Chalklinedetail Samba Member
Joined: April 25, 2010 Posts: 311 Location: San Mateo, CA
Posted: Wed Aug 07, 2013 11:37 pm Post subject: |
Not anything too interesting lately...Except for I finally got the front end aligned today! I started out at Fred's Garage in San Carlos, Fred said his "alignment bar" was out of commission (whatever that means). Fred sent me to Speedy Oil and Tune Up. I dropped it off this morning to find out a few hours later that their machine wont fit on my 165 45's. He sent me to Big-O tires where they were finally able to get the job done Great guys, he topped off my grease fittings and checked all my new nuts to be sure that none of them are coming loose, all included in the cost for the alignment. Good experience.
Finally got to rattle canning my windshield wipers today. It was a little drizzly earlier this week and I had them off, realized I should probably get them back on the car
_________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight=
Last edited by Chalklinedetail on Wed Aug 07, 2013 11:57 pm; edited 2 times in total |
I've been reading up on what it'll take to get my fog light finally hooked up, so on the way home I picked up the hardware I think I need to get it to light up; Inline fuses, switch, relay. Will post more pics once I get some light
_________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
grandpa pete Samba Member
Posted: Thu Aug 08, 2013 7:20 am Post subject: |
Why are you grinding on wheels to get "earlier"hubcaps on? ...Please explain......Safety note from the "old guy"who used to work on an ambulance......after working an accident where the suicide knob was stuck IN a drivers skull I would suggest reconsidering having one in your car _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Thu Aug 08, 2013 8:56 am Post subject: |
grandpa pete wrote: |
Why are you grinding on wheels to get "earlier"hubcaps on? ...Please explain......Safety note from the "old guy"who used to work on an ambulance......after working an accident where the suicide knob was stuck IN a drivers skull I would suggest reconsidering having one in your car |
Hey Pete. Is that why they're called suicide knobs?! I will consider your advice carefully.
As for the grinding, the earlier hub caps attach with clips, the 66-67 caps are engaged to formed nubs on the inside lip of the rim. The hub caps are also shaped differently, so to gain the clearance I need for the early caps the nubs have to be ground off and early-style clips installed. Having said that, I'm considering just cleaning up the original smoothies (like the rear). I have all five wheels original to the car in original 2-tone. _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
Posted: Sun Aug 11, 2013 9:59 pm Post subject: |
I decided to try to tackle the fog light now that I have all the parts I think I need...
Started by connecting some 14 ga. wire to the fog light
Fed the wire through the housing
Fed the wire through a tight hole in the bumper, under the bumper bracket and tight up along the hood pull housing to the location where the relay and switch will live
Here is the final look from the front
I reused a couple of existing holes at the underside of the dash to mount the switch and the bracket for the relay
Here's the switch from the inside, I am going to switch attachment of the relay bracket so that the allen head is in the cab and not the nut.
So I got this far and was going to try to wire the rest of it up until I got to the switch and realized that I got a 6 terminal switch. I have to figure out what goes where before I light the car up, the wrong way.
If you have any of the same issues I do, follow this thread. I've gotten some great advice and wiring diagrams here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=563189&highlight= _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
Posted: Sat Jan 11, 2014 11:11 pm Post subject: |
Did a little work on my wheels to get them finished up. I really wanted the 66-67 only wheels with the early caps. I didn't like the color that I had the fronts powder coated, so I ended up just rattle canning the fronts over the powder coating and rears after sand-blasting them.
I have to say, I've really become a fan of a stainless steel spray paint called "Steel It". It's about $20/rattle can, but it goes on so thick, so evenly and does not run. It also has stainless steel powder in it so the sheen on it is unmatched. Really a cool product.
Here is one of the rear wheels before sandblasting
Post-sandblast
Painted. Only required one coat, but I did a second light coat, just to prevent future headache
Drilling for early clips
I will say, it was a bit of a touch and go for me. I bought two different clip types on ebay; long, thick stainless clips that i installed in the front and shorter, thin metal clips that I installed in the rear. The clips in the rear failed miserably at the most inopportune moment. I ended up losing a couple of hub caps in the process. I finally realized that the clips were the culprit and got some long, thick stainless clips for the rear. They have been working great.
Here is the finished product. I also added some lemmerz beauty rings so the chrome ended up being a bit more overpowering than the "Steel It", but overall I'm happy with the look.
Posted: Sun Feb 02, 2014 9:58 pm Post subject: |
Replaced the (3) fuel lines last night. Moved the fuel filter to the front (under the tank), figured it would be a good location so I could replace the fuel filter and check the brake fluid at the same time. Also added a shut-off valve.
Word to the wise if you try this setup, try not to kink the line when reinstalling the tank, kinda prevents fuel from getting to the engine. Took me a few hours to figure out why the car wouldn't start
Posted: Sun Feb 02, 2014 10:17 pm Post subject: |
A few weeks ago I decided to refresh my roof rack. Here's how it went:
First I removed all the slats and prepped the frame
I used my favorite rattle can paint that I've praised in the past (see rim restoration a few posts back). It covers so nicely and is super durable
I was going to buy new slats, but they priced out at about $70 for the set. I realized that I could just sand down the clear coat that's applied. An orbital sander did the trick to remove the pathetic thin coat of clear
Picked up some Minwax Ebony to darken up the slats a bit
And the rack reassembled with some brass hardware (subtle, but complimentary)
Posted: Sun Feb 02, 2014 10:31 pm Post subject: |
An upholstery wheel wrap I made a few weeks ago:
Started with some nice, smooth to the touch upholstery material that I cut to size and had the edges finished (sewed)
Alot of hand stitching later...
Feels really good to the touch. _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
Posted: Sat Feb 15, 2014 5:46 pm Post subject: |
Hey all,
I still have an old transmission (see the free transaxle I got on page 1 of this thread), the one that I was told was rebuilt.
Is there a diagnostic I can run on the transmission (besides just putting it in the car) to confirm that it was in fact rebuilt, or at least to see if it has any major problems? Any visuals I can check, like what the gaskets will look like if their new? The tranny doesn't leak at all, that may be a good first sign
Thanks. _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
Posted: Tue Feb 18, 2014 11:15 pm Post subject: |
Lights came in today...got the front and rear installed with some custom bracketry, the rears hooked up to the brake light by simply tapping off of the black wire in the tail light housing...thanks to this samba thread...http://www.thesamba.com/vw/forum/viewtopic.php?t=260178&highlight=
ballbag Samba Member
Joined: January 01, 2006 Posts: 204 Location: Cheshire, UK
Posted: Fri Mar 07, 2014 10:44 am Post subject: |
Great thread dude, love the car and the work you've done.
I was considering putting some beauty rings on my 356 steels. _________________ I never learned that much at school, but i've taught ladies plenty!! |
Posted: Sun Mar 09, 2014 10:05 pm Post subject: |
ballbag wrote: |
I was considering putting some beauty rings on my 356 steels. |
Thanks Ballbag. I never considered beauty rings until just before I put them on, but I have to say I love the look (with or without hubcaps!)
Just be careful with them the first few rides. It might depend on the manufacturer, but the ones that I got had a little bit of trouble "biting" into the rim and one of mine flew off before it settled. It might also be the paint that I used (steel it) has some weird properties that make it a bit slippery.
Good luck man. _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Fri Apr 11, 2014 8:04 pm Post subject: |
Just read your thread from the beginning. Nice work! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Sun Apr 27, 2014 4:36 pm Post subject: |
Here's a little trick to modify day-night mirrors to fit.
Picked one up after wanting one for a while....came home to fit it up and here's what it looked like...
Took it apart and figured I'd run to tap plastics for a replacement...Notice I kept the rivets after drilling them out. We'll need these later...
Tap quoted me $25 for a single, $35 for two. I decided instead to find a piece from the scrap pile. It was $0.55, but when I said "do you take Visa" she just gave it to me! So here's what I did...
Made a pattern from the mirror
Rough trim with a peanut grinder and finished it off with a belt sander
Fitted up the bracket without acrylic. The new acrylic was just a few hairs thicker than the original, so I had to grind down the two tabs at top that engage the mirror, for clearance.
Dry fit the acrylic for hole locations...
Drilled out the rivet holes. The acrylic ended up being just a little bit over-sized in order for there to be a little bit of meat around the mounting holes.
I used the rivets removed earlier, de-burred drilled out end so they'd fit back through the holes, but left them a bit rough.
Mixed up some JB Weld, popped the rivets back in and back-filled the holes with the JB Weld mix via tooth pick. This actually looks great, better even than the original rivets did.
Here's the finished product!
subgraphic Samba Member
Joined: January 02, 2004 Posts: 141 Location: San Diego, CA
Posted: Thu May 01, 2014 9:33 pm Post subject: |
Great thread! |
pdowty68 Samba Member
Joined: April 07, 2014 Posts: 224 Location: Long Island, New York
Posted: Mon Jul 07, 2014 5:36 pm Post subject: |
I'd kill for your car as it was when you first got it. Minimal rust! |
