification = restoration + modification
dubllyou
dubllyou is offline
PostPosted: Thu Jul 12, 2012 9:14 am    Post subject: Reply with quote
Looks nice! Do you know what those front seats are out of? They seem to fit good and look pretty comfy..
Two wrongs don't make a right...
three lefts do.
Wade
vwo60 wrote:
You cannot polish a turd, but you can roll it in glitter.
bandi
bandi is offline
PostPosted: Thu Jul 12, 2012 9:24 am    Post subject: Reply with quote
Just get that fuel filter out of the engine compartment Smile
'52 Zwitter deluxe, '66 Bug, '69 Sunroof Bug, a pair of '71 Supers, '72 Baja Champion SE, '73 Standard, '73 Cabrio, '74 Love Bug, 2 '74 Supers, '74 Sun Bug, '75 La Grande Bug, '83 Mexi Bug, '99 New Beetle, etc.
View user's profile Send private message MSN Messenger Facebook Gallery Classifieds Feedback
DesertBob
DesertBob is offline
PostPosted: Thu Jul 12, 2012 9:26 am    Post subject: Reply with quote
Really nice start! Dump that 009 distributor and get an SVDA and you will be very happy. Also get rid of the gas filter in the engine compartment. You don't want your new baby to catch fire. I typically run mine were it comes out of the wishbone and above the CV joint.
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around.
ROCKOROD71
ROCKOROD71 is offline
PostPosted: Thu Jul 12, 2012 9:56 am    Post subject: Reply with quote
no half moon vents and a 60s style radio antenna? you got a semi-back dated super franken-bug! getting rid of the vents is a good thing though, as cancerous rot starts there, yours was probably repaired already and eliminated. car looks sweet though, can't get one like that around these parts for that price!
1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI **de-hippifying process ongoing** http://www.thesamba.com/vw/forum/viewtopic.php?t=541788&highlight=krustykamper
***Internet pan-handling for my sick cousin: http://www.thesamba.com/vw/forum/viewtopic.php?t=669826
THANK YOU SAMBA***
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy**
CarlIseminger
CarlIseminger is offline
PostPosted: Thu Jul 12, 2012 10:01 am    Post subject: Reply with quote
Did you do the interior? I would like to know how the headliner was done. I want to do something similar to mine.
Molly1973
PostPosted: Thu Jul 12, 2012 10:05 am    Post subject: Reply with quote
Thank you for the compliments! The interior was completely done by the previous owner, so I don't know where the seats came from or how the headliner was done. Sorry about that!
Can you show me a picture of where you put the fuel filter? I am not very technica (009 distributor vs. SVDA - not sure what you mean or what the difference is?l. Embarassed
dubllyou
dubllyou is offline
PostPosted: Thu Jul 12, 2012 10:19 am    Post subject: Reply with quote
The 009 distributor was originally intended for stationary motors used in industrial applications and is mechanical advance only. It doesn't work as well as the one that was originally in your car. SVDA stands for Single Vacuum Dual Advance and has vacuum as well as mechanical advance mechanisms = better performance under general driving conditions. The best place for the fuel filter is OUT of the engine compartment. Some people put it up front where the fuel line exits the gas tank under the car, others put it in front of the motor by the left axle where the fuel line exits the bodywork. More important is that the fuel lines and all connections are inspected regularly. (The best place for the filter as far as keeping crud out of the carb is "last in line" or right before the carb...."catch 22")
three lefts do.
Wade
Molly1973
PostPosted: Thu Jul 12, 2012 10:32 am    Post subject: Reply with quote
Thank you for the explanation on that. I like the idea of having the fuel filter right behind the engine compartment, as you stated. Ideas on where I can pick up the appropriate fuel lines as I will need new ones to make the change, right?
oldPSUguy
oldPSUguy is offline
PostPosted: Thu Jul 12, 2012 11:02 am    Post subject: Reply with quote
Looks like a nice straight driver. My VW mechanic says that keeping the fuel filter replaced periodically, and the lines close to it inspected, is most important. Your car has had trim removed and vents removed but is still essentially stock. Think twice about customizing recommendations. Original beetles are getting hard to come by.
71superAS
71superAS is offline
PostPosted: Thu Jul 12, 2012 12:35 pm    Post subject: Reply with quote
Mehhhhhhhhhh. Aside from the fire risks of the fuel filter in the engine bay, I don't like the idea of sending debris into my fuel pump. That's how you kill them.
That's why I moved mine, more than fire risk. Also installled some NOS german braided fuel line.
Ahoy! Purple Bug
TjdTaylor
TjdTaylor is offline
PostPosted: Thu Jul 12, 2012 1:26 pm    Post subject: Reply with quote
yeah, when i bough the car, mine was between the pump and the carb, obviously in the engine compartment Razz so i moved it behind the firewall and i definately like it there alot better. Looks neater inside the engine and dont need to worrk about fuell pump/fires. If you are REALLY worried about particals, put one underneath the tank and before the firewall.
1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote:
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows
TjdTaylor
PostPosted: Thu Jul 12, 2012 1:28 pm    Post subject: Reply with quote
also, is it a documented 500 or is that what the PO says? Never trust a PO. They are probably going to be full of shit cause they wana get rid of the car.
RDbugger
RDbugger is offline
PostPosted: Thu Jul 12, 2012 1:38 pm    Post subject: Reply with quote
Looks in superb condition just drive it as is then do a restore a couple years or more down the line.
Cool
togatony
togatony is offline
PostPosted: Thu Jul 12, 2012 3:25 pm    Post subject: Reply with quote
I agree, those seats look awesome! If you know or anyone else knows what those seats are out of please post!
GatorJZ
GatorJZ is offline
PostPosted: Fri Jul 13, 2012 5:31 am    Post subject: Reply with quote
Doesn't play well with ethanol.
1973 Sports Bug (Super)
TjdTaylor
PostPosted: Fri Jul 13, 2012 5:53 am    Post subject: Reply with quote
i use an additive that takes away the ethanol. Just acouple cap fulls at each fillup.
71superAS
PostPosted: Fri Jul 13, 2012 6:49 am    Post subject: Reply with quote
I use additives, too, but I will keep an eye on it. I came into a pretty obscene length of it, like 20 feet. Enough to last me years, haha.
Ahoy! Purple Bug
Molly1973
PostPosted: Fri Jul 13, 2012 1:44 pm    Post subject: Reply with quote
It isn't a documented 500 miles...he just said 'roughly'...and the odometer had stopped working, so I had that repaired. I believe the seats say 'Veracruz' on them...if that helps.
wbrown45
wbrown45 is offline
PostPosted: Fri Jul 13, 2012 2:46 pm    Post subject: Reply with quote
Very nice! Have fun driving this summer. I would also suggest carrying a fire extinguisher for the worst case scenarios.
OK Thang
