beetleboy74 Samba Member
Posted: Tue Jul 24, 2012 6:23 pm Post subject: How to bend the "tab" to limit total advance pleas |
Hey guys and girls I am making myrebuilt 1600dp with only 500 miles on it I am wondering how to bend the tab so its at 8* and 24* driving please help thank you
Jacob |
Hotrodvw Samba Member
Posted: Tue Jul 24, 2012 6:54 pm Post subject: |
Why only 24 deg of advance?? Set it at 30deg @ 3krpm, don't worry about what the timing is at idle. No reason to be bending tabs to limit it unless you're cramming air forcibly down it's throat. I'm assuming you're running a 009 dist.?? _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Tue Jul 24, 2012 7:17 pm Post subject: Yes |
Yes a 009 and my buddy told me 24 was best |
Posted: Tue Jul 24, 2012 7:22 pm Post subject: |
But you came here to ask as well. That is my suggestion...... Ask him his reason why. OR..........you can try both and see what you like best. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76899 Location: Sneaking up behind you
Posted: Tue Jul 24, 2012 7:26 pm Post subject: Re: Yes |
beetleboy74 wrote: |
Your buddy is wrong, 009s should be 28-32* BTDC @ 3500rpm. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jul 24, 2012 7:28 pm Post subject: But |
Yes but he has never done anything turbo and what I like in my opinion is what will run best and best reliability how do u bend the tabs and where r u tabs |
Posted: Tue Jul 24, 2012 7:29 pm Post subject: |
Is this a turbo motor?? _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Glenn Mr. 010
Posted: Tue Jul 24, 2012 7:32 pm Post subject: |
Turbo is different.
Get a CB digital distributor and map the ignition.
Bend the tabs at the top and bottom of this picture. That will limit the total movement.
Member #1009
#BlueSquare |
Posted: Tue Jul 24, 2012 7:37 pm Post subject: |
Well I kinda don't want to spend money tho I.have a crane cams ignition box and 009 disty would I be good with just keeping it like it is and if not what's a hOme remidy to fixin it |
Posted: Tue Jul 24, 2012 7:41 pm Post subject: |
If you're going to run a turbo and lock the timing, you're going to miss a lot on the street. You'll miss considerable off boost timing which a lot of your street driving will probably live off boost, until you nail it and hold it open as you build boost. I did this myself, and the timing was missed. I went with the CB Digital dist and programmed it properly. There are several good ways to do this, but locking it out isn't ideal for something other than a drag car IMO. To each his own. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Yes it will beturbo |
Posted: Tue Jul 24, 2012 7:43 pm Post subject: |
Good info to include in your original post. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Jul 24, 2012 8:33 pm Post subject: |
Best money you could spend is on a good ignition setup.
There is nothing cheap about setting up a turbo engine. If you go cheap ignition you'll have a bunch of piston pieces laying in the bottom of your case.
Take the time to do it right and learn form others.
If you don't want to get serious and buy a decent ignition then at least limit the boost to 6 lbs. or less.
Good luck with your build and post lot s of pics.....we always love pictures of homemade turbo setups. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Tue Jul 24, 2012 8:49 pm Post subject: |
Well I kinda don't want to spend money tho |
Come on dude, get real. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Wed Jul 25, 2012 3:47 am Post subject: |
rule #1 - it doesn't cost any more to do it right the first time. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
mark tucker Samba Member
Posted: Wed Jul 25, 2012 9:00 am Post subject: |
get a boost retard. |
Posted: Wed Jul 25, 2012 9:05 am Post subject: |
mark tucker wrote: |
Oooh the power of a comma, or the lack there of. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Wed Jul 25, 2012 9:16 am Post subject: |
Hotrodvw wrote: |
Oooh the power of a comma, or the lack there of. |
Classic!! _________________
Mitey62 wrote: |
808OvalGreasemonkey Samba Member
Posted: Thu Jul 26, 2012 3:38 am Post subject: |
Turbo setup that cost no money? |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Thu Jul 26, 2012 4:00 am Post subject: |
Sometimes I think you do it on purpose...
