Extended Full Flow Blocking Pulley
moarlow
moarlow is offline
PostPosted: Thu Jul 12, 2012 10:43 pm    Post subject: Extended Full Flow Blocking Pulley Reply with quote
Hey guys,
I've got an extended full flow that blocks the pulley from fitting in all the way. Is there a trick and a way around this? Do I have to get a different pulley?
Thanks in advance for your input.
FSFTS18Z
FSFTS18Z is offline
PostPosted: Thu Jul 12, 2012 11:00 pm    Post subject: Reply with quote
if its the empi style.... i had to grind the heads of the bottom allen bolts down and drill 2 holes in the tin that sits behind the pulley to keep it from touching
moarlow
moarlow is offline
PostPosted: Thu Jul 12, 2012 11:08 pm    Post subject: Reply with quote
The pulley is hitting the oil pump even without the tin installed. Is there a spacer that can be installed?
I believe the pulley is an Empi style.
FSFTS18Z
FSFTS18Z is offline
PostPosted: Thu Jul 12, 2012 11:12 pm    Post subject: Reply with quote
stupid question but is the pump fully seated
vw_hank
vw_hank is offline
PostPosted: Fri Jul 13, 2012 12:45 am    Post subject: Reply with quote
some people have had to grind down the pump to git the pulley and tin to fit,,, one of the mane reasons i'm not A fan of the pump/filters.
1302s sunroof..
TimsACVW 1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Big thanks to my friends Jes67 & Keoki
