scottalford Samba Member
Joined: August 13, 2011 Posts: 331 Location: Orange, Australia
Posted: Sat Apr 05, 2014 2:45 pm Post subject: |
The next two pics show how I will be doing the join. The box sections being cut back to where they are square again.
_________________ I hate rust!
1959 driver with original 36er
1959 vert in rustortation http://www.thesamba.com/vw/forum/viewtopic.php?t=525582&highlight=
1954 oval just waiting |
L’ATELIER RENARD Samba Member
Posted: Mon Apr 07, 2014 11:50 am Post subject: |
scottalford wrote: |
M@mouth 37 wrote: |
My semaphore are of origin, only the metal is very rusty. My semaphore are of origin, only the metal is very rusty. I had to cut the metal and transplant it. |
I'll need as much detail as you can share. As this vert started life as a LHD car it has no semaphore pockets at all. So I'll need to fabricate a set up from scratch!
Whatever pictures, measurements and suggestions you have it would be appreciated. I want them to look OG as best I can.
Thanks again
Scott |
I think that the reproduction of this part is not complex. A simple iron U and soyer the sheet steel. When you will cut the sheet steel of rear panel section it is necessary cut longer and to pull down(to reduce) the sheet steel in 90 ° on 3 sides and to add the iron U. is not very clear the photo for explain.
Most great difficulty will be to find semaphore of specific convertible because longer and finer and expensive. |
AlteWagen Troll
Posted: Sat Apr 12, 2014 2:21 pm Post subject: |
AlteWagen wrote: |
Here are some pics of some pockets I picked up a few years ago off an Atlas blue 58 vert, hope they help.
Pocket location:
from body line to top of hole = 46.25mm
from B pillar edge to side of hole = 16mm
Overall length of hole = 176.50mm
Width of hole = 18mm |
Thanks for the great photos! I'd love to get my hands on an OG set like those! _________________ I hate rust!
Posted: Sat Apr 12, 2014 2:24 pm Post subject: |
M@mouth 37 wrote: |
Agree. I got a price for an OG set and was luck to survive the heart attack!
Plan is to get some repro lenses and try and convert a set of sedan semaphore. If anyone has a how to on that it would be appreciated.
Scott _________________ I hate rust!
Posted: Sat Apr 12, 2014 2:39 pm Post subject: |
If possible, do you have these dimensions?
I'm guessing the inner is spot welded to the inward folded sections of the outer panel?
AlteWagen Troll
Posted: Sat Apr 12, 2014 8:28 pm Post subject: |
Scott |
Here you go
Yes just spot welded on the lip.
Jason from the Resurrection Project in Sacramento made some vert semaphores for Yustrin's RHD conversion vert, maybe he could help. _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
Posted: Sun Apr 13, 2014 2:07 am Post subject: |
AlteWagen wrote: |
Scott |
Here you go
Jason from the Resurrection Project in Sacramento made some vert semaphores for Yustrin's RHD conversion vert, maybe he could help. |
Thanks so much for the dimension. Definately will help! I love the work that TheRessurectionProject does and follow him on Facebook. I will send him a PM and see if he will share some more of his secrets.
Thanks again
Posted: Fri Apr 25, 2014 3:08 pm Post subject: |
Some more work on the vert in between real work, one year old children and easter festivities.
Prepared the sides for the grafting.
Posted: Fri Apr 25, 2014 3:20 pm Post subject: |
Even though the clip is nice and straight the spare wheel well bottom had suffered from a few scrapes and bangs.
Time to practice some metal bumping. Actually turned out ok. Needs a crack welded up but will look the goods!
Posted: Fri Apr 25, 2014 3:30 pm Post subject: |
For the front apron the original plan was to graft in the 4 finger section into a repro apron like Jason did.
Some time ago I picked up a repro apron. I checked the general fit and shape and immediately thought, s&*t! It was a heap of crap. The general pressings was poor, the shape was wrong and it just did not fit up at all to the clip.
So what to do?? _________________ I hate rust!
Posted: Fri Apr 25, 2014 3:32 pm Post subject: |
I cut the original apron off what was left of the clip to have a look at how bad it really was. The PO had bolted doublers on the back, cake'd on a bucket load of filler on the front, and the underside was nearly beated back on itself.
Posted: Fri Apr 25, 2014 3:34 pm Post subject: |
Out with the wire wheel and the bog was off in a matter of minutes. This is what I was left looking at!
Repairable? _________________ I hate rust!
Posted: Fri Apr 25, 2014 3:39 pm Post subject: |
I thought I would spend some time to see if this could end up being useable. Nothing to loose
Started to work the bottom lip back to something that resembled how it left the factory. Also started to remove the remaining attached metal.
Getting the bottom lip correct is going to be a challenge. Fixing the torn bumper openings should be fairly straight forward. But if that bottom roll is wrong the whole front of the vert is just going to suck! _________________ I hate rust!
Posted: Fri Apr 25, 2014 4:01 pm Post subject: |
After looking at the apron some more this morning. I really think this isn't saveable. Just check out how bent and twisted it is compared to the repro panel.
Posted: Sat Apr 26, 2014 2:18 pm Post subject: |
People may remember the blue 58 which has so far donated its RHD dash, rear apron, cross members and random sheet metal. Since parking a sad 54 oval in the shed I had ear marked the front apron from the 58 for the oval.
Well, the oval may have to find another. Spent a couple of hours yesterday afternoon removing the 4 finger apron and a bit of panel beating.
Posted: Sat Apr 26, 2014 2:21 pm Post subject: |
Compared to the original front apron his is in mint condition
Well not really. Some rust in the bottom and a few holes in one side but the damamge to the lower lip is nothing compared to the green one.
