iprangen Samba Member
Joined: December 10, 2007 Posts: 474 Location: Centerport, NY
Posted: Wed Aug 15, 2012 7:37 am Post subject: Double-checking, am I missing a tin? |
I checked the B-manual, but the picture is vague.
Besides the upper cylinder tin, is there a little tin that separates airflow on top of the cylinders? I don't think so, but I'm just checking.
I know that there is the small flat tin underneath the cylinders that pushes air sideways, but I'm just checking that there isn't one on top. I don't have flaps and its a 1600 DP in a '71.
Thanks! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Aug 15, 2012 7:49 am Post subject: |
Only the one built into the upper cylinder tin (upside down V), many aftermarket and chrome tins lack the piece.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Aug 15, 2012 7:56 am Post subject: |
Thanks again BusDaddy. I have original tin and that little piece is in place. I'm putting this longblock in for the second time and just tripple checking everything.
GeorgeO. Samba Member
Joined: October 08, 2010 Posts: 881 Location: Menifee, CA
Posted: Wed Aug 15, 2012 9:32 am Post subject: |
Good for you. My complaint with Vendors is that they have the "You Don't Need It" mindset. Yes you do need that little piece of tin to divert cool air around your heads, both side, but especially #3 cylinder where cooling is a problem. Like a High Weather pressure front, if that tin is missing all you do is create a dam where the cool air gets heated and when it finally makes it way around the head, it is already hot. Yeah you can gets some nice looking tins from some of these vendors, but keep in mind, the stock dual port motor was suppose to get at least 90k before an overhaul or rebuild. With aftermarket tins, your lucky to get 60k with any reliability and if you spend at least 3k on your motor, does it make sense to go cheap on the most important part of your motor, cooling tins?...I say not. Keep up the good work and gives some pictures when your done. |
Desertbusman Samba Member
Posted: Wed Aug 15, 2012 4:45 pm Post subject: |
Yes, that deflector is important. Mine have aftermarket cylinder tins but I fabbed and incorporated exact duplicates of those original deflectors. _________________ 71 Superbug
71 Westy |
