2002 cabrio power window regulator
Forum Index -> Water-cooled VW Share: Facebook Twitter
tkfar
tkfar is offline
PostPosted: Thu Aug 09, 2012 11:22 am    Post subject: 2002 cabrio power window regulator Reply with quote
I bought a 2002 cabrio that had passenger door window problems. After dismantling door , I found the problem to be a broken pulley on the regulator. The culprit was the large white pulley that is located closest to outside door handle (upper rear of door). A replacement regulator w/motor showed up at a local junkyard for only $80! So I replaced it and was the hero for 31 days (30-day warranty) until the same plastic pulley busted again. Anyone got a fix for this or know a source for a metal replacement pulley...........or have a busted regulator (left or right) with the large white pulley intact? Thanks
"Better to burn out than to rust"
1958 Single Cab
1971 Karmann Ghia vert
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
