sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Sun Jul 29, 2012 7:11 pm Post subject: Custom Bikini Top |
I would like to make a bikini top similar to this one...
http://www.thesamba.com/vw/classifieds/detail.php?id=1234736
...but with the ability to seal with the side curtains. I will also be making a surfboard rack that attaches to the roll bar, which is the biggest reason that I don't just get The Thing Shop bikini top.
So, I'm hoping to get some input before I get carried away and mess it up.
(disregard the wood dowels, they're holding the windshield where it belongs)
I'm using 1" square tubing with a stainless bolt to attach to the windshield. The bolt is welded to some plate and then welded inside the square tube. It then drops inside the window frame like the factory soft top pins.
The other end of the tubing will also be removable without tools, but attached to the roll bar in a way that it keeps tension on the windshield. I'll cut them about even with the rear side curtain.
The vinyl top would attach to the windshield, snap onto the side rails, and then continue over the rear of the roll bar and use adjustable straps down to the hooks on the body.
Any comments or suggestions before I get too far?
Thanks,
Robb _________________ (ignore the X's ) |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Mon Jul 30, 2012 1:43 pm Post subject: |
Looking good to me.
Do you have any plan for adding lateral stiffness? The 1in tubing is strong enough, but I see it bowing towards the middle having to hold the windshield in place and keep tension on the top.
Are you putting a bow across the windshield frame? That's where the TTS top really wins out over the one advertised here, a solid hold with no modifications to the body.
Is it going to fold? In my opinion, that's not a necessary bikini top feature but perhaps nice to have.
This is high on my list... The temperatures here in the sun are absolutely brutal some times. I've taken to keeping the convertible top up and doors off, but keep thinking about that big parachute back there doing wonders for my gas mileage. |
Madkel Samba Member
Joined: May 02, 2008 Posts: 106 Location: North San Diego County
Posted: Tue Jul 31, 2012 8:09 pm Post subject: |
Based upon your past work, this will be a first class modification.
Cannot wait to see the end result. _________________ 1973 Type 181 - 2016cc - 091 trans
ITS A FUN RIDE! |
DougD Samba Member
Joined: October 11, 2011 Posts: 334 Location: Auburn, WA
Posted: Wed Aug 01, 2012 6:54 am Post subject: |
How hard is it to remove the rubber piece at the top of the windshield? Seems like it would be an easy place to install a slide in attachment for the bikini similar to the one for sale in the classified section but without permanent modifications to the body. |
Posted: Wed Aug 01, 2012 8:20 am Post subject: |
DougD wrote: |
It's a t-shape gasket that fits into a channel. Pretty tough to get in or out, though it could be done. The real issue is that nothing would be supporting the windshield frame, so it would just keep bending farther and farther back. |
Posted: Wed Aug 01, 2012 11:05 am Post subject: |
If I were to get a soft top, I'd get the one with the removable back window for just this reason.
Quote: |
Are you putting a bow across the windshield frame? |
I'm trying to come up with something to slide into the existing channel. The rubber slides out easily on mine. Attaching a channel to the windshield will be the last resort.
This is the 2nd benefit of the side bars. I could make or buy some windshield stiffeners from The Thing Shop otherwise.
Quote: |
Do you have any plan for adding lateral stiffness? The 1in tubing is strong enough, but I see it bowing towards the middle having to hold the windshield in place and keep tension on the top. |
After giving it more thought, I will be adding another attachment point at the rear end on the square tube to the cage. This way the bars and windshield are a solid unit. I could also shim the side bars further apart as the top stretches to take up the slack, if needed.
Cannot wait to see the end result. |
C'mon, Jim, you're embarrasing me.
I'll get some more work done this weekend with a plastic tarp mocked up and post pics then.
I also want to make the front curtains with a zippered window like a Jeep. I have an idea that I think will work.
Now I just have to find a good marine canvas shop in the area to take care of sewing the top and windows.
-Robb _________________ (ignore the X's ) |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Wed Aug 01, 2012 1:50 pm Post subject: |
I have custim biniki top, snappes to widshields over roll bar, adj. straps in back. I got TTS windshield braces. worth the $$$$$$$ |
Posted: Wed Aug 01, 2012 3:35 pm Post subject: |
FV195 wrote: |
Not without pictures, you don't _________________ (ignore the X's ) |
Mountain man Samba Member
Joined: February 19, 2011 Posts: 37 Location: Sevierville, Tennessee
Posted: Thu Aug 02, 2012 12:19 pm Post subject: Custom Bikini Top |
I have been looking for a solution for the exact same set up. I have a TTS Show bar and looking for a way to make a bikini top but also a zip off rear section to enclose or open up the back. Looking forward to your solutions and hopefully I can duplicate it. Send lots of pics. |
FV195 Samba Member
Posted: Thu Aug 02, 2012 12:23 pm Post subject: |
I have had 2 differant biniki tops on 2 cars, both open in the back, made them long enough in the sides to go over windows, but back has been open |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Mon Sep 10, 2012 1:40 pm Post subject: |
That looks ALOT like the thing Shop one, minus the fancy header bow, for @ half the cost? |
Posted: Mon Sep 10, 2012 8:23 pm Post subject: |
Much better price than TTS.
I thought about going with this style, but I want a snug fit to the side curtains and I need it to work with my surfboard rack idea.
I went to an upholstery shop a couple weeks ago. I'll get a better price if I wait til boat season ends.
I will be using the aluminum channel across the windshield, as well as one on each side attached to the top of the side bars. This should keep the wind and water out. Straps at the rear will keep it pulled tight.
I'll post pics of my progress as I make it. _________________ (ignore the X's ) |
Joined: January 05, 2009 Posts: 38 Location: washington, IL
Posted: Wed Sep 12, 2012 8:41 am Post subject: |
I would think an industrious individual could make a header with similar latching to the thing shop and use the $200 bikini top snaps into it. This could be fun. I hate dropping $400+ on the TTS top but I also would hate to put snaps on my windshield frame. Anyone using the snap top? |
Yarkle Samba Member
Posted: Fri Sep 28, 2012 5:29 pm Post subject: |
does anyone have pictures of how the thing shop bikini top actually attaches to the windshield? |
Posted: Fri Sep 28, 2012 5:34 pm Post subject: |
I believe it attaches just as the convertible top...with the latches at the top.
I'm actually considering abandoning this project and getting one. Have to work out a couple details before deciding.
Posted: Fri Sep 28, 2012 5:42 pm Post subject: |
Here ya go...
Quote: |
The front "bow" is made of wood, with a steel backer with the pins attached, the latch is also screwed in here..... There are two straps one on each side that go all the way to a tie down in the back, this is to place the rear two metal "bows" in the proper position and to give the top tension.... Now onto the topic of tension.... with the bikini top on and tensioned it pulls back on the windshield pretty good, this is why the thing shop now provides their windshield frame support brackets(which I need to buy), you can see that in my bottom pic with the window installed, which is to answer the question as to whether the windows "work" with the Thing-Shop top or not.... there is about a 1" gap between the top of the window and the edge of the top..... |
Yarkle Samba Member
Posted: Fri Sep 28, 2012 6:05 pm Post subject: |
im thinking the big reasons between the softopper and the thing shops price is that funky bow and the material itself. you may be getting what you pay for with the softtopper. |
Posted: Fri Sep 28, 2012 6:14 pm Post subject: |
Project is back on. One of the main benefits I want is for the side curtains to "somewhat" seal against the top. The Thing Shop Bikini Top doesn't do this. The convertible top with the roll up rear window is nice, but the price is insane. _________________ (ignore the X's ) |
Yarkle Samba Member
Posted: Fri Sep 28, 2012 7:01 pm Post subject: |
well, up here once its cool enough to have to have the windows on, theres gonna be salt on the road, so I dont use them. Pretty much, the bikini top is just going to be used, whether i buy or fabricate, to keep the sun off when its real hot, or if i get caught in a sudden downpour. |
