Flipping tie rods. Flip-it Kit.
alexwilson94
alexwilson94 is offline
PostPosted: Sun Aug 05, 2012 10:17 pm    Post subject: Flipping tie rods. Flip-it Kit. Reply with quote
Hey, so I need to install the Flip-it kit from topline. I recently lowered my car, and the tie rods are hitting the body on sharp turns/ bumpy roads. So, I get the part where I drill the tie rod hole, and insert the bushing. However, how do I actually FLIP the tie rod itself to insert it into the bushing upside down from the original location?
Thanks!
vw_hank
vw_hank is offline
PostPosted: Mon Aug 06, 2012 2:52 am    Post subject: Reply with quote
You dont actually flip anything, you well just tern the tie-rod end, and put it in from the bottom instead of from the top Very Happy You well probably need to adjust the alignment when dun..
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
