Deep sump cleaning
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
1950split
1950split is offline
PostPosted: Sun Jul 22, 2012 2:41 pm    Post subject: Deep sump cleaning Reply with quote
Hi,
Maybe a silly question but how do you clean your oil sumps as you cannot see the interior very well and that the casting flashes make good traps for debris.
I've had a damage on a rod bearing and found small chips on the strainer plate. I poured acetone in the sump, shook it well and after emptying the acetone I used the compressor to blow it.
I'm not sure this is the best method an although I have a full flow set-up that should catch contamination I'm reluctant to start the freshly rebuilt engine with this sump..
Thanks for your help,
Phil
WanderHopple
WanderHopple is offline
PostPosted: Sun Jul 22, 2012 2:49 pm    Post subject: Reply with quote
I clean sumps by submersing them in my solvent tank and blowing air into it while under the solvent. {Be very careful, solvent can be blown all over the place if you do not have it completely under}
I use an air blower with a long tube on it so it will reach all the way in.
Dave Hopple Classic VW
2224 E.Highland St. Suite C
Shawnee, OK 74801
1-405-275-1703
SRP1
SRP1 is offline
PostPosted: Sun Jul 22, 2012 3:03 pm    Post subject: Reply with quote
You have the cases apart or together?
You must pull the bottom end completely apart to remove debris and flush/brush out the oil galleys.
Don't forget your cooler and hoses will be filled with metal also, I recommend you replace it.
www.srpengines.com
Bugless.......
1950split
PostPosted: Sun Jul 22, 2012 3:06 pm    Post subject: Reply with quote
I have rebuilt the whole engine, everything was taken appart and cleaned. Now the engine is back together and I'm just left with this sump issue.
I will replace the cooler and thoroughly clean the oil lines.
Sadly I don't have a part washer.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jul 22, 2012 3:25 pm    Post subject: Reply with quote
I've used a power washer.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
SamT
SamT is offline
PostPosted: Sun Jul 22, 2012 3:57 pm    Post subject: Reply with quote
I wash everything but steel Parts at The car wash.
mark tucker
mark tucker is offline
PostPosted: Sun Jul 22, 2012 4:27 pm    Post subject: Reply with quote
the actone works good, and you can add a few small peices of rage soaked & shake the crap out of it too. and I have also used the dish washer befor&after to be sure.and also you can get a syphen blow gun and use some laundry detergent,mixed with water, it cleans better than most other methods with about 10 psi.no mater what you use besure to have it clean befor you use it.the syphen blowgun is awassom for cleaning just about everything that gets nasty.kinda like steem cleaning with out all the heat&parafaniala.and pressure washers can be hazzardus to the digets&hands
vwracerdave
vwracerdave is offline
PostPosted: Sun Jul 22, 2012 5:35 pm    Post subject: Reply with quote
When I rebuild any engine I always take the caes and sump to the car wash. Spend a $1.00 and leave the mess there. Don't forget to wear gogles and a rain coat.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Max Welton
Max Welton is offline
PostPosted: Sun Jul 22, 2012 5:50 pm    Post subject: Re: Deep sump cleaning Reply with quote
A real oil filter will protect your bearings.
Max
The only thing more expensive than cheap parts is mixing cheap parts with stupidity.
MURZI
MURZI is offline
PostPosted: Sun Jul 22, 2012 6:52 pm    Post subject: Reply with quote
Buy a used sump Laughing
PENNY LOAFER MAFIA..step up or step back...
1962 Beetle Convertible http://s23.photobucket.com/albums/b374/MURZI/new%2062%20vert/
1968 BAJA http://s23.photobucket.com/albums/b374/MURZI/testmule/
My old Dune Buggy http://s23.photobucket.com/albums/b374/MURZI/
Quit playing...build a 2276 and be done with it.......
Hotrodvw
Hotrodvw is offline
PostPosted: Sun Jul 22, 2012 8:28 pm    Post subject: Reply with quote
I used Castrol Super Clean. I sprayed it liberally inside of the sump, rolled it around in my hands to slosh it to all of the corners and let it sit. After about 20 minutes, I rinsed it thoroughly with the garden hose, then dried it with compressed air. Worked pretty well I think.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost lots of money!
Hose & Fittings
SRP1
SRP1 is offline
PostPosted: Sun Jul 22, 2012 9:42 pm    Post subject: Reply with quote
Yep that is what I would do, just be careful not to let it sit to long, the superclean will eat the aluminum for lunch.
Once you get it all clean throw it in the dishwasher (laying flat) for a hot wash cycle.
www.srpengines.com
Bugless.......
vwracerdave
PostPosted: Mon Jul 23, 2012 6:46 am    Post subject: Reply with quote
Dishwasher will clean the outside but it will not clean the inside.
Hotrodvw
Hotrodvw is offline
PostPosted: Mon Jul 23, 2012 6:50 am    Post subject: Reply with quote
And will come with a complimentary divorce as well!
'67 Sunroof
Eric
Hose & Fittings
Mr. 010
Glenn is offline
PostPosted: Mon Jul 23, 2012 6:55 am    Post subject: Reply with quote
Might not matter since you already used the oven to do powder painting at home Wink
Glenn
HBB/RW
www.DasVolks.com
mark tucker
PostPosted: Mon Jul 23, 2012 7:27 am    Post subject: Reply with quote
my dishwasher has been "updated" for it's new ussage.and does a pretty good job on the inside,but with that said you cant ever be TOO clean so do it a few times,
1950split
PostPosted: Tue Jul 24, 2012 1:52 am    Post subject: Reply with quote
Murzi, I'll stick to my used sump Wink
I cleaned it yesterday. Used 1L of acetone and let it sit 30min on each side and then used compressed air to dry/blow it.
I just found one little tiny chip. The sump is now bone dry and ready to be fitted.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
