Desertbusman Samba Member
Posted: Thu Aug 09, 2012 1:25 pm Post subject: Re: New rebuild and no oil pressure. |
bugger101 wrote: |
Not everyone needs tom wilson's engine book. |
You are right. But based on the large amount of engine problems we see here a big wad of people threw away a lot of coin when $17 would have prevented it. _________________ 71 Superbug
71 Westy |
curtis4085 Samba Member
Posted: Thu Aug 09, 2012 2:07 pm Post subject: Re: New rebuild and no oil pressure. |
Desertbusman wrote: |
bugger101 wrote: |
You are right. But based on the large amount of engine problems we see here a big wad of people threw away a lot of coin when $17 would have prevented it. |
X10 ... I bought the book even though i did not rebuild my engine. What I learned is my first engine builder should have bought a copy as well. $4,500 and 9 m0nth of down time of a mistake. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Thu Aug 09, 2012 2:13 pm Post subject: Re: New rebuild and no oil pressure. |
bugger101 wrote: |
I wonder if anyone at GEX has ever seen one? Maybe we could pool our resources and buy them one.
velo96 Samba Member
Joined: May 04, 2009 Posts: 70 Location: Lebanon,Ohio
Posted: Thu Aug 09, 2012 2:15 pm Post subject: |
ok desertbusman I tried turning the engine backward by hand and adding oil to the sender hole with no luck, about a half a quart. Should it be harder to turn the engine backward than forward? I need to stop and take a mental break. Later i will start digging my way to the pump. The engine always ran thru smooth during assembly. I can't believe this is happening!! |
Posted: Thu Aug 09, 2012 4:22 pm Post subject: |
No it shouldn't be any harder turning it backwards. I would squirt some oil in thru the plug holes to give it a bit of piston and ring lube.
Too bad it's in the bus. Otherwise you could tip it up a bit and flood the whole pump and pickup area. _________________ 71 Superbug
71 Westy |
Posted: Thu Aug 09, 2012 6:38 pm Post subject: |
If it is really hard to turn backwards it could be that for some reason the inlet side of the pump is totally clogged or plain blocked off. This would deadhead the pump when you try to turn it backwards and would all but guaranty you could not make oil pressure. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 09, 2012 6:58 pm Post subject: |
velo96 wrote: |
Should it be harder to turn the engine backward than forward? |
Is the distributor installed?, if not the resistance may be the inadvertant remachining of the drive gear on the crank _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
velo96 Samba Member
Posted: Fri Aug 10, 2012 7:18 pm Post subject: |
So I removed the pump cover and rotated the engine by hand and the pump turns. Not a drop of oil came out of the pump when i removed the cover. The ports are clean. The only thing I see is the top gear has been rubbing the the cover. I remember checking it with a feeler gauge and the dimensions being at the minimum. I wonder if with the cover on the shaft is spinning but the gear isn't? I had to press the shaft in further when i got the pump and i remember thinking it was quite easy but not enough to alarm me. Tomorrow I'm going to recheck the clearances and pack the pump with vaseline. |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri Aug 10, 2012 7:23 pm Post subject: |
be careful if you do this. you may never seat the rings if you flood the cyls with oil _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
velo96 Samba Member
Posted: Sat Aug 11, 2012 10:12 am Post subject: |
Primed the pump with petroleum jelly and it took two seconds to have oil squirt out of the sender hole and loose oil filter. LESSON LEARNED!!! Thanks for everyones help!! |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Sat Aug 11, 2012 11:19 am Post subject: |
velo96 wrote: |
Awesome! Glad it worked out. _________________ '71 Westy |
SGKent Samba Member
Posted: Sat Aug 11, 2012 11:28 am Post subject: |
glad it worked out. |
Posted: Sat Aug 11, 2012 11:56 am Post subject: |
skills@eurocarsplus wrote: |
be careful if you do this. you may never seat the rings if you flood the cyls with oil |
I would like a bit of further explanation on this. Any oil that you squirt into the cylinder should be gone within minutes, so I don't see how it can have much affect on the seating of the rings. Never heard of anyone installing their pistons dry to speed up seating. |
