TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Fri Apr 12, 2013 6:05 pm Post subject: Possible 86 in my future |
Going to sell my bay panel (non running) and going to look at a 86 tomorrow.
I searched the forum and did not find anything glaring I should look out for. Feel free to enlighten me. I plan on removing the middle seat using it for camping if I buy it... just would need to throw some curtains in it. The heads have been replaced along with some other misc parts... has some body damage that I can fix or live with.
One question, would I have to replace the ac compressor and assorted parts to for the updated Freon? _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Fri Apr 12, 2013 8:30 pm Post subject: |
Re the body damage: I have almost the same crease. It popped open the seam sealer on the wheel arch, which allowed water into the rocker, now it's rusting out on the bottom. Check the sealant.
To change refrigerant, just put in a new reciever-dryer, and get a R-134 conversion kit, it chemically alters the existing oil to be compatible with the new stuff. Very easy. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
Posted: Fri Apr 12, 2013 8:32 pm Post subject: |
Syncroincity wrote: |
To change refrigerant, just put in a new reciever-dryer, and get a R-134 conversion kit, it chemically alters the existing oil to be compatible with the new stuff. Very easy. |
Many thanks! _________________ Don't harsh my mellow...
1967 Bug- Gone
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Fri Apr 12, 2013 8:46 pm Post subject: |
I have a couple a/c pumps ill sell ya cheap, off my working vans.
86's can either have the early or late style fittings FYI |
morymob Samba Member
Posted: Sat Apr 13, 2013 4:48 am Post subject: |
TequilaSunSet wrote: |
Many thanks! |
R-134 and mineral based oil in there now not compatable, it WILL be be altered for sure to a screwed up snot mess, better read up on this before u do. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Apr 13, 2013 7:03 am Post subject: Re: Possible 86 in my future |
I searched the forum and did not find anything glaring I should look out for... |
Really? You found no mention of leaking heads (yours hopefully fixed - a plus),
manual tranny and/or connecting rods grenading at 150k miles, rear heater leaks,
low oil pressure, brittle plastic coolant tower or thermostat housing, hacked air flow
meter, locked up rear drums, worn throttle body & switch, under rated tires, seized
blower motors, rusted/leaking windshield seals, corroded grounds, cooked coolant hoses...???
None of this? Really?
How many miles on this rig? Manual or Auto?
Oh wait, you're just worried about curtains & the AC.
Never mind - good luck.
PS: Sorry about your mellow... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sat Apr 13, 2013 7:49 am Post subject: Re: Possible 86 in my future |
dhaavers wrote: |
PS: Sorry about your mellow... |
Kinda of tough to look for those issues if ya don't know to look for those issues... thanks for the guiding light.
Mellow not harshed... mellow harshed if I buy a rig with all those problems! _________________ Don't harsh my mellow...
1967 Bug- Gone
bluebus86 Banned
Posted: Sat Apr 13, 2013 10:54 am Post subject: |
the AC hoses if original are likely to need replacement They are long hoses. old hoses tend to leak thru the rubber (millions of little tiny leaks) it may hold the freon for hours or months, but eventually the old rubber hoses will leak thru the rubber. read oup on this site for economical replacemet options. the VW dealer hoses are pricey. other option cost much less. (use of industrial hydrolic hoses )
the 1986 is a great year, you got the biggest motor!!!!
besure to put some seam sealer on the seams in the damaged area aap even if you decide to wait on the repair, you will want to seal to keep water out in mean time. simply painting wont stop the water fom getting into a seam. |
